查看: 2151|回復: 0
用esp32-cam向巴法云發送圖片,同時小程序獲取
  1. #include <WiFi.h>
  2. #include <WiFiClient.h>
  3. #include <ArduinoJson.h>
  4. #include <HTTPClient.h>
  5. #include <EEPROM.h>
  6. #include <Ticker.h>
  7. #include "DHT.h" //加載DHT11的庫
  8. #include "esp_http_client.h"
  9. #include "esp_camera.h"
  10. #include "configuration.h"
  11. #include "camera_pins.h"
  12. char config_flag = 0;   //配網成功標識
  13. //tcp客戶端相關
  14. String TcpClient_Buff = "";
  15. unsigned int TcpClient_BuffIndex = 0;
  16. unsigned long TcpClient_preTick = 0;
  17. unsigned long preHeartTick = 0;//心跳
  18. unsigned long preTCPStartTick = 0;//連接
  19. String over_int = "false";
  20. bool preTCPConnected = false;
  21. String UID = "c124bafd03ba4909b1f7794c3e38af32";    //巴法云私鑰
  22. String TOPIC = "mytrash";   //主題名字
  23. //圖像拍照上傳相關
  24. int capture_interval = 5 * 1000;                       // 20秒上傳一次
  25. const char* uid = "c124bafd03ba4909b1f7794c3e38af32";  //私鑰
  26. const char* topic = "mytrash";                       //主題
  27. const char* wechatMsg = "";                            //如果不為空,會推送到
  28. const char* wecomMsg = "";                             //如果不為空,會推送到企業,推送到企業的消息
  29. const char* urlPath = "";                              //如果不為空,會生成自定義圖片鏈接,自定義圖片上傳后返回的圖片url,url前一部分為巴法云域名,第二部分:私鑰+主題名的md5值,第三部分為設置的圖片鏈接值。
  30. bool flashRequired = true;                            //閃光燈,true是打開閃光燈
  31. const int brightLED = 4;                               //閃光燈引腳
  32. const int sensorPin = 14; // 溢出檢測引腳
  33. unsigned char sendp = 0;
  34. int sensorValue = 0;
  35. int connect_time = 0;
  36. const char* post_url = "imagesbemfa/upload/v1/upimages.php";  // 默認上傳地址
  37. static String httpResponseString;                                         //接收服務器返回信息
  38. bool internet_connected = false;
  39. long current_millis;
  40. long last_capture_millis = 0;
  41. // Bright LED (Flash)
  42. const int ledFreq = 50;        // PWM settings
  43. const int ledChannel = 15;     // camera uses timer1
  44. const int ledRresolution = 8;  // resolution (8 = from 0 to 255)
  45. struct config_type
  46. {
  47.   char stassid[32];
  48.   char stapsw[64];
  49.    char cuid[40];
  50.    char ctopic[32];
  51.   uint8_t reboot;
  52.   uint8_t magic;
  53. };
  54. config_type config;
  55. WiFiClient TCPclient;
  56. Ticker delayTimer;
  57. DHT dht(DHTPIN, DHTTYPE);//聲明 dht 函數
  58. /**
  59. * 存儲配網信息
  60. */
  61. void saveConfig()
  62. {
  63.   int rand_key;
  64.   uint8_t mac[6];
  65.   WiFi.macAddress(mac);
  66.   config.reboot = 0;
  67.   EEPROM.begin(512);
  68.   uint8_t *p = (uint8_t*)(&config);
  69.   for (int i = 0; i < sizeof(config); i++)
  70.   {
  71.     EEPROM.write(i, *(p + i));
  72.   }
  73.   EEPROM.commit();
  74. }
  75. void delayRestart(float t)
  76. {
  77.   delayTimer.attach(t, []()
  78.   {
  79.     ESP.restart();
  80.   });
  81. }
  82. /**
  83. * airkiss配網
  84. */
  85. void doSmartconfig()
  86. {
  87.   Serial.println("waiting for WeChat Config.....");
  88.   Serial.print("*");
  89.   Serial.print("*");
  90.   Serial.print("*");
  91.   Serial.print("*");
  92.   Serial.print("*");
  93.   Serial.println("*");
  94.   WiFi.mode(WIFI_STA);
  95.   WiFi.stopSmartConfig();
  96.   WiFi.beginSmartConfig();
  97.   int cnt = 0;
  98.   bool flag_ok = false;
  99.   while (!WiFi.smartConfigDone())
  100.   {
  101.     delay(300);
  102.     if (flag_ok == true) continue;
  103.     if (WiFi.smartConfigDone())
  104.     {
