查看: 1751|回復: 8
計時器程序增加控制應該怎么寫
ID:72649 發表于 2024-5-21 06:58 | 顯示全部樓層 |閱讀模式
//99分計時器,需要用按鍵開關P3.2控制計時器啟動,按下按鍵啟動,松開按鍵停止倒計時,2秒后熄滅數碼管,重新按下按鍵,從0開始重新計時,需要怎么增加?給點思路。
#include"stc8.h"
#include "intrins.h"
#define  uint unsigned int
#define  uchar unsigned char
sbit ge = P3^7;
sbit shi = P3^6;
sbit KEY = P3^2;
uchar count;
char sec,min;
bit flag;
uchar code table[]={0x12,0x3F,0x94,0x1C,0x39,0x58,0x50,0x1F,0x10,0x18,0x11,0x70,0xD2,0x34,0xD0,0xD1};
//uchar code table[]={
//0x03,0x9F,0x25,0x0D,0x99,0x49,0x41,0x1F,0x01,0x09,
//0x11,0xC1,0x63,0x85,0x61,0x71};    //0-9,a-f
sbit c = P1^7;
sbit b = P1^6;
sbit a = P1^5;
sbit h = P1^4;
sbit e = P1^3;
sbit f = P1^2;
sbit g = P1^1;
sbit d = P1^0;
void IO_init();
void delay(uchar n);
void T0_init();
void display();
void IO_init()
    P3M0 = 0xc0; P3M1 = 0x00;
    P1M0 = 0xff; P1M1 = 0x00;
void delay(uchar n)
        uchar j,k;
        for(j=n;j>0;j--)
                for(k=125;k>0;k--);
void T0_init()                                //5毫秒@11.0592MHz
        AUXR &= 0x7F;                        //定時器時鐘12T模式
        TMOD &= 0xF0;                        //設置定時器模式
        TMOD |= 0x01;                        //設置定時器模式
        TL0 = 0x00;                                //設置定時初始值
        TH0 = 0xEE;                                //設置定時初始值
        TF0 = 0;                                //清除TF0標志
//        TR0 = 1;                                //定時器0開始計時
        ET0 = 1;                                //使能定時器0中斷
        EA = 1;
void display()
        static bit i=0;
        static uchar temp=0;
        P1=0;
        i=~i;
        if(++temp>=200)temp=0;
        if(i==1)
                ge  = 1;
                shi = 0;
                P1=table[sec/10];
                ge  = 0;
                shi = 1;
//                if(temp<100)
                 P1=table[sec%10] ;  //&0xcf;//閃秒   1110  1111
//                else P1=table[min%10];
        IO_init();
        T0_init();
        { if(!KEY)
                   TR0=1;
                                        if(flag)
                        flag=0;
                        if(++count >= 200)
                                count = 0;
                                sec++;
                                if(sec >99)
                                        sec = 0;
                        display();
void TM0_Isr() interrupt 1 //5毫秒
//         if(!KEY)
//                                                 delay(20);
//          if(!KEY)
//            while(!KEY);
        flag=1;
ID:72649 發表于 2024-5-21 15:08 | 顯示全部樓層
//99s倒計時
#include"stc8.h"
sbit ge = P3^7;
sbit shi = P3^6;
sbit KEY = P3^2;
uchar count;
char sec,min;
bit flag;
sbit c = P1^7;
sbit b = P1^6;
sbit a = P1^5;
sbit h = P1^4;
sbit e = P1^3;
sbit f = P1^2;
sbit g = P1^1;
sbit d = P1^0;
void IO_init();
void T0_init();
void display();
void IO_init()
    P3M0 = 0x00; P3M1 = 0x00;
    P1M0 = 0x00; P1M1 = 0x00;
void delay(uint n)
        uchar j,k;
        for(j=n;j>0;j--)
                for(k=125;k>0;k--);
        TF0 = 0;                                //清除TF0標志
        ET0 = 1;                                //使能定時器0中斷
        EA = 1;
void display()
        static bit i=0;
        P1=0;
        i=~i;
        if(i==1)
                ge  = 1;
                shi = 0;
                P1=table[sec/10];
                ge  = 0;
                shi = 1;
//                if(temp<100)
        IO_init();
        T0_init();
                                                 if(!KEY)
                                                        TR0=1;
                                           if(flag)
                        flag=0;
                        if(++count >= 200)
                                count = 0;
                                sec++;
                                if(sec >99)
                                  sec = 0;
                        display();
        flag=1;
}這樣按鍵按下計數開始,現在我要求按下計數,松開停止并熄滅,下次按下從0開始計數。
ID:624769 發表于 2024-5-21 18:49 | 顯示全部樓層
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
ID:161164 發表于 2024-5-22 10:19 | 顯示全部樓層
ID:72649 發表于 2024-5-22 20:58 來自觸屏版 | 顯示全部樓層
188610329 發表于 2024-5-21 18:49
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
TR0關閉了,顯示要延時10秒熄滅怎么修改?
ID:72649 發表于 2024-5-22 21:31 | 顯示全部樓層
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
要求:
1持續觸發計時開始,觸發發斷開計時停止,保持計時停止的數值10秒。然后數碼管熄滅。
2,在數碼管保持上一次計時的10秒鐘內,重新觸發,計時馬上重新開始,觸發結束計時保持10秒,然后熄滅
3,數碼管熄滅后.重新觸發計時,馬上點亮數碼從0開始計時同上。
ID:72649 發表于 2024-5-22 21:32 | 顯示全部樓層
按照你的修改不能計時了。
要求:
ID:74687 發表于 2024-5-23 06:47 | 顯示全部樓層
你現在按下應該能正常計時了,就是松開再按下,不能從0開始?
在if(!key)后面加個
else{
   if(flag){
              flag =0;
              if(count >200){
                  count = 0;
                  clear_sec++;
                 if(clear_sec > 2){
                       sec =0;
                      TR0 = 0;
大體就是這個思路,把括號補齊。
ID:161164 發表于 2024-5-23 11:38 | 顯示全部樓層
hjx5548 發表于 2024-5-22 21:32
按照你的修改不能計時了。
要求:
1持續觸發計時開始,觸發發斷開計時停止,保持計時停止的數值10秒。 ...
把改好的代碼發出來啊
