查看: 504|回復: 2
LED點陣實驗兩個圖案顯示for循環
ID:1150380 發表于 2025-5-14 16:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"
#include "intrins.h"
typedef unsigned char u8;
typedef unsigned int u16;
sbit SRCLK=P3^6;
sbit rCLK=P3^5;
sbit SER=P3^4;
//點陣列控制數據1
u8 gled_col[32]=
{0x80,0x00,0x9F,0x10,0x90,0x10,0x90,0x08,0x90,0x04,0x9E,0x02,0x82,0x00,0xE2,0x7F,
0x82,0x02,0x9E,0x04,0x90,0x04,0x90,0x08,0x90,0x10,0x90,0x22,0x8A,0x41,0x84,0x00
//點陣列控制數據2
u8 gled_co2[32]=
{0x80,0x08,0x82,0x08,0xF4,0x7F,0x84,0x08,0x00,0x02,0xE1,0x3F,0x02,0x22,0xFA,0x7F,
0x08,0x22,0xE4,0x3F,0x07,0x02,
0xA4,0x26,0xA4,0x2A,0x64,0x2A,0x14,0x22,0x08,0x22};
//點陣行控制數據
u8 gled_row[32]=
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x08,
0x10,0x20,0x40,0x80};
void delay_10us(u16 ten_us)//當傳入Ten_us=1時,大約延時10us
        while(ten_us--);
void hc595_write_data(u8 dat1,u8 dat2,u8 dat3,u8 dat4)
        u8 i=0;
        for(i=0;i<8;i++)
                 SER=dat4>>7;
                dat4<<=1;
                SRCLK=0;
                _nop_();
                SRCLK=1;
                _nop_();
        for(i=0;i<8;i++)
                 SER=dat3>>7;
                dat3<<=1;
                SRCLK=0;
                _nop_();
                SRCLK=1;
                _nop_();
        for(i=0;i<8;i++)
                 SER=dat2>>7;
                dat2<<=1;
                SRCLK=0;
                _nop_();
                SRCLK=1;
                _nop_();
        for(i=0;i<8;i++)
                 SER=dat1>>7;
                dat1<<=1;
                SRCLK=0;
                _nop_();
                SRCLK=1;
                _nop_();
        rCLK=1;
        delay_10us(1);
        rCLK=0;
        u8 i=0;
        int j;
                for(j=0;j<100;j++)
                        for(i=0;i<16;i++)//循環16次 行,列
                        {        hc595_write_data(gled_row[i],gled_row[i+16],~gled_col[i*2],~gled_col[i*2+1]);
                                delay_10us(10);//延遲一段時間,
                                hc595_write_data(0x00,0x00,0x00,0x00);//消影
                for(j=0;j<100;j++)
                                hc595_write_data(gled_row[i],gled_row[i+16],~gled_co2[i*2],~gled_co2[i*2+1]);
ID:619259 發表于 2025-6-20 16:50 | 只看該作者
不同的點陣屏電路,程序會有區別,希望樓主先上屏電路圖,便于理解程序。
ID:325985 發表于 2025-6-20 19:14 | 只看該作者
既無硬件電路又無實物顯示效果,霧里云里。
