查看: 772|回復: 9
請教網友我在本站下載網友的LCD19264C51例程改STC8H不顯示該怎么修改
ID:303735 發表于 2025-10-7 22:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*系統頭文件--------------------------------------------------------------------*/
#include <reg52.h>           //此文件中定義了單片機的一些特殊功能寄存器
#include "Delay.h"           //全局通用延時頭文件
#include "19264ks0107ZK.h"   //19264屏字庫
#include "19264ks0107.h"     //19264屏驅動
//#define uchar unsigned char  //宏定義無符號字符形數據類型進行聲明定義 定義名稱uchar 所占位數8位 范圍0~255
//#define uint unsigned int    //宏定義無符號整形數據類型進行聲明定義 定義名稱uint 所占位數16位 范圍0~65535
/*主函數--------------------------------------------------------------------*/
        Init19264LCD(); //19264屏初始化LCD函數
         /************說明*********************/
         /*例如:Disp_8x16(0,0,1,ZM_8x16[0]);
           括號第1個數指那一列開始
           括號第2個數指那一行開始
           括號第3個數指 0不反色顯示 1反色顯示
           括號第4個數指 字庫要顯示的字或符號*/
         Disp_8x16(0,0,1,ZM_8x16[0]); //0
         Disp_8x16(1,0,1,ZM_8x16[1]); //1
   Disp_8x16(2,0,1,ZM_8x16[2]); //2
         Disp_8x16(3,0,1,ZM_8x16[3]); //3
         Disp_8x16(4,0,1,ZM_8x16[4]); //4
         Disp_8x16(5,0,1,ZM_8x16[5]); //5
         Disp_8x16(6,0,1,ZM_8x16[6]); //6
         Disp_8x16(7,0,1,ZM_8x16[7]); //7
         Disp_8x16(8,0,1,ZM_8x16[8]); //8
         Disp_8x16(9,0,1,ZM_8x16[9]); //9
         Disp_8x16(11,0,0,ZM_8x16[10]); //A
         Disp_8x16(12,0,0,ZM_8x16[11]); //B
         Disp_8x16(13,0,0,ZM_8x16[12]); //C
         Disp_8x16(14,0,0,ZM_8x16[13]); //D
         Disp_8x16(15,0,0,ZM_8x16[14]); //E
         Disp_8x16(16,0,0,ZM_8x16[15]); //F
   Disp_8x16(17,0,0,ZM_8x16[16]); //G
         Disp_8x16(18,0,0,ZM_8x16[17]); //H
         Disp_8x16(19,0,0,ZM_8x16[18]); //I
         Disp_8x16(20,0,0,ZM_8x16[19]); //J
         Disp_8x16(21,0,0,ZM_8x16[20]); //K
         Disp_8x16(22,0,0,ZM_8x16[21]); //L
         Disp_8x16(23,0,0,ZM_8x16[22]); //M
         Disp_16x32(0,8,0,ZM_16x32[2]); //2
         Disp_16x32(1,8,0,ZM_16x32[0]); //0
         Disp_16x32(2,8,0,ZM_16x32[2]); //2
         Disp_16x32(3,8,0,ZM_16x32[1]); //1
         Disp_32x32(2,2,0,ZM_32x32[0]); //心
         Disp_32x32(3,2,0,ZM_32x32[1]); //想
         Disp_32x32(4,2,0,ZM_32x32[2]); //事
         Disp_32x32(5,2,0,ZM_32x32[3]); //成
         Disp_16x16(0,3,0,ZM_16x16[0]); //新
         Disp_16x16(1,3,0,ZM_16x16[1]); //年
         Disp_16x16(2,3,0,ZM_16x16[2]); //快
         Disp_16x16(3,3,0,ZM_16x16[3]); //樂
         Disp_16x16(4,3,0,ZM_16x16[4]); //!
         Disp_16x16(5,3,1,ZM_16x16[9]); //福
         Disp_16x16(7,3,0,ZM_16x16[5]); //身
         Disp_16x16(8,3,0,ZM_16x16[6]); //體
         Disp_16x16(9,3,0,ZM_16x16[7]); //健
         Disp_16x16(10,3,0,ZM_16x16[8]); //康
         Disp_16x16(11,3,0,ZM_16x16[4]); //!
