求大佬解惑,或提供一下思路,忙活一天了
如圖,使用該模塊實(shí)現(xiàn)電腦對(duì)單片機(jī)通信
大致硬件連接如下
PB13 ------> SPI2_SCK
PB14 ------> SPI2_MISO
PB15 ------> SPI2_MOSI
PC13 ------> CSN
PC14 ------> CE
PC15 ------> IRQ
現(xiàn)在問(wèn)題是電腦端NRF24L01接收無(wú)消息
這是cubemx設(shè)置
這是main代碼
- #include "main.h"
- #include "spi.h"
- #include "gpio.h"
- #include "nrf24l01.h"
- #include <stdio.h>
- #define u8 uint8_t
- #define u16 uint16_t
- void SystemClock_Config(void);
- int main(void)
- /* USER CODE BEGIN 1 */
- u8 tmp_buf[32]={0};
- u8 mode;
- u8 t=0;
- HAL_Init();
- SystemClock_Config();
- MX_GPIO_Init();
- MX_SPI2_Init();
- while(NRF24L01_Check())
- printf("NRF_ERROR!!!\r\n");
- HAL_Delay(200);
- printf("NRF_OK!!!\r\n");
- printf("SET NRF_TX_MODE ... \r\n");
- HAL_Delay(200);
- NRF24L01_TX_Mode();
- * 組裝數(shù)據(jù)幀,第一位是有效數(shù)據(jù)的長(zhǎng)度
- tmp_buf[0] = 5;
- tmp_buf[1] = 'A';
- tmp_buf[2] = 'B';
- tmp_buf[3] = 'C';
- tmp_buf[4] = 'D';
- tmp_buf[5] = 'E';
- printf("Send message: ");
- for (t=0; t < 32; t++)
- printf("%x ", tmp_buf[t]);
- printf("\r\n");
- while (1)
- if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
- printf("\r\nSend Date: ");
- }else
- printf("\r\nSend failed!\r\n");
- HAL_Delay(1500);
- if(mode==0)//RX
- NRF24L01_RX_Mode();
- else//TX模式
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
這是nrf24l01.c
- #include "nrf24L01.h"
- #include "spi.h"
- //const uint8_t TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發(fā)送地址
- //const uint8_t RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址
- const uint8_t TX_ADDRESS[TX_ADR_WIDTH]={0xFF,0xFF,0xFF,0xFF,0xFF}; //發(fā)送地址
- const uint8_t RX_ADDRESS[RX_ADR_WIDTH]={0xFF,0xFF,0xFF,0xFF,0xFF}; //接收地址
- * 函數(shù)功能: 往串行Flash讀取寫(xiě)入一個(gè)字節(jié)數(shù)據(jù)并接收一個(gè)字節(jié)數(shù)據(jù)
- * 輸入?yún)?shù): byte:待發(fā)送數(shù)據(jù)
- * 返 回 值: uint8_t:接收到的數(shù)據(jù)
- * 說(shuō) 明:無(wú)
- uint8_t SPIx_ReadWriteByte(SPI_HandleTypeDef* hspi,uint8_t byte)
- uint8_t d_read,d_send=byte;
- if(HAL_SPI_TransmitReceive(hspi,&d_send,&d_read,1,0xFF)!=HAL_OK)
- d_read=0xFF;
- return d_read;
- * 函數(shù)功能: 檢測(cè)24L01是否存在
- * 輸入?yún)?shù): 無(wú)
- * 返 回 值: 0,成功;1,失敗
- * 說(shuō) 明:無(wú)
- uint8_t NRF24L01_Check(void)
- uint8_t buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
- uint8_t i;
- NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//寫(xiě)入5個(gè)字節(jié)的地址.
