查看: 1541|回復: 0
51單片機單人彈球游戲程序Proteus仿真圖分享
ID:1131956 發表于 2024-9-14 14:08 | 顯示全部樓層 |閱讀模式
#include <REGX52.H>
#include "Delay.h"
#include "MatrixLED.h"
#include "Timer0Init.h"
#include "StartGame.h"
#include "GAMEOVER.h"
#include "VICTORY.h"
sbit k2=P3^0;                //K2按鍵
sbit k1=P3^1;    //K1按鍵
int Place=3,numt=0,ball_LeftRight=1,ball_UpDown=1,Defeat=0,Victory=0,Score=0,start_flag=0;
unsigned char ball_position=0x80;
int racket[]={224,112,56,28,14,7};//用于表示球拍位置
//分別為1110 0000,0111 0000,0011 1000,0001 1100,0000 1110,0000 0111
void Gameinit()//游戲初始化
        Place=3;
        numt=0;
        ball_LeftRight=1;//球的左右移動方向
        ball_UpDown=1;//球的上下移動方向
        Defeat=0;//失敗標志
        Victory=0;//勝利標志
        Score=0;//分數
        start_flag=0;
        ball_position=0x80;//球在第8行
void Showpicture()//用于顯示點陣屏
    unsigned char k=1;
    MatrixLED_ShowColumn(0,racket[Place]);
                for(k=1;k<8;k++)
                        if(k!=7-numt)
                           MatrixLED_ShowColumn(k,0x00);
                                MatrixLED_ShowColumn(k,ball_position);
void Check()//判斷游戲勝利或失敗
        if(numt==6)//表示當球在第二列時
           if(ball_position==0x80)//如果球在最上方
                         if(Place!=0)//球拍位置不是1110 0000則游戲失敗
                         Defeat=1;
                 if(ball_position==0x20)
                         if((Place!=0)&&(Place!=1)&&(Place!=2))
                         Defeat=1;
                 if(ball_position==0x08)
                         if((Place!=2)&&(Place!=3)&&(Place!=4))
                         Defeat=1;
                 if(ball_position==0x02)
                         if((Place!=4)&&(Place!=5))
                         Defeat=1;
        if(Score==6)//如果分數達到6分
                Victory=1;        //游戲勝利
void BallMove()//球的移動
        Check();
        numt+=ball_LeftRight;
                ball_UpDown=1;
        if(ball_position==0x01)
                ball_UpDown=-1;
        if(ball_UpDown==1)
                ball_position=ball_position>>1;
        if(ball_UpDown==-1)
                ball_position=ball_position<<1;
  if(numt==0)
          ball_LeftRight=1;
                Score+=1;
        if(numt==6)
          ball_LeftRight=-1;
void MoveUP()//球拍上移
        Place-=1;
        if(Place<0)
                Place=0;
void MoveDOWN()//球拍下移
        Place+=1;
        if(Place>5)
                Place=5;
        MatrixLED_Init();
     while(start_flag==0)                        //如果K1按鍵按下
                    StartGame(start_flag);
                    start_flag=1;
           Timer0Init();
           while((Defeat==0)&&(Victory==0))
                    Showpicture();
                    if(k1==0)                        //如果K1按鍵按下
                             Delay(20);
                             while(k1==0);
                             Delay(20);
                                        MoveUP();//拍子上移
                    if(k2==0)                        //如果K2按鍵按下
                             Delay(20);
                             while(k2==0);
                             Delay(20);
           MoveDOWN();//拍子下移
           if (Defeat==1)//如果游戲失敗
        TR0=0;
                    GAMEOVER(Score);
        Gameinit();
           if (Victory==1)//如果游戲勝利
        TR0=0;
                    VICTORY(Score);
        Gameinit();
void Timer0() interrupt 1//定時器中斷程序
        static unsigned int T0Count;
        TL0 = 0x18;                //設置定時初值
        TH0 = 0xFC;                //設置定時初值
        T0Count++;
        if((T0Count>=300)&&(k1==1)&&(k2==1))        //定時器分頻,300ms
                T0Count=0;
    BallMove();//每300ms球移動一次
仿真程序: Simulation.7z (48.94 KB, 下載次數: 7)