}后面是我改的STC8H程序
//#include <stc8x.h>           //此文件中定義了單片機的一些特殊功能寄存器
#include "reg51.h"
#include "intrins.h"
sfr     P0M0    =   0x94;
sfr     P0M1    =   0x93;
sfr     P1M0    =   0x92;
sfr     P1M1    =   0x91;
sfr     P2M0    =   0x96;
sfr     P2M1    =   0x95;
sfr     P3M0    =   0xb2;
sfr     P3M1    =   0xb1;
sfr     P4M0    =   0xb4;
sfr     P4M1    =   0xb3;
sfr     P5M0    =   0xca;
sfr     P5M1    =   0xc9;
sfr     P6M0    =   0xcc;
sfr     P6M1    =   0xcb;
sfr     P7M0    =   0xe2;
sfr     P7M1    =   0xe1;
    P0M0 = 0x00;                                //設置P0.0~P0.7為雙向口模式
    P0M1 = 0x00;
    P1M0 = 0xff;                                //設置P1.0~P1.7為推挽輸出模式
    P1M1 = 0x00;
    P2M0 = 0x00;                                //設置P2.0~P2.7雙向模式
    P2M1 = 0x00;
    P3M0 = 0xff;                                //設置P3.0~P3.7為開漏模式
    P3M1 = 0xff;
           括號第1個數指那一列開始
           括號第2個數指那一行開始
         //Disp_8x16(1,0,1,ZM_8x16[1]); //1
   //Disp_8x16(2,0,1,ZM_8x16[2]); //2
         //Disp_8x16(3,0,1,ZM_8x16[3]); //3
        // Disp_8x16(4,0,1,ZM_8x16[4]); //4
         //Disp_8x16(5,0,1,ZM_8x16[5]); //5
         //Disp_8x16(6,0,1,ZM_8x16[6]); //6
        // Disp_8x16(7,0,1,ZM_8x16[7]); //7
        // Disp_8x16(8,0,1,ZM_8x16[8]); //8
         //Disp_8x16(9,0,1,ZM_8x16[9]); //9
         //Disp_8x16(11,0,0,ZM_8x16[10]); //A
         //Disp_8x16(12,0,0,ZM_8x16[11]); //B
         //Disp_8x16(13,0,0,ZM_8x16[12]); //C
         //Disp_8x16(14,0,0,ZM_8x16[13]); //D
         //Disp_8x16(15,0,0,ZM_8x16[14]); //E
         //Disp_8x16(16,0,0,ZM_8x16[15]); //F
   //Disp_8x16(17,0,0,ZM_8x16[16]); //G
         //Disp_8x16(18,0,0,ZM_8x16[17]); //H
         //Disp_8x16(19,0,0,ZM_8x16[18]); //I
         //Disp_8x16(20,0,0,ZM_8x16[19]); //J
         //Disp_8x16(21,0,0,ZM_8x16[20]); //K
         //Disp_8x16(22,0,0,ZM_8x16[21]); //L
         //Disp_8x16(23,0,0,ZM_8x16[22]); //M
        // Disp_16x32(0,8,0,ZM_16x32[2]); //2
         //Disp_16x32(1,8,0,ZM_16x32[0]); //0
         //Disp_16x32(2,8,0,ZM_16x32[2]); //2
         //Disp_16x32(3,8,0,ZM_16x32[1]); //1
         //Disp_32x32(2,2,0,ZM_32x32[0]); //心
         //Disp_32x32(3,2,0,ZM_32x32[1]); //想
         //Disp_32x32(4,2,0,ZM_32x32[2]); //事
         //Disp_32x32(5,2,0,ZM_32x32[3]); //成
         //Disp_16x16(0,3,0,ZM_16x16[0]); //新
         //Disp_16x16(1,3,0,ZM_16x16[1]); //年
         //Disp_16x16(2,3,0,ZM_16x16[2]); //快
         //Disp_16x16(3,3,0,ZM_16x16[3]); //樂
         //Disp_16x16(4,3,0,ZM_16x16[4]); //!
         //Disp_16x16(5,3,1,ZM_16x16[9]); //福
         //Disp_16x16(7,3,0,ZM_16x16[5]); //身
         //Disp_16x16(8,3,0,ZM_16x16[6]); //體
         //Disp_16x16(9,3,0,ZM_16x16[7]); //健
         //Disp_16x16(10,3,0,ZM_16x16[8]); //康
         //Disp_16x16(11,3,0,ZM_16x16[4]); //!