- NRF24L01_Read_Buf(TX_ADDR,buf,5); //讀出寫(xiě)入的地址
- for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
- if(i!=5)return 1; //檢測(cè)24L01錯(cuò)誤
- return 0; //檢測(cè)到24L01
- * 函數(shù)功能: SPI寫(xiě)寄存器
- * 返 回 值: 無(wú)
- * 說(shuō) 明:reg:指定寄存器地址
- uint8_t NRF24L01_Write_Reg(uint8_t reg,uint8_t value)
- uint8_t status;
- NRF24L01_SPI_CS_ENABLE(); //使能SPI傳輸
- status =SPIx_ReadWriteByte(&hspi2,reg); //發(fā)送寄存器號(hào)
- SPIx_ReadWriteByte(&hspi2,value); //寫(xiě)入寄存器的值
- NRF24L01_SPI_CS_DISABLE(); //禁止SPI傳輸
- return(status); //返回狀態(tài)值
- * 函數(shù)功能: 讀取SPI寄存器值
- * 返 回 值: 無(wú)
- * 說(shuō) 明:reg:要讀的寄存器
- uint8_t NRF24L01_Read_Reg(uint8_t reg)
- uint8_t reg_val;
- SPIx_ReadWriteByte(&hspi2,reg); //發(fā)送寄存器號(hào)
- reg_val=SPIx_ReadWriteByte(&hspi2,0XFF);//讀取寄存器內(nèi)容
- return(reg_val); //返回狀態(tài)值
- * 函數(shù)功能: 在指定位置讀出指定長(zhǎng)度的數(shù)據(jù)
- * 返 回 值: 此次讀到的狀態(tài)寄存器值
- * 說(shuō) 明:無(wú)
- uint8_t NRF24L01_Read_Buf(uint8_t reg,uint8_t *pBuf,uint8_t len)
- uint8_t status,uint8_t_ctr;
- status=SPIx_ReadWriteByte(&hspi2,reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
- for(uint8_t_ctr=0;uint8_t_ctr<len;uint8_t_ctr++)
- pBuf[uint8_t_ctr]=SPIx_ReadWriteByte(&hspi2,0XFF);//讀出數(shù)據(jù)
- NRF24L01_SPI_CS_DISABLE(); //關(guān)閉SPI傳輸
- return status; //返回讀到的狀態(tài)值
- * 函數(shù)功能: 在指定位置寫(xiě)指定長(zhǎng)度的數(shù)據(jù)
- * 返 回 值: 無(wú)
- * 說(shuō) 明:reg:寄存器(位置) *pBuf:數(shù)據(jù)指針 len:數(shù)據(jù)長(zhǎng)度
- uint8_t NRF24L01_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t len)
- status = SPIx_ReadWriteByte(&hspi2,reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
- for(uint8_t_ctr=0; uint8_t_ctr<len; uint8_t_ctr++)
- SPIx_ReadWriteByte(&hspi2,*pBuf++); //寫(xiě)入數(shù)據(jù)
- * 函數(shù)功能: 啟動(dòng)NRF24L01發(fā)送一次數(shù)據(jù)
- * 返 回 值: 發(fā)送完成狀況
- * 說(shuō) 明:txbuf:待發(fā)送數(shù)據(jù)首地址
- uint8_t NRF24L01_TxPacket(uint8_t *txbuf)
- uint8_t sta;
- NRF24L01_CE_LOW();
- NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫(xiě)數(shù)據(jù)到TX BUF 32個(gè)字節(jié)
- NRF24L01_CE_HIGH();//啟動(dòng)發(fā)送
- while(NRF24L01_IRQ_PIN_READ()!=0);//等待發(fā)送完成
- sta=NRF24L01_Read_Reg(STATUS); //讀取狀態(tài)寄存器的值
- NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標(biāo)志
- if(sta&MAX_TX)//達(dá)到最大重發(fā)次數(shù)
- NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
- return MAX_TX;
- if(sta&TX_OK)//發(fā)送完成
- return TX_OK;
- return 0xff;//其他原因發(fā)送失敗
- * 函數(shù)功能:啟動(dòng)NRF24L01接收一次數(shù)據(jù)
- * 返 回 值: 無(wú)
- * 說(shuō) 明:無(wú)
- uint8_t NRF24L01_RxPacket(uint8_t *rxbuf)
- uint8_t sta;
- if(sta&RX_OK)//接收到數(shù)據(jù)
- NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
- NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
- return 0;
- return 1;//沒(méi)收到任何數(shù)據(jù)
- * 函數(shù)功能: 該函數(shù)初始化NRF24L01到RX模式
- * 返 回 值: 無(wú)
- * 說(shuō) 明:無(wú)
- void NRF24L01_RX_Mode(void)
- NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0F);//配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自動(dòng)應(yīng)答
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
- //NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設(shè)置RF通信頻率
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,0); //設(shè)置RF通信頻率
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開(kāi)啟
- NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數(shù)據(jù)寬度
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t*)RX_ADDRESS,RX_ADR_WIDTH);//寫(xiě)RX節(jié)點(diǎn)地址
- NRF24L01_CE_HIGH(); //CE為高,進(jìn)入接收模式
- HAL_Delay(1);
- * 函數(shù)功能: 該函數(shù)初始化NRF24L01到TX模式
- * 返 回 值: 無(wú)
- * 說(shuō) 明:無(wú)
- void NRF24L01_TX_Mode(void)
- NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(uint8_t*)TX_ADDRESS,TX_ADR_WIDTH);//寫(xiě)TX節(jié)點(diǎn)地址
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t*)RX_ADDRESS,RX_ADR_WIDTH); //設(shè)置TX節(jié)點(diǎn)地址,主要為了使能ACK
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
- NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0xff);//設(shè)置自動(dòng)重發(fā)間隔時(shí)間:4000us + 86us;最大自動(dòng)重發(fā)次數(shù):15次
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設(shè)置RF通道為40
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開(kāi)啟
- NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式,開(kāi)啟所有中斷
- NRF24L01_CE_HIGH();//CE為高,10us后啟動(dòng)發(fā)送
- HAL_Delay(1);
- * 函數(shù)功能: 該函數(shù)NRF24L01進(jìn)入低功耗模式
- * 返 回 值: 無(wú)
- * 說(shuō) 明:無(wú)
- void NRF_LowPower_Mode(void)
- NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x00); //配置工作模式:掉電模式
這是nrf24l01.h
- #ifndef _NRF24L01_H
- #define _NRF24L01_H
- #include "main.h"
- /* 宏定義 --------------------------------------------------------------------*/
- #define NRF24L01_SPI_CS_ENABLE() HAL_GPIO_WritePin(CS_GPIO_Port,CS_Pin,GPIO_PIN_RESET)
- #define NRF24L01_SPI_CS_DISABLE() HAL_GPIO_WritePin(CS_GPIO_Port,CS_Pin,GPIO_PIN_SET)
- #define NRF24L01_CE_LOW() HAL_GPIO_WritePin(CE_GPIO_Port,CE_Pin,GPIO_PIN_RESET)
- #define NRF24L01_CE_HIGH() HAL_GPIO_WritePin(CE_GPIO_Port,CE_Pin,GPIO_PIN_SET)
- #define NRF24L01_IRQ_PIN_READ() HAL_GPIO_ReadPin(IRQ_GPIO_Port,IRQ_Pin)
- // NRF24L01發(fā)送接收數(shù)據(jù)寬度定義
- #define TX_ADR_WIDTH 5 //5字節(jié)的地址寬度
- #define RX_ADR_WIDTH 5 //5字節(jié)的地址寬度
- #define TX_PLOAD_WIDTH 32 //32字節(jié)的用戶數(shù)據(jù)寬度
- #define RX_PLOAD_WIDTH 32 //32字節(jié)的用戶數(shù)據(jù)寬度
- //NRF24L01寄存器操作命令
- #define NRF_READ_REG 0x00 //讀配置寄存器,低5位為寄存器地址
- #define NRF_WRITE_REG 0x20 //寫(xiě)配置寄存器,低5位為寄存器地址
- #define RD_RX_PLOAD 0x61 //讀RX有效數(shù)據(jù),1~32字節(jié)
- #define WR_TX_PLOAD 0xA0 //寫(xiě)TX有效數(shù)據(jù),1~32字節(jié)
- #define FLUSH_TX 0xE1 //清除TX FIFO寄存器.發(fā)射模式下用
- #define FLUSH_RX 0xE2 //清除RX FIFO寄存器.接收模式下用
- #define REUSE_TX_PL 0xE3 //重新使用上一包數(shù)據(jù),CE為高,數(shù)據(jù)包被不斷發(fā)送.
