查看: 2565|回復: 13
請教一下,為什么我的單片機ADC_DMA進不了中斷
ID:298743 發表于 2024-7-12 13:47 | 顯示全部樓層 |閱讀模式
#include "stc8h.h"
#include "eeprom.h"
#include "stdio.h"
#include "intrins.h"
typedef         unsigned char        u8;
typedef         unsigned int        u16;
typedef         unsigned long        u32;
/*************        ±¾µØ³£Á¿ÉùÃ÷        **************/
//1~16,使用的ADC轉換通道數量,必須和[ADC_DMA通道使能寄存器(DMA_ADC_CHSWx)]中啟用的ADC通道數量一致
#define ADC_CH_NUM          1
//ADC轉換次數,必須和[ADC_DMA配置寄存器2(DMA_ADC_CFG2)]設置的一致
#define ADC_SAMPLES_NUM     8
//每個通道ADC轉換數據總字節數=2*轉換次數+4
#define ADC_DATA_SIZE       (ADC_SAMPLES_NUM*2 + 4)
//存儲ADC DMA轉換結果,即ADC DMA的目的地址
u8 xdata adc_samples_buff[ADC_CH_NUM][ADC_DATA_SIZE];
//ADC DMA轉換完成標志
bit DmaFlag;
void Uart1_Init(void);        //4800bps@11.0592MHz
void sendByte(char dat);
void sendString(unsigned char *dat);
char putchar(char c);
void adc_dma_config(void);
void Delay500ms(void);        //@11.0592MHz
void ADC_Init(void);
   u8 i,j;
   u16 adc_value;
   float voltage;
   Uart1_Init();
   ADC_Init();
   EA = 1;
   printf("Hello");
           if(DmaFlag)
                      DmaFlag = 0;
                      adc_value=(adc_samples_buff[0][16]<<8)+adc_samples_buff[0][17];
                      voltage   = (5*adc_value)/4096;
                       printf("voltage: %.2fV\r\n",voltage);
                     DMA_ADC_CR = 0xC0;
           Delay500ms();
   P_SW2 = 0x80;
   DMA_ADC_STA = 0x00;         //清零ADC DMA狀態寄存器
   DMA_ADC_CFG = 0x80;         //開啟ADC DMA中斷
   DMA_ADC_RXAH = (u8)((u16)(&adc_samples_buff) >> 8); //ADC轉換數據存儲地址,即ADC DMA目的地址
   DMA_ADC_RXAL = (u8)((u16)(&adc_samples_buff));
   DMA_ADC_CFG2 = 0x0A;    //每個通道ADC轉換次數:8
   DMA_ADC_CHSW0 = 0x01;   //使能ADC通道1
   DMA_ADC_CHSW1 = 0x00;
   DMA_ADC_CR = 0xC0;      //啟動ADC DMA轉換
void ADC_Init(void)
        P1M0=0x00;                 //設置P10為高阻輸入
        P1M1=0x01;
           ADCTIM = 0x3F;                  //設置ADC內部時許
        ADCCFG = 0x2F;                  //設置ADC時鐘為系統時鐘,數據右對齊
        ADC_CONTR = 0x80;    //使能ADC模塊
void Uart1_Init(void)        //4800bps@11.0592MHz
        PCON &= 0x7F;                //波特率不倍速
        SCON = 0x50;                //8位數據位,可變波特率
        AUXR &= 0xBF;                //定時器時鐘12T模式
        AUXR &= 0xFE;                //串口1選擇定時器1為波特率發生器
        TMOD &= 0x0F;
        TMOD |= 0x20;
        TL1 = 0xFA;
        TH1 = 0xFA;
        ET1 = 0;
        TR1 = 1;
        SBUF = dat;
        while(!TI);
        TI = 0;
        while(*dat != '\0')
                sendByte(*dat++);
        sendByte(c);
        return c;
void ADC_DMA_Interrupt(void) interrupt 13
        DMA_ADC_STA = 0;
        DmaFlag = 1;
void Delay500ms(void)        //@11.0592MHz
        unsigned char data i, j, k;
        _nop_();
        _nop_();
        i = 22;
        j = 3;
        k = 227;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
ID:1034262 發表于 2024-7-12 17:40 | 顯示全部樓層
試試STC官方的例子:
STC8H系列-ADC相關程序.rar (918.47 KB, 下載次數: 3)
ID:1109793 發表于 2024-7-12 17:49 | 顯示全部樓層
8G和8H的ADC中斷向量號好像是5吧,我看工具里面的示例里面的是5
void ADC_Isr() interrupt 5
    ADC_CONTR &= ~0x20;                         //清中斷標志
    P2 = ADC_RES;                               //讀取ADC結果
    ADC_CONTR |= 0x40;                          //繼續AD轉換
ID:624769 發表于 2024-7-13 13:04 | 顯示全部樓層
看你你中斷號用的 13
那么……, 你 LJMP 那段匯編 寫了沒有?
