查看: 1228|回復(fù): 1
基于STM32單片機的仿真電機+3X3矩陣程序
ID:316613 發(fā)表于 2024-6-20 15:27 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "stm32f10x.h"                  // Device header
#include "Delay.h"
#include "1602.h"
#include "stdio.h"
#include "Matrix.h"
#include "Nixie.h"
#include "Motor.h"
#include "PWM.h"
#include "Encoder.h"
#include "Timer.h"
uint8_t MatrixNum=0;
uint32_t x=0;
int main(void)
        LCD1602_Init();
        Matrix_Init();
        Nixie_Init();
        Motor_Init();
        PWM_Init();
        Encoder_Init();
        LCD1602_GPIO_Configuration();
        LCD1602_Init();
        unsigned char str[64];
        unsigned char str_1[64]="R";
        unsigned char str_2[64]="F";
        while (1)
                switch (scan_key())
        case 1:
                sprintf((char *)str,"Number:%4dcm",1);
                LCD1602_Show_Str(1, 1, (u8 *)str);
                Select(1);
                NixiesetNum(1);
                break;
        case 2:
                sprintf((char *)str,"Number:%4dcm",2);
                Select(1);
                NixiesetNum(2);
                break;
        case 3:
                sprintf((char *)str,"Number:%4dcm",3);
                Select(1);
                NixiesetNum(3);
                break;
        case 4:
                sprintf((char *)str,"Number:%4dcm",4);
                Select(1);
                NixiesetNum(4);
                break;
        case 5:
                sprintf((char *)str,"Number:%4dcm",5);
                Select(1);
                NixiesetNum(5);
                break;
        case 6:
                sprintf((char *)str,"Number:%4dcm",6);
                Select(1);
                NixiesetNum(6);
                break;
        case 7:
                sprintf((char *)str,"Number:%4dcm",7);
                Select(1);
                NixiesetNum(7);
                break;
        case 8:
                sprintf((char *)str,"Number:%4dcm",8);
                Select(1);
                NixiesetNum(8);
                break;
        case 9:
                sprintf((char *)str,"Number:%4dcm",9);
                Select(1);
                NixiesetNum(9);
                break;
                default:break;
        Delay_ms(1000);
        Motor_Set_Stop();
        Select(2);
        NixiesetNum(0);
        Delay_ms(2000);
        Motor_SetSpeed_Left(1);//正轉(zhuǎn)
        Select(2);
        NixiesetNum(1);
        sprintf((char *)str,"Speed:%4dcm",Encoder_Get_1());
        LCD1602_Show_Str(1, 1, (u8 *)str_1);
        LCD1602_Show_Str(2, 1, (u8 *)str);
        Delay_ms(1000);
        Motor_SetSpeed_Left(2);//反轉(zhuǎn)
        Select(2);
        NixiesetNum(1);
        LCD1602_Show_Str(1, 1, (u8 *)str_2);
        Delay_ms(1000);
仿真程序: 基于STM32的仿真電機 3X3矩陣.7z (242.96 KB, 下載次數(shù): 9)
收藏收藏1 分享淘帖 頂 踩1
ID:608162 發(fā)表于 2025-1-3 02:41 | 只看該作者
代碼不行,運行不了