- #define NOP 0xFF //空操作,可以用來(lái)讀狀態(tài)寄存器
- //SPI(NRF24L01)寄存器地址
- #define CONFIG 0x00 //配置寄存器地址;bit0:1接收模式,0發(fā)射模式;bit1:電選擇;bit2:CRC模式;bit3:CRC使能;
- //bit4:中斷MAX_RT(達(dá)到最大重發(fā)次數(shù)中斷)使能;bit5:中斷TX_DS使能;bit6:中斷RX_DR使能
- #define EN_AA 0x01 //使能自動(dòng)應(yīng)答功能 bit0~5,對(duì)應(yīng)通道0~5
- #define EN_RXADDR 0x02 //接收地址允許,bit0~5,對(duì)應(yīng)通道0~5
- #define SETUP_AW 0x03 //設(shè)置地址寬度(所有數(shù)據(jù)通道):bit1,0:00,3字節(jié);01,4字節(jié);02,5字節(jié);
- #define SETUP_RETR 0x04 //建立自動(dòng)重發(fā);bit3:0,自動(dòng)重發(fā)計(jì)數(shù)器;bit7:4,自動(dòng)重發(fā)延時(shí) 250*x+86us
- #define RF_CH 0x05 //RF通道,bit6:0,工作通道頻率;
- #define RF_SETUP 0x06 //RF寄存器;bit3:傳輸速率(0:1Mbps,1:2Mbps);bit2:1,發(fā)射功率;bit0:低噪聲放大器增益
- #define STATUS 0x07 //狀態(tài)寄存器;bit0:TX FIFO滿標(biāo)志;bit3:1,接收數(shù)據(jù)通道號(hào)(最大:6);bit4,達(dá)到最多次重發(fā)
- //bit5:數(shù)據(jù)發(fā)送完成中斷;bit6:接收數(shù)據(jù)中斷;
- #define MAX_TX 0x10 //達(dá)到最大發(fā)送次數(shù)中斷
- #define TX_OK 0x20 //TX發(fā)送完成中斷
- #define RX_OK 0x40 //接收到數(shù)據(jù)中斷
- #define OBSERVE_TX 0x08 //發(fā)送檢測(cè)寄存器,bit7:4,數(shù)據(jù)包丟失計(jì)數(shù)器;bit3:0,重發(fā)計(jì)數(shù)器
- #define CD 0x09 //載波檢測(cè)寄存器,bit0,載波檢測(cè);
- #define RX_ADDR_P0 0x0A //數(shù)據(jù)通道0接收地址,最大長(zhǎng)度5個(gè)字節(jié),低字節(jié)在前
- #define RX_ADDR_P1 0x0B //數(shù)據(jù)通道1接收地址,最大長(zhǎng)度5個(gè)字節(jié),低字節(jié)在前
- #define RX_ADDR_P2 0x0C //數(shù)據(jù)通道2接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
- #define RX_ADDR_P3 0x0D //數(shù)據(jù)通道3接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
- #define RX_ADDR_P4 0x0E //數(shù)據(jù)通道4接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
- #define RX_ADDR_P5 0x0F //數(shù)據(jù)通道5接收地址,最低字節(jié)可設(shè)置,高字節(jié),必須同RX_ADDR_P1[39:8]相等;
- #define TX_ADDR 0x10 //發(fā)送地址(低字節(jié)在前),ShockBurstTM模式下,RX_ADDR_P0與此地址相等
- #define RX_PW_P0 0x11 //接收數(shù)據(jù)通道0有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define RX_PW_P1 0x12 //接收數(shù)據(jù)通道1有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define RX_PW_P2 0x13 //接收數(shù)據(jù)通道2有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define RX_PW_P3 0x14 //接收數(shù)據(jù)通道3有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define RX_PW_P4 0x15 //接收數(shù)據(jù)通道4有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define RX_PW_P5 0x16 //接收數(shù)據(jù)通道5有效數(shù)據(jù)寬度(1~32字節(jié)),設(shè)置為0則非法
- #define NRF_FIFO_STATUS 0x17 //FIFO狀態(tài)寄存器;bit0,RX FIFO寄存器空標(biāo)志;bit1,RX FIFO滿標(biāo)志;bit2,3,保留
- //bit4,TX FIFO空標(biāo)志;bit5,TX FIFO滿標(biāo)志;bit6,1,循環(huán)發(fā)送上一數(shù)據(jù)包.0,不循環(huán);
- /* 函數(shù)聲明 ------------------------------------------------------------------*/
- void NRF24L01_RX_Mode(void); //配置為接收模式
- void NRF24L01_TX_Mode(void); //配置為發(fā)送模式
- uint8_t NRF24L01_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t uint8_ts);//寫(xiě)數(shù)據(jù)區(qū)
- uint8_t NRF24L01_Read_Buf(uint8_t reg, uint8_t *pBuf, uint8_t uint8_ts); //讀數(shù)據(jù)區(qū)
- uint8_t NRF24L01_Read_Reg(uint8_t reg); //讀寄存器
- uint8_t NRF24L01_Write_Reg(uint8_t reg, uint8_t value); //寫(xiě)寄存器
- uint8_t NRF24L01_Check(void); //檢查24L01是否存在
- uint8_t NRF24L01_TxPacket(uint8_t *txbuf); //發(fā)送一個(gè)包的數(shù)據(jù)
- uint8_t NRF24L01_RxPacket(uint8_t *rxbuf); //接收一個(gè)包的數(shù)據(jù)
- void NRF_LowPower_Mode(void);
- #endif
