查看: 1402|回復: 1
arduino編譯esp32WiFiscan示例編譯失敗求助
ID:1070351 發(fā)表于 2024-6-2 11:09 | 顯示全部樓層 |閱讀模式
E:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino\hardware -hardware C:\Users\10169\AppData\Local\Arduino15\packages -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -tools C:\Users\10169\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino\libraries -libraries C:\Users\10169\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\10169\AppData\Local\Temp\arduino_build_548755 -warnings=none -build-cache C:\Users\10169\AppData\Local\Temp\arduino_cache_269250 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd-esp32.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230921.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.dfu-util.path=C:\Users\10169\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\10169\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.mkspiffs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-442a798083.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp-rv32.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.esptool_py.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -verbose C:\Users\10169\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\WiFi\examples\WiFiScan\WiFiScan.ino
E:\Arduino\arduino-builder -compile -logger=machine -hardware E:\Arduino\hardware -hardware C:\Users\10169\AppData\Local\Arduino15\packages -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -tools C:\Users\10169\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino\libraries -libraries C:\Users\10169\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\10169\AppData\Local\Temp\arduino_build_548755 -warnings=none -build-cache C:\Users\10169\AppData\Local\Temp\arduino_cache_269250 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd-esp32.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230921.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.dfu-util.path=C:\Users\10169\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\10169\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.mkspiffs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-442a798083.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp-rv32.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-12.2.0_20230208.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.esptool_py.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\10169\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -verbose C:\Users\10169\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\WiFi\examples\WiFiScan\WiFiScan.ino
Using board 'esp32' from platform in folder: C:\Users\10169\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0
Using core 'esp32' from platform in folder: C:\Users\10169\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0
cmd /c if exist "C:\\Users\\10169\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0\\libraries\\WiFi\\examples\\WiFiScan\\partitions.csv" COPY /y "C:\\Users\\10169\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0\\libraries\\WiFi\\examples\\WiFiScan\\partitions.csv" "C:\\Users\\10169\\AppData\\Local\\Temp\\arduino_build_548755\\partitions.csv"
������ʾ���ѱ�ϵͳ����Աͣ�á�
�밴���������. . .
exit status 255
E:\Arduino\arduino-builder 返回 255
為開發(fā)板 ESP32 Dev Module 編譯時出錯。
ID:1070351 發(fā)表于 2024-6-4 09:26 | 顯示全部樓層
已經(jīng)解決了,在準備用VScode+espidf的時候發(fā)現(xiàn)命令提示符被僅用了,解除禁用之后,稀里糊涂就可以編譯成功了