}延時庫也按照STC8的延時計算
#ifndef __DELAY_H_
#define __DELAY_H_
/*延時函數 Delay_ms(1)時大約1ms——————————————————————————————————————————————————————*/
void Delay_ms(uint ms)
  //uchar t;
// while(ms--)
           // for(t = 110; t > 0; t --);
//void Delay1ms(void)        //@11.0592MHz
        unsigned char data i, j;
        _nop_();
        i = 2;
        j = 199;
        do
                while (--j);
        } while (--i);
/*延時函數 Delay_us(1)時大約1us——————————————————————————————————————————————————————*/
/*void Delay_us(uint us)
   while(--us);
#endif
請教高手如何能在STC8上正確顯示,謝謝指教!
STC8H51hei.zip
23.42 KB, 下載次數: 0
ID:303735 發表于 2025-10-7 22:22 | 只看該作者
LCD19264驅動庫沒有作修改
#ifndef __19264KS0107_H_
#define __19264KS0107_H_
/*定義19264液晶屏數據線———————————————————————————————————————————————————————————————————————*/
#define Bus_Port P2    // 數據D0~D7
sbit LCD_RS  = P0^5;          // 數據=高,指令=低
sbit LCD_RW  = P0^4;          // 讀=高,寫=低
sbit LCD_EN  = P0^3;          // 讀\寫使能
sbit LCD_CS1 = P0^2;          // 片選1
sbit LCD_RST = P0^6;         // 液晶復位,低電平復位
sbit LCD_CS2 = P0^1;          // 片選2
sbit LCD_CS3 = P0^0;          // 片選3
/*寫數據——————————————————————————————————————————————————————————————————————————————————————*/
void Write19264_data(uchar dat)
        LCD_RS=1;
        LCD_RW=0;
        Bus_Port=dat;
        LCD_EN=1;
        _nop_();
        LCD_EN=0;
/*寫指令——————————————————————————————————————————————————————————————————————————————————————*/
void Write19264_com(uchar com)
        LCD_RS=0;
        LCD_RW=0;
        Bus_Port=com;
        LCD_EN=1;
        _nop_();
        _nop_();
        LCD_EN=0;
  _nop_();
        _nop_();
/*選擇屏幕,screen: =0左屏;=1中屏;——————————————————————————————————————————————————————*/
void SelectScreen(uchar screen)
        switch(screen)
                case 0: LCD_CS1=0; LCD_CS2=1; LCD_CS3=1; break;                 //左屏
                 case 1: LCD_CS1=1; LCD_CS2=0; LCD_CS3=1; break;                 //中屏
          case 2: LCD_CS1=1; LCD_CS2=1; LCD_CS3=0; break;                 //右屏
/*設定行地址(頁面)--X=0-7—————————————————————————————————————————————————————————————————————*/
void SetLine(uchar Line)
        Line=Line & 0x07;           //0<=line<=7
        Line=Line | 0xb8;           //1011 1xxx
        Write19264_com(Line);                //向LCD發送命令
/*清屏函數,screen: =0左屏;=1中屏;=2右屏——————————————————————————————————————————————————————*/
void ClearScreen(uchar screen)
        uchar i,j;
        SelectScreen(screen);
        for(i=0;i<8;i++)
                SetLine(i);
                for(j=0;j<64;j++)
                        Write19264_data(0x00);
/********************液晶片選并返回列地址***************************/
uchar LCD19264_PX(uchar add)
         uchar ZZY;  //ZZY代表左中右意思
         ZZY = add/64;
         if(ZZY==0){LCD_CS1=0;} else LCD_CS1=1;//片選左屏
         if(ZZY==1){LCD_CS2=0;} else LCD_CS2=1;//片選中屏
         if(ZZY==2){LCD_CS3=0;} else LCD_CS3=1;//片選左屏
         return(add-ZZY*64);                   //返回在哪片小屏上的列開始寫
/*初始化LCD函數———————————————————————————————————————————————————————————————————————————————*/
void Init19264LCD(void)
        uchar i;
        LCD_RST=0;                                    //液晶復位
        Delay_ms(10);
        LCD_RST=1;
        for (i=0;i<3;i++)
                LCD19264_PX(i);            //選擇左中右屏
                ClearScreen(i);                  //清除左中右屏顯示
        Write19264_com(0x3f);        //操作完畢開顯示
函數功能:指定位置顯示8*16的字符
colcol列0~23,page行0~3   fb帶表反白顯示,fb=非0是反白顯示,fb=0正常顯示
void Disp_8x16(uchar col,uchar page,uchar fb,uchar code *cn)
