查看: 1153|回復: 0
基于stc89c52單片機的小車直線行駛源碼
ID:1130376 發表于 2024-8-9 22:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
小車使用PWM調節頻率使得能夠進行直線行駛并且可以采用藍牙進行調控
  1. #include <REGX52.H>
  2. sbit IN1 = P1^1;
  3. sbit IN2 = P1^2;
  4. sbit IN3 = P1^3;
  5. sbit IN4 = P1^4;
  6. sbit ENA = P1^0;
  7. sbit ENB = P1^5;
  8. sbit LED1 = P1^6;
  9. unsigned char counter,compare = 0;
  10. void car_go()
  11. {
  12.         IN1 = 1;
  13.         IN2 = 0;
  14.         IN3 = 0;
  15.         IN4 = 1;
  16. }
  17. void Timer0_Init()                //100微秒@11.0592MHz
  18. {
  19.         TMOD &= 0xF0;                        //設置定時器模式
  20.         TMOD |= 0X01;           //設置定時器模式
  21.         TL0 = 0xA4;                                //設置定時初始值
  22.         TH0 = 0xFF;                                //設置定時初始值
  23.         TF0 = 0;                                //清除TF0標志
  24.         TR0 = 1;                                //定時器0開始計時
  25.         ET0 = 1;
  26.         EA = 1;
  27.         PT0 = 0;
  28. }
  29. void Timer_Init() interrupt 1
  30. {
  31.         TL0 = 0xA4;                                //設置定時初始值
  32.         TH0 = 0xFF;                                //設置定時初始值
  33.
  34.         counter = 32;
  35.         compare ++ ;
  36.
  37.         if(compare <= counter)
  38.         {
  39.                 IN1 = 0;
  40.                 IN2 = 1;
  41.         }
  42.         else
  43.         {
  44.                 IN1 = 1;
  45.                 IN2 = 0;
  46.         }
  47.         if(compare == 100)
  48.         {
  49.                 compare = 0;
  50.         }
  51. }
  52. void main()
  53. {
  54.         Timer0_Init();
  55.
  56.         ENA = 1;
  57.         ENB = 1;
  58.
  59.         while(1)
  60.         {
  61.                 car_go();
  62.         }
  63. }