  105.         strcpy(config.stassid, WiFi.SSID().c_str());
  106.         strcpy(config.stapsw, WiFi.psk().c_str());
  107.         config.magic = MAGIC_NUMBER;
  108.         saveConfig();
  109.         flag_ok = true;
  110.     }
  111.     cnt++;
  112.     if (cnt >= 600)
  113.     {
  114.       delayRestart(0);
  115.     }
  116.   }
  117. }
  118. /**
  119. * 設置SmartConfig
  120. */
  121. void setConfig()
  122. {
  123.     String mac = WiFi.macAddress().substring(8);//取mac地址做主題用
  124.     mac.replace(":", "");//去掉:號
  125.     WiFiClient client_bemfa_WiFiClient;
  126.     HTTPClient http_bemfa_HTTPClient;
  127.     http_bemfa_HTTPClient.begin(client_bemfa_WiFiClient,"//probemfa/vv/setSmartConfig?version=1&user="+mac);
  128.     int httpCode = http_bemfa_HTTPClient.GET();
  129.     if (httpCode == 200)
  130.     {
  131.       Serial.println("wifi smartconfig ok");
  132.     }
  133.     http_bemfa_HTTPClient.end();
  134. }
  135. /**
  136. * 初始化wifi信息,并連接路由器網絡
  137. */
  138. void initWiFi()
  139. {
  140.   char temp[32];
  141.   uint8_t mac[6];
  142.   WiFi.macAddress(mac);
  143.   //sprintf(temp, "%s_%02X%02X%02X", HOST_NAME, mac[3], mac[4], mac[5]);
  144.   WiFi.hostname(temp);
  145.   if(WiFi.status() != WL_CONNECTED)
  146.   {
  147.     WiFi.disconnect();//斷開連接
  148.     WiFi.mode(WIFI_STA);//STA模式
  149.     WiFi.begin(config.stassid, config.stapsw);//連接路由器
  150.   }
  151.   Serial.print("Waiting for connect");
  152.   while (WiFi.status() != WL_CONNECTED)
  153.   {//檢查是否連接成功
  154.     delay(500);
  155.     Serial.print(".");
  156.     connect_time++;
  157.     if(connect_time >= 360)
  158.     {
  159.       connect_time = 0;
  160.       Serial.println("wifi connect faild");
  161.     }
  162.   }
  163.   if(config_flag == 1)
  164.   {
  165.     setConfig();
  166.   }
  167.   Serial.println("wifi is connected");
  168.   //Serial.print("ssid:");
  169.   //Serial.println(WiFi.SSID());
  170.   //Serial.print("psw:");
  171.   //Serial.println(WiFi.psk());
  172.   WiFi.softAP(temp);
  173. }
  174. /**
  175. * 加載存儲的信息,并檢查是否進行了反復5次重啟恢復出廠信息
  176. */
  177. uint8_t *p = (uint8_t*)(&config);
  178. void loadConfig()
  179. {
  180.     uint8_t mac[6];
  181.     WiFi.macAddress(mac);
  182.     EEPROM.begin(512);
  183.     for (int i = 0; i < sizeof(config); i++)
  184.     {
  185.       *(p + i) = EEPROM.read(i);
  186.     }
  187.     config.reboot = config.reboot + 1;
  188.     if(config.reboot>=4)
  189.     {
  190.         restoreFactory();
  191.     }
  192.     if(config.magic != MAGIC_NUMBER)
  193.     {
  194.       config_flag = 1;
  195.     }
  196.     EEPROM.begin(512);
  197.     for (int i = 0; i < sizeof(config); i++)
  198.     {
  199.       EEPROM.write(i, *(p + i));
  200.     }
  201.     EEPROM.commit();
  202.     delay(2000);
  203.     EEPROM.begin(512);
  204.     config.reboot = 0;
  205.     for (int i = 0; i < sizeof(config); i++)
  206.     {
  207.       EEPROM.write(i, *(p + i));
  208.     }
  209.     EEPROM.commit();
  210.     delay(2000);
  211. }
  212. /**
  213. * 恢復出廠設置,清除存儲的wifi信息
  214. */
  215. void restoreFactory(){
  216.     Serial.println("Restore Factory.......");
  217.     config.magic = 0x00;
  218.     strcpy(config.stassid, "");
  219.     strcpy(config.stapsw, "");
  220.     config.magic = 0x00;
  221.     saveConfig();
  222.     delayRestart(1);
  223.     while (1)
  224.     {
  225.       delay(100);
  226.     }
  227. }
  228. /**