                uchar i,j,xpcol,page1;
                xpcol =LCD19264_PX(col*8); //求出在哪片小屏上的列開始寫
                page1=page*2;
                for(i=0;i<2;i++)
                                Write19264_com(0xb8+page1+i);
                                Write19264_com(0x40+xpcol);
                                for(j=0;j<8;j++)
                                                        if(fb)  //如果f非0,則反白顯示。
        Write19264_data(~(cn[i*8+j]));
                                                        else   //否則正常顯示
        Write19264_data(cn[i*8+j]);
函數功能:指定位置顯示16*16的字符
col列0~11,page頁0~3   fb帶表反白顯示,fb=非0是反白顯示,fb=0正常顯示
void Disp_16x16(uchar col,uchar page,uchar fb,uchar code *cn)
                xpcol=LCD19264_PX(col*16);    // 求出在哪片小屏上的列開始寫
                page1=page*2;
                for(i=0;i<2;i++)
                                        for(j=0;j<16;j++)
        Write19264_data(~(cn[i*16+j]));
                                                        else   //否則正常顯示
        Write19264_data(cn[i*16+j]);
函數功能:指定位置顯示16*32的字符
col列0~11,page頁0~16   fb帶表反白顯示,fb=非0是反白顯示,fb=0正常顯示
void Disp_16x32(uchar col,uchar page,bit fb,uchar code *cn)
            uchar i,n,xpcol;
            n = page/4;
                  Write19264_com(0xb8+n);
                        for(i=0;i<64;i++)
                                        if(i==16)
                                                n+=1;
                                                if(i==32)
                                                        n+=1;
                                                if(i==48)
                                                        n+=1;
                                                if(i==64)
                                                        n+=1;
                                        if(fb==1)
                                                Write19264_data(~(cn[i]));
                                                Write19264_data(cn[i]);
函數功能:指定位置顯示32*32的字符
col列0~4,page頁0~5   fb帶表反白顯示,fb=非0是反白顯示,fb=0正常顯示
void Disp_32x32(uchar col,uchar page,bit fb,uchar code *cn)
          uchar i,xpcol;
    xpcol=LCD19264_PX(col*32);    //求出在哪片小屏上的列開始寫
                Write19264_com(0xb8+page);
                        for(i=0;i<128;i++)
                                        if(i==32)
                                                page+=1;
                                                if(i==64)
                                                        page+=1;
                                                if(i==96)
                                                        page+=1;
                                                if(i==128)
                                                        page+=1;
                                        if(fb==1)
#endif
ID:584814 發表于 2025-10-9 08:20 | 只看該作者
在確保除單片機以外的硬件相同接法沒問題且都是51單片機的情況下查延時。
ID:59202 發表于 2025-10-18 20:33 | 只看該作者
樓主給的void Delay_ms(uint ms)延時函數根本編譯不過,先把這個函數弄好再說,然后在控制 LCD_RS ,LCD_RW,LCD_EN,  LCD_CS1,  LCD_RST, LCD_CS2,  LCD_CS3每個引腳后再加上延時幾ms。
ID:1064915 發表于 2025-10-19 08:31 | 只看該作者
先用51試驗,成功再換stc8
ID:303735 發表于 2025-11-7 11:15 | 只看該作者
xxxevery 發表于 2025-10-18 20:33
樓主給的void Delay_ms(uint ms)延時函數根本編譯不過,先把這個函數弄好再說,然后在控制 LCD_RS ,LCD_RW ...
確實是延時的問題,STC8比51快
ID:303735 發表于 2025-11-7 11:16 | 只看該作者
man1234567 發表于 2025-10-9 08:20
是的硬件沒毛病,就是STC8要延時才行
ID:303735 發表于 2025-11-7 11:17 | 只看該作者
joyb 發表于 2025-10-19 08:31
先用51試驗,成功再換stc8
51完全OK
ID:1162659 發表于 2025-11-7 12:41 | 只看該作者
用51調試
ID:303735 發表于 2025-12-21 19:35 | 只看該作者
51完全沒問題,實際要上STC8H。
