查看: 1309|回復: 0
msp432p401r單片機adc+dma 問題提問
ID:1128952 發表于 2024-7-14 14:19 | 顯示全部樓層 |閱讀模式
提問:
近期,我在學習msp432p401r單片機時,想用msp的adc進行多通道采集,然后加上dma數據轉運。以下是代碼起初我是直接用的dma里的adc通道,發現不行。然后我就仿照官方例程里的進行數組到數組間的轉運 resultsBuffer -->adc 的轉運,結果還是失敗了
在主函數里我就是顯示了一下數組里的值,發現程序卡死。希望能得到大佬的幫助。
#include "headfile.h"
#include "adc.h"
#include "ml_oled.h"
//左到右 4.3   4.4   4.5   4.6   4.7
//                  10        9          8            7          6
uint16_t adc[5];
uint16_t resultsBuffer[5];
void ADC_config(void)
        /* 啟用浮點運算的FPU */
    MAP_FPU_enableModule();
    MAP_FPU_enableLazyStacking();
    /* Initializing ADC (MCLK/1/1) */
    MAP_ADC14_enableModule();        //使能ADC14模塊
    MAP_ADC14_initModule(ADC_CLOCKSOURCE_MCLK, ADC_PREDIVIDER_4, ADC_DIVIDER_5, ADC_NOROUTE); //初始化ADC 時鐘 分頻  通道 2.4MHz
    MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P4, GPIO_PIN5 | GPIO_PIN6 | GPIO_PIN7| GPIO_PIN3| GPIO_PIN4, GPIO_TERTIARY_MODULE_FUNCTION);
//        MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P5, GPIO_PIN1 | GPIO_PIN2, GPIO_TERTIARY_MODULE_FUNCTION);                //
    MAP_ADC14_configureMultiSequenceMode(ADC_MEM6, ADC_MEM10, true);
        MAP_ADC14_configureConversionMemory(ADC_MEM6, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A6, ADC_NONDIFFERENTIAL_INPUTS);
    MAP_ADC14_configureConversionMemory(ADC_MEM7, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A7, ADC_NONDIFFERENTIAL_INPUTS);
        MAP_ADC14_configureConversionMemory(ADC_MEM8, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A8, ADC_NONDIFFERENTIAL_INPUTS);
        MAP_ADC14_configureConversionMemory(ADC_MEM9, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A9, ADC_NONDIFFERENTIAL_INPUTS);
        MAP_ADC14_configureConversionMemory(ADC_MEM10, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A10, ADC_NONDIFFERENTIAL_INPUTS);
    ADC14_enableInterrupt(ADC_INT10);
    /* Enabling Interrupts */
    MAP_Interrupt_enableInterrupt(INT_ADC14); //ADC模塊的中斷
    MAP_Interrupt_enableMaster();
    /* Setting up the sample timer to automatically step through the sequence
     * convert.
    ADC14_enableSampleTimer(ADC_AUTOMATIC_ITERATION);
    /* Triggering the start of the sample */
    MAP_ADC14_enableConversion();        //使能開始轉換(觸發后 自動ADC上電)
    MAP_ADC14_toggleConversionTrigger(); //開啟第一次軟件觸發
////////////////////DMA配置///////////////////////////////
/* DMA Control Table  這一段是必須要有的*///
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN(controlTable, 1024)
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment = 1024
#elif defined(__GNUC__)
__attribute__((aligned(1024)))
#elif defined(__CC_ARM)
__align(1024)
#endif
uint8_t controlTable[1024];
#define DAM_SIZE 1024
uint16_t data_array1[DAM_SIZE]; // DMA數組
void DMA_config(void)
    MAP_WDT_A_holdTimer(); // 關閉看門狗
    memset(data_array1, 0x11, DAM_SIZE); // 目標數組初始化
    DMA_enableModule();               // 使能DMA模塊
    DMA_setControlBase(controlTable); // 設置控制表基地址
    DMA_disableChannelAttribute(DMA_CH0_RESERVED0,
                                UDMA_ATTR_ALTSELECT | UDMA_ATTR_USEBURST |
                                    UDMA_ATTR_HIGH_PRIORITY |
                                    UDMA_ATTR_REQMASK); // 禁用通道特征
    DMA_setChannelControl(UDMA_PRI_SELECT | DMA_CH0_RESERVED0, UDMA_SIZE_16 | UDMA_SRC_INC_16 | UDMA_DST_INC_16 | UDMA_ARB_1);
    // 設置通道控制參數                   ADC映射        主數據結構     16位數據大小            源地址增量        目標地址增量      仲裁大小
    DMA_setChannelTransfer(UDMA_PRI_SELECT | DMA_CH0_RESERVED0, UDMA_MODE_AUTO, resultsBuffer, adc, 5);
    // 設置通道傳輸參數               ADC映射        主數據結構         自動模式                        源數據            目標數據    傳輸數量
    MAP_Interrupt_disableSleepOnIsrExit();
    DMA_requestChannel(0);
//    DMA_assignChannel(DMA_CH0_RESERVED0); // 指定外設映射
    DMA_assignInterrupt(DMA_INT0, 0);
    Interrupt_enableInterrupt(INT_DMA_INT0);
    DMA_clearInterruptFlag(0);
    DMA_enableChannel(0);
    DMA_requestSoftwareTransfer(0); //
void DMA_INT1_IRQHandler(void)
    /* Switch between primary and alternate bufferes with DMA's PingPong mode */
                               adc, 5);
void ADC14_IRQHandler(void)
    uint_fast64_t status = MAP_ADC14_getEnabledInterruptStatus();
    MAP_ADC14_clearInterruptFlag(status);
    if (ADC_INT10 & status)
        MAP_ADC14_getMultiSequenceResult(resultsBuffer);