并且,是否用的 .A51 格式? 是否正確插入了項目?
ID:298743 發表于 2024-7-14 14:44 | 顯示全部樓層
xiaobendan001 發表于 2024-7-12 17:49
STC的官方程序寫的是13
ID:298743 發表于 2024-7-14 14:46 | 顯示全部樓層
188610329 發表于 2024-7-13 13:04
看你你中斷號用的 13
并且,是否用的 .A51 格式? 是否正確插入 ...
這個"stc8h.h"這個頭文件沒有嗎?我程序里還有中斷12 開的定時器2也能正常工作
ID:1109793 發表于 2024-7-14 15:00 | 顯示全部樓層
asdadqw2 發表于 2024-7-14 14:44
STC的官方程序寫的是13
改成5試試啊,你的官方歷程截圖看看吧
ID:161164 發表于 2024-7-14 17:36 | 顯示全部樓層
STC的官方程序寫的是13
例程是13沒錯,但還要加中斷號48跳到13的附加操作
ID:1109793 發表于 2024-7-14 20:07 | 顯示全部樓層
lkc8210 發表于 2024-7-14 17:36
那是處理大于31號的手段。ADC的就是5,又不大于31,為何要借用13號?13號就是保留的,讓編譯器把服務代碼放到13號的位置,然后在不如32號的位置人為添加LJMP跳轉到13號。借用其他不使用的也一樣啊。但是ADC的就是5號,直接用就行了啊,不懂為何要借用,然后還得添加匯編代碼。這不是那啥?
ID:624769 發表于 2024-7-14 20:31 | 顯示全部樓層
asdadqw2 發表于 2024-7-14 14:46
你如果看得是官方例程,你繼續往下翻,應該會有類似這樣的代碼:
ISR.ASM
CSEG  AT  0183H
LJMP  0063H
END
你把他做成 ASM 文件 加入到項目里才可以。
ID:161164 發表于 2024-7-14 22:19 | 顯示全部樓層
xiaobendan001 發表于 2024-7-14 20:07
那是處理大于31號的手段。ADC的就是5,又不大于31,為何要借用13號?13號就是保留的,讓編譯器把服務代碼 ...
因為他用的是DMA_ADC,而不是單純的ADC
ID:1109793 發表于 2024-7-15 07:28 | 顯示全部樓層
lkc8210 發表于 2024-7-14 22:19
哦,沒用過H的,剛下載了PDF看了下是48號,話說DMA有啥好處?還要借用跳轉。直接用ADC中斷不行?
ID:161164 發表于 2024-7-16 16:09 | 顯示全部樓層
xiaobendan001 發表于 2024-7-15 07:28
不用頻繁進中斷
ID:1109793 發表于 2024-7-16 18:23 | 顯示全部樓層
lkc8210 發表于 2024-7-16 16:09
不用頻繁進中斷
意思是時不時的關掉48號?DMA中斷也是中斷啊。5號也可以時不時 的關閉一下吧。
