#include "at89x52.h"
#include "51hei.h"
#define LCM_RW P2_7 //定義引腳
#define LCM_RS P3_5
#define LCM_E P3_4
#define LCM_Data P0
#define Busy 0x80 //用于檢測LCM狀態(tài)字中的Busy標識
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
unsigned char code uctech[] = {" *51hei* "};
unsigned char code net[] = {" m.raoushi.com "};
void main(void)
guandz();//關(guān)閉點陣
guanled();//關(guān)閉led數(shù)碼管
Delay400Ms(); //啟動等待,等LCM講入工作狀態(tài)
LCMInit(); //LCM初始化
Delay5Ms(); //延時片刻(可不要)
DisplayListChar(0, 5, uctech);
DisplayListChar(0, 0, net);
ReadDataLCM();//測試用句無意義
while(1);
//寫數(shù)據(jù)
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
LCM_E = 0; //延時
LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//讀數(shù)據(jù)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態(tài)
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關(guān)閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(0x0C,1); // 顯示開及光標設置
//按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X, 0); //這里不檢測忙信號,發(fā)送地址碼
WriteDataLCM(DData);
//按指定位置顯示一串字符
unsigned char ListLength;
ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
if (X <= 0xF) //X坐標應小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
ListLength++;
X++;
//5ms延時
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延時
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
