查看: 1914|回復: 2
基于QT開發的串口上位機串口示波器源碼
我用QT開發軟件寫了一個上位機,串口示波器,既可以用串口發送接收數據,又可以圖形化顯示
#ifndef MAINWINDOW_H
#define MAINWINDOW_H
#include <QMainWindow>
#include <QMessageBox>
#include <QSerialPort>
#include <QSerialPortInfo>
#include <QFile>
#include <QFileDialog>
#include <QtCharts>
#include "QLineSeries"
#include "QValueAxis"
#include "QTimer"
#include "QTime"
#include "QList"
#include "qmath.h"
#include "QPointF"
#include "QDebug"
#include "QChartView"
#include "dataprocess.h"
#include <QMutex>
#include <QTcpServer>
#include <QTcpSocket>
#include <QUdpSocket>
#include <QtNetwork>
QT_CHARTS_USE_NAMESPACE
namespace Ui {
class MainWindow;
#define Channel_number 20
class MainWindow : public QMainWindow
    Q_OBJECT
public:
    explicit MainWindow(QWidget *parent = 0);
    ~MainWindow();
private slots:
    void readData();
    //void socket_Read_Data();
    void socket_Disconnected();
    void server_New_Connect();
    //void udp_receive();
    void on_btn_OpenSerial_clicked();
    void on_btn_help_clicked();
    void on_btn_StopDis_clicked();
    void on_action_save_triggered();
    void on_action_load_triggered();
    void on_btn_ClearSeries_clicked();
    void on_btn_SetXSize_clicked();
    void on_CH1_stateChanged();
    void on_CH2_stateChanged();
    void on_CH3_stateChanged();
    void on_CH4_stateChanged();
    void on_CH5_stateChanged();
    void on_CH6_stateChanged();
    void on_CH7_stateChanged();
    void on_CH8_stateChanged();
    void on_CH9_stateChanged();
    void on_CH10_stateChanged();
    void on_CH11_stateChanged();
    void on_CH12_stateChanged();
    void on_CH13_stateChanged();
    void on_CH14_stateChanged();
    void on_CH15_stateChanged();
    void on_CH16_stateChanged();
    void on_CH17_stateChanged();
    void on_CH18_stateChanged();
    void on_CH19_stateChanged();
    void on_CH20_stateChanged();
    void writeData(char* data,unsigned int len);
    void on_BTNSEND_clicked();
    void on_HEXSND_stateChanged();
    void on_pushButton_clicked();
    void on_pushButton_2_clicked();
    void on_pushButton_3_clicked();
    void on_pushButton_4_clicked();
    void on_pushButton_5_clicked();
    void on_pushButton_6_clicked();
    void on_periodsend_stateChanged();
    void on_period_sends();
    void on_cb_SerialPort_activated();
private:
    QString writeDataToCSV();
    void readDataFromCSV(QTextStream &sDataStream);
    void string2hex(QByteArray sendcoms);
    void hex2string(QByteArray &rcvstring);
//    void dispformat(QString appendStr);
private:
    bool SerialSta;
    DataProcess processor;
    bool chartSta;
    QSerialPort *port;
    Ui::MainWindow *ui;
    QLabel *lb_StatusBar_SerialStatus;
    QLabel *lb_StatusBar_DataRecNum;
    QChart *m_chart;
    QLineSeries m_series[Channel_number];
    QVector<QPointF> points[Channel_number];
    QValueAxis *axisX;
    QValueAxis *axisY;
    bool selchx[20];
    unsigned long int dataRecNum=0;
    int XSize = 200;
    int timeId;
    int Xmin=0;
    int Xmax=0;
    float Ymin=3.4028235e38f;
    float Ymax=1.4e-45f;
    QByteArray sendbuff;
    QString recvbuff;
    QTimer *sendTimer;// 定時器對象
    uint16_t rcvmaxsize;
    bool recvconvf;
    QString displaystr;
    QMutex mutex;
    QStringList baudspeed;
    uint8_t commethflag;
    QTcpServer* server;
    QTcpSocket* socket;
    QList<QTcpSocket*> tcpClient;
    QUdpSocket *uSocket;
    QString ipAddr;
    QTcpSocket* TCPCSocket;
    QHostAddress udpfromhost;
    quint16 udpfromport;
    bool bditemf;
    //QList<QHostAddress> ipAddressesList;
#endif // MAINWINDOW_H
serial_net_graph.7z
15.19 MB, 下載次數: 30, 下載積分: 黑幣 -5
收藏收藏4 分享淘帖 頂 踩
ID:258145 發表于 2024-5-19 17:55 | 只看該作者
這不是用QCreator 開發環境做的吧?  能把開發環境介紹下,同時給個 波形數據可以導入看波形的csv文件?
ID:258145 發表于 2024-5-19 17:57 | 只看該作者
這不是Q-Creator環境的工程吧? 能否把開發環境詳細說一下,同時給一個波形數據文件csv,以便導入看效果?