  229. * 檢查是否需要airkiss配網
  230. */
  231. void waitKey()
  232. {
  233.   if(config_flag == 1)
  234.   {
  235.     doSmartconfig();
  236.   }
  237. }
  238. /*
  239.   *發送數據到TCP服務器
  240. */
  241. void sendtoTCPServer(String p)
  242. {
  243.   if (!TCPclient.connected())
  244.   {
  245.     //Serial.println("Client is not readly");
  246.     return;
  247.   }
  248.   TCPclient.print(p);
  249.   //Serial.println("[Send to TCPServer]:String");
  250. }
  251. /*
  252.   *初始化和服務器建立連接
  253. */
  254. void startTCPClient()
  255. {
  256.   if(TCPclient.connect(TCP_SERVER_ADDR, atoi(TCP_SERVER_PORT)))
  257.   {
  258.     //Serial.print("\nINFO:Connected to server:");
  259.     //Serial.printf("%s:%d\r\n",TCP_SERVER_ADDR,atoi(TCP_SERVER_PORT));
  260.     preTCPConnected = true;
  261.     preHeartTick = millis();
  262.     TCPclient.setNoDelay(true);
  263.     sendtoTCPServer("cmd=1&uid="+UID+"&topic="+TOPIC+"\r\n");
  264.   }
  265.   else
  266.   {
  267.     //Serial.print("INFO:Failed connected to server:");
  268.     //Serial.println(TCP_SERVER_ADDR);
  269.     TCPclient.stop();
  270.     preTCPConnected = false;
  271.   }
  272.   preTCPStartTick = millis();
  273. }
  274. /*
  275.   *檢查數據,發送數據
  276. */
  277. void doTCPClientTick()
  278. {
  279. //檢查是否斷開,斷開后重連
  280.   if(WiFi.status() != WL_CONNECTED) return;
  281.   if (!TCPclient.connected())
  282.   {//斷開重連
  283.     if(preTCPConnected == true)
  284.     {
  285.       preTCPConnected = false;
  286.       preTCPStartTick = millis();
  287.       Serial.println("TCP Client disconnected");
  288.       TCPclient.stop();
  289.     }
  290.     else if(millis() - preTCPStartTick > 1*1000)//重新連接
  291.       startTCPClient();
  292.   }
  293.   else
  294.   {
  295.     if (TCPclient.available())
  296.     {//收數據
  297.       char c =TCPclient.read();
  298.       TcpClient_Buff +=c;
  299.       TcpClient_BuffIndex++;
  300.       TcpClient_preTick = millis();
  301.       if(TcpClient_BuffIndex>=MAX_PACKETSIZE - 1)
  302.       {
  303.         TcpClient_BuffIndex = MAX_PACKETSIZE-2;
  304.         TcpClient_preTick = TcpClient_preTick - 200;
  305.       }
  306.       preHeartTick = millis();
  307.     }
  308.     if(millis() - preHeartTick >= upDataTime)
  309.     {//上傳數據
  310.       preHeartTick = millis();
  311.       float h = dht.readHumidity();//讀取濕度
  312.       float t = dht.readTemperature();//讀取攝氏度
  313.       if (isnan(h) || isnan(t))
  314.       {
  315.         Serial.println("Failed to read from DHT sensor!");
  316.         return;
  317.       } //檢查抓取是否成功
  318.       /*********************數據上傳*******************/
  319.       String upstr = "";
  320.       String uart_str = "";
  321.       upstr = "cmd=2&uid="+UID+"&topic="+TOPIC+"&msg=#"+over_int+"#"+t+"#"+h+"\r\n";
  322.       sendtoTCPServer(upstr);
  323.       uart_str = "DATA#"+over_int+"#"+t+"#"+h+"\r\n";
  324.       Serial.print(uart_str);
  325.       upstr = "";
  326.     }
  327.   }
  328.   if((TcpClient_Buff.length() >= 1) && (millis() - TcpClient_preTick>=200))
  329.   {//data ready
  330.     TCPclient.flush();
  331.     //Serial.print("Buff:");
  332.     //Serial.println(TcpClient_Buff);
  333.     TcpClient_Buff="";
  334.     TcpClient_BuffIndex = 0;
  335.   }
  336. }
  337. // change illumination LED brightness
  338. void brightLed(byte ledBrightness) {
  339.   ledcWrite(ledChannel, ledBrightness);  // change LED brightness (0 - 255)
  340. }
