仿真圖都正確,也能正常顯示,就是想弄成循環(huán)顯示的時(shí)候,OLED_ShowCHinese放if里面就無法正常顯示,放外面能顯示但是時(shí)間延遲較長(zhǎng),無法調(diào)整。有沒有大佬知道怎么回事的!
單片機(jī)源程序如下:
#include<reg51.h>
#include<intrins.h>
typedef unsigned int u16; //對(duì)系統(tǒng)默認(rèn)數(shù)據(jù)類型進(jìn)行重定義
typedef unsigned char u8;
sbit ds1 = P2^1;
sbit sh_cp1 = P2^0;
sbit st_cp1 = P2^2;
sbit ds2 = P2^6;
sbit sh_cp2 = P2^5;
sbit st_cp2 = P2^7;
sbit OE = P2^3;
sbit e = P2^4;
void Delay_ms(u16 ms)
u16 i,j;
for(i=ms;i>0;i--)
for(j=110;j>0;j--);
uchar code dat[][16] = {
{0x00,0x00,0x0F,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0x0F,0x00,0x00,0x00},
{0x00,0x00,0xF0,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0xF0,0x00,0x00,0x00},
{0x00,0x7F,0x40,0x48,0x49,0x49,0x49,0x4F,0x49,0x49,0x49,0x48,0x40,0x7F,0x00,0x00},
{0x00,0xFF,0x02,0x12,0x12,0x12,0x12,0xF2,0x12,0x52,0x32,0x12,0x02,0xFF,0x00,0x00},
{0x04,0x08,0x32,0xE2,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x2B,0x20,0x20,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x0C,0x02,0x0F,0x00},
{0x08,0x10,0x3E,0x52,0xD2,0x53,0x57,0x5A,0x52,0x52,0x72,0x12,0x1E,0x00,0x00,0x00},
{0x02,0x52,0x52,0x94,0xA4,0x28,0x4A,0x91,0x7E,0x20,0x50,0x88,0x04,0x02,0x02,0x00},
{0x10,0x12,0x11,0x10,0x13,0x1C,0x00,0x7F,0x40,0x40,0x4F,0x40,0x40,0x7F,0x00,0x00},
{0x04,0x08,0x30,0xC0,0x20,0x19,0x02,0xC4,0x18,0x60,0x80,0x7E,0x01,0xC1,0x07,0x00},
{0x02,0x02,0x42,0x42,0x42,0x42,0x43,0x42,0x42,0x42,0x42,0x42,0x42,0x02,0x02,0x00},
{0x00,0x04,0x0E,0x14,0x24,0xC4,0x04,0x04,0x04,0x24,0x14,0x0C,0x07,0x00,0x00,0x00},
{0x08,0x06,0x40,0x31,0x00,0x7F,0x40,0x4F,0x40,0x7F,0x00,0x1F,0x00,0xFF,0x00,0x00},
{0x20,0x20,0x7E,0x80,0x01,0xE2,0x0C,0xF0,0x08,0xE4,0x00,0xE2,0x01,0xFE,0x00,0x00},
{0x02,0x02,0x42,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x42,0x42,0x02,0x02,0x00},
{0x01,0x01,0x02,0x04,0x08,0x30,0xC0,0x00,0xC0,0x30,0x08,0x04,0x02,0x01,0x01,0x00},
void dat595(uchar as,uchar bs) //向HC595傳入數(shù)據(jù)
uchar i,b;
e = 1;
b = bs; //先寫第二個(gè)參數(shù),即取模的時(shí)候漢字字模的第二排數(shù)據(jù)(共16個(gè)),寫到16*16點(diǎn)陣的下面2個(gè)8*8點(diǎn)陣
for(i = 0; i < 8; i++)
ds1 = b & 0x01; //寫參數(shù)2的最低位
sh_cp1 = 0;
_nop_();_nop_();_nop_(); //空操作,
sh_cp1 = 1;
b >>= 1; //右移一位
b = as;
ds1 = b&0x01;
sh_cp1 = 0;
sh_cp1 = 1;
b >>= 1;
void shuchu() //HC595輸出數(shù)據(jù)
st_cp2 = 0;
st_cp1 = 0;
st_cp2 = 1; //在時(shí)鐘上升沿輸出數(shù)據(jù)
st_cp1 = 1; //在時(shí)鐘上升沿輸出數(shù)據(jù)
void suocun() //HC595鎖存數(shù)據(jù)
sh_cp2 = 0; //在時(shí)鐘上升沿寫入數(shù)據(jù)
sh_cp2 = 1;
ds2 = 1;
void OLED_ShowCHinese(uchar f)
uchar j;
OE = 0 ;
ds2= 0 ;
for(j =0; j < 16; j++)
dat595(dat[3*f+f][j],dat[3*f+f+1][j]);
suocun();
shuchu();
for(j = 0; j < 16; j++)
dat595(dat[3*f+f+2][j],dat[3*f+f+3][j]);
suocun();
shuchu();
void timer0_isr() interrupt 1
static uchar index = 0;
static uint cp2;
TH0=0XFC; //給定時(shí)器賦初值,定時(shí)1ms
TL0=0X18;
cp2++;
if(cp2 == 100)
cp2 =0;
index++;
if(index >=4)
index = 0;
}OLED_ShowCHinese(index);
void init_timer0()
TMOD|=0X01;//選擇為定時(shí)器0模式,工作方式1
TL0=0X18;
ET0=1;//打開定時(shí)器0中斷允許
EA=1;//打開總中斷
TR0=1;//打開定時(shí)器
void main(void)
init_timer0();
