查看: 1333|回復: 7
stm32串口DMA問題
ID:929517 發表于 2024-7-14 16:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
最近在學習串口的DMA接收,發現一個問題,就是RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); 這條時鐘無論是否開啟,都能正常接收,有沒有高手能解釋下這條語句。具體程序我壓縮包上傳,經過測試串口助手是可以發送并將收到的信息發回。請大師們指正,這個工程未完工,階段測試可以。
void Serial_Init(void)
  USART_InitTypeDef USART_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  DMA_InitTypeDef DMA_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
//  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);// ???
  USART_DeInit(USART1);  //復位串口1
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//搶占優先級3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子優先級3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根據指定的參數初始化VIC寄存器
  //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_Init(USART1, &USART_InitStructure); //初始化串口
  USART_ITConfig(USART1, USART_IT_IDLE, ENABLE);//開啟空閑中斷
  USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);   //使能串口1 DMA接收
  USART_Cmd(USART1,ENABLE);                    //使能串口
  DMA_DeInit(DMA1_Channel5);   //將DMA的通道5寄存器重設為缺省值  串口1對應的是DMA通道5
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USART1->DR;  //DMA外設ADC基地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)DMA_RX_Buf;  //DMA內存基地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //數據傳輸方向,從外設讀取發送到內存
  DMA_InitStructure.DMA_BufferSize = DMA_Max_Size;  //DMA通道的DMA緩存的大小
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外設地址寄存器不變
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //內存地址寄存器遞增
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //數據寬度為8位
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //數據寬度為8位
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常緩存模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x擁有中優先級
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x沒有設置為內存到內存傳輸
  DMA_Init(DMA1_Channel5, &DMA_InitStructure);  //根據DMA_InitStruct中指定的參數初始化DMA的通道
  USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
  DMA_Cmd(DMA1_Channel5, ENABLE);  //正式驅動DMA傳輸
未完工的DMA.zip
323.42 KB, 下載次數: 2
ID:267719 發表于 2024-7-16 15:13 | 只看該作者
引腳復用 進行重映射時 需要開啟AFIO 時鐘。你沒有remap,所以沒有必要開啟。
ID:929517 發表于 2024-7-16 15:42 | 只看該作者
carpcarey 發表于 2024-7-16 15:13
PA9 PA10用作串口 不算引腳復用嗎?
ID:267719 發表于 2024-7-18 10:04 | 只看該作者
reking8 發表于 2024-7-16 15:42
沒有重新映射,沒有用到remap
ID:267719 發表于 2024-7-18 10:25 | 只看該作者
當把 GPIO 用作 EXTI 外部中斷或使用重映射功能的時候,必須開啟 AFIO 時鐘,而在使用默認復用功能的時候,就不必開啟 AFIO 時鐘了。
ID:267719 發表于 2024-7-18 10:53 | 只看該作者
當把 GPIO 用作 EXTI 外部中斷或使用重映射功能的時候,必須開啟 AFIO 時鐘,而在使用默認復用功能的時候,就不必開啟 AFIO 時鐘了。PA9 PA10用作串口算默認復用功能,所以不必開啟AFIO 時鐘。
ID:1043262 發表于 2024-7-18 12:09 | 只看該作者
那個引腳IO本來就有串口的功能,AFIO一般用于引腳復用的,我個人是這么理解的
ID:929517 發表于 2024-7-18 15:27 | 只看該作者
懂了 謝謝