  341. // ----------------------------------------------------------------
  342. //       set up PWM for the illumination LED (flash)
  343. // ----------------------------------------------------------------
  344. // note: I am not sure PWM is very reliable on the esp32cam - requires more testing
  345. void setupFlashPWM() {
  346.   ledcSetup(ledChannel, ledFreq, ledRresolution);
  347.   ledcAttachPin(brightLED, ledChannel);
  348.   brightLed(0);
  349. }
  350. void Setint(){
  351.   sendp = 1;
  352. }
  353. void setup() {
  354.   Serial.begin(115200);
  355.   pinMode(brightLED, OUTPUT);    // flash LED
  356.   pinMode(sensorPin, INPUT); // 將引腳設置為輸入模式
  357.   digitalWrite(brightLED, LOW);  // led off = Low
  358.   attachInterrupt(2, Setint, FALLING);  //當電平發生變化時,觸發中斷
  359.   attachInterrupt(13, restoreFactory, FALLING);  //當電平發生變化時,觸發中斷
  360.   dht.begin(); //啟動傳感器
  361.   camera_config_t config;
  362.   config.ledc_channel = LEDC_CHANNEL_0;
  363.   config.ledc_timer = LEDC_TIMER_0;
  364.   config.pin_d0 = Y2_GPIO_NUM;
  365.   config.pin_d1 = Y3_GPIO_NUM;
  366.   config.pin_d2 = Y4_GPIO_NUM;
  367.   config.pin_d3 = Y5_GPIO_NUM;
  368.   config.pin_d4 = Y6_GPIO_NUM;
  369.   config.pin_d5 = Y7_GPIO_NUM;
  370.   config.pin_d6 = Y8_GPIO_NUM;
  371.   config.pin_d7 = Y9_GPIO_NUM;
  372.   config.pin_xclk = XCLK_GPIO_NUM;
  373.   config.pin_pclk = PCLK_GPIO_NUM;
  374.   config.pin_vsync = VSYNC_GPIO_NUM;
  375.   config.pin_href = HREF_GPIO_NUM;
  376.   config.pin_sscb_sda = SIOD_GPIO_NUM;
  377.   config.pin_sscb_scl = SIOC_GPIO_NUM;
  378.   config.pin_pwdn = PWDN_GPIO_NUM;
  379.   config.pin_reset = RESET_GPIO_NUM;
  380.   config.xclk_freq_hz = 20000000;
  381.   config.frame_size = FRAMESIZE_UXGA;
  382.   config.pixel_format = PIXFORMAT_JPEG;  // for streaming
  383.   config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  384.   config.fb_location = CAMERA_FB_IN_PSRAM;
  385.   config.jpeg_quality = 10;
  386.   config.fb_count = 1;
  387.   // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  388.   //                      for larger pre-allocated frame buffer.
  389.   if (config.pixel_format == PIXFORMAT_JPEG) {
  390.     if (psramFound()) {
  391.       config.jpeg_quality = 10;
  392.       config.fb_count = 2;
  393.       config.grab_mode = CAMERA_GRAB_LATEST;
  394.     } else {
  395.       // Limit the frame size when PSRAM is not available
  396.       config.frame_size = FRAMESIZE_SVGA;
  397.       config.fb_location = CAMERA_FB_IN_DRAM;
  398.     }
  399.   } else {
  400.     // Best option for face detection/recognition
  401.     config.frame_size = FRAMESIZE_240X240;
  402. #if CONFIG_IDF_TARGET_ESP32S3
  403.     config.fb_count = 2;
  404. #endif
  405.   }
  406. #if defined(CAMERA_MODEL_ESP_EYE)
  407.   pinMode(13, INPUT_PULLUP);
  408.   pinMode(14, INPUT_PULLUP);
  409. #endif
  410.   // camera init
  411.   esp_err_t err = esp_camera_init(&config);
  412.   if (err != ESP_OK) {
  413.     //Serial.printf("Camera init failed with error 0x%x", err);
  414.     return;
  415.   }
  416.   sensor_t* s = esp_camera_sensor_get();
  417.   // initial sensors are flipped vertically and colors are a bit saturated
  418.   if (s->id.PID == OV3660_PID) {
  419.     s->set_vflip(s, 1);        // flip it back
  420.     s->set_brightness(s, 1);   // up the brightness just a bit
  421.     s->set_saturation(s, -2);  // lower the saturation
  422.   }
  423. #if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  424.   s->set_vflip(s, 1);
  425.   s->set_hmirror(s, 1);
  426. #endif
  427. #if defined(CAMERA_MODEL_ESP32S3_EYE)
  428.   s->set_vflip(s, 1);
  429. #endif
  430.   loadConfig();
  431.   waitKey();
  432.   initWiFi();
  433.   //Serial.print("Camera Ready!:");
  434.   //Serial.println(WiFi.localIP());
  435.   setupFlashPWM();  // configure PWM for the illumination LED
  436. }
  437. /********http請求處理函數*********/
  438. esp_err_t _http_event_handler(esp_http_client_event_t* evt) {
  439.   if (evt->event_id == HTTP_EVENT_ON_DATA) {
  440.     httpResponseString.concat((char*)evt->data);
  441.   }
  442.   return ESP_OK;
  443. }
  444. static esp_err_t take_send_photo() {
  445.   if (flashRequired) {
  446.     brightLed(255);
  447.     delay(300);
  448.   }
  449.   //Serial.println("take_send_photo...");
  450.   camera_fb_t* fb = NULL;
  451.   esp_err_t res = ESP_OK;
  452.   fb = esp_camera_fb_get();
  453.   if (flashRequired) brightLed(0);  // change LED brightness back to previous state
  454.   if (!fb) {
  455.     //Serial.println("Camera capture failed...");
  456.     return ESP_FAIL;
  457.   }
  458.   httpResponseString = "";
  459.   esp_http_client_handle_t http_client;
  460.   esp_http_client_config_t config_client = { 0 };
  461.   config_client.url = post_url;
  462.   config_client.event_handler = _http_event_handler;
  463.   config_client.method = HTTP_METHOD_POST;
  464.   http_client = esp_http_client_init(&config_client);
  465.   esp_http_client_set_post_field(http_client, (const char*)fb->buf, fb->len);  //設置http發送的內容和長度
  466.   esp_http_client_set_header(http_client, "Content-Type", "image/jpg");        //設置http頭部字段
  467.   esp_http_client_set_header(http_client, "Authorization", uid);               //設置http頭部字段
  468.   esp_http_client_set_header(http_client, "Authtopic", topic);                 //設置http頭部字段
  469.   esp_http_client_set_header(http_client, "wechatmsg", wechatMsg);             //設置http頭部字段
  470.   esp_http_client_set_header(http_client, "wecommsg", wecomMsg);               //設置http頭部字段
  471.   esp_http_client_set_header(http_client, "picpath", urlPath);                 //設置http頭部字段
  472.   esp_err_t err = esp_http_client_perform(http_client);                        //發送http請求
  473.   if (err == ESP_OK) {
  474.     //json數據解析
  475.     StaticJsonDocument<200> doc;
  476.     DeserializationError error = deserializeJson(doc, httpResponseString);
  477.     if (error) {
  478.       //Serial.print(F("deserializeJson() failed: "));
  479.       //Serial.println(error.c_str());
  480.     }
  481.   }
  482.   //Serial.println("Taking picture END");
  483.   esp_camera_fb_return(fb);
  484.   esp_http_client_cleanup(http_client);
  485.   return res;
  486. }
  487. void loop()
  488. {
  489.   sensorValue = digitalRead(sensorPin); // 讀取引腳的電平
  490.   if (sensorValue == HIGH)
  491.   {
  492.     over_int = "true";
  493.   }
  494.   else
  495.   {
  496.     over_int = "false";
  497.   }
  498.   doTCPClientTick();
  499.   // current_millis = millis();
  500.   // if (current_millis - last_capture_millis > capture_interval)
  501.   // {
  502.   //   last_capture_millis = millis();
  503.   //   take_send_photo();
  504.   // }
  505.   if (sendp == 1)
  506.   {  // Take another picture
  507.     take_send_photo();
  508.     sendp = 0;
  509.   }
  510. }
esp32camv2.zip
6.9 KB, 下載次數: 9, 下載積分: 黑幣 -5
esp32-cam代碼
trash.zip
7.63 KB, 下載次數: 9, 下載積分: 黑幣 -5
小程序代碼
收藏收藏1 分享淘帖 頂1 踩
