查看: 3207|回復: 10
STC8H8K64U單片機LCD1602做的電壓表數字一直在變化怎么回事?
回帖獎勵 40 黑幣 回復本帖可獲得 10 黑幣獎勵! 每人限 1 次
ID:1108299 發表于 2024-3-8 16:49 | 顯示全部樓層 |閱讀模式
#include <STC8h.H>
#include <stdio.h>
#include <intrins.h>
sbit RS = P2^4;   //定義LCD1602端口
sbit RW = P2^5;
sbit EN = P2^6;
#define DataPort P0
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
void delay(unsigned int ms)    //@11.0592MHz
    unsigned char i, j;
   while(ms--)
    i = 15;
    j = 90;
    do
        while (--j);
    } while (--i);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
delay(1);
EN_SET;
delay(1);
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
delay(1);
EN_CLR;
delay(1);
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
delay(1);
EN_CLR;
delay(1);
void LCD_Clear(void)
LCD_Write_Com(0x01);
delay(5);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
  LCD_Write_Com(0x80 + x);     //表示第一行
  LCD_Write_Com(0xC0 + x);      //表示第二行
while ((*s)!='\0')
LCD_Write_Data( *s);
s ++;
void LCD_Init(void)
LCD_Write_Com(0x38);    /*顯示模式設置*/
delay(5);
delay(5);
delay(5);
LCD_Write_Com(0x08);    /*顯示關閉*/
LCD_Write_Com(0x01);    /*顯示清屏*/
LCD_Write_Com(0x06);    /*顯示光標移動設置*/
delay(5);
LCD_Write_Com(0x0C);    /*顯示開及光標設置*/
void DisplayVoltage(float voltage)
    unsigned char str[16];
    sprintf(str,"Voltage: %.2fV",voltage);
    LCD_Write_Com(0x80);
    LCD_Write_String(0,0,str);
void ADC_Init(void)
    ADC_CONTR |= 0x80;     //AD上電
    ADCTIM = 0x3f;         //設置ADC內部時序
    ADC_CONTR &= 0x7f;     //AD斷電
    ADCCFG = 0x2f;         //設置ADC時鐘為系統時鐘/2/16,12位結果右對齊
    ADC_CONTR = 0x80;      //使能ADC模塊上電
    delay(4);
    ADC_CONTR |= 0x01;     //選P01作為AD輸入
uint ADC_Read()
    ADC_CONTR |= 0x40;                          //啟動AD轉換
    delay(2);
    while ((ADC_CONTR & 0x20)==0);                //查詢ADC完成標志
    ADC_CONTR &= ~0x20;                         //清完成標志
    return ADC_RES << 8 | ADC_RESL;         //返回12位ADC結果
void main(void)
    P0M0=0;
    P0M1=0;
    P2M0=0;
    P2M1=0;
    LCD_Init();
    LCD_Clear();//清屏
    ADC_Init();
    delay(3);
    while (1)
        unsigned int rawVoltage = ADC_Read();
        float voltage = (rawVoltage * 5.0) / 4095; // 假設參考電壓是5V
        DisplayVoltage(voltage);
        delay(900);
在測量時有點電壓(不管是0.5v還是3.3v)就直接顯示5V,不進行測量時讀數在0~5v之間一直變化。程序有什么錯誤?指教指教!
ID:41656 發表于 2024-3-8 19:12 | 顯示全部樓層
需要把ADC的輸入端口IO模式設置為高阻模式,你全部初始化準雙向模式肯定讀取不正常的
ID:712097 發表于 2024-3-8 19:43 | 顯示全部樓層
多次重復讀取后累加,再取平均值。
ID:213173 發表于 2024-3-8 21:34 | 顯示全部樓層
幾mV的跳動是正常的,把此示例端口按實際電路改一下即可。
  1. #include "STC8H.H"
  2. #include "intrins.h"
  3. #define uint unsigned int
  5. #define ulong unsigned long
  6. #define LCD1602_DB P4
  7. sbit  LCD1602_RS=P1^0;
  8. sbit  LCD1602_RW=P1^1;
  9. sbit  LCD1602_EN=P1^2;
  10. uchar data dis_buf[]="VCC=0.000VVIN=0.000V";
  11. int *BGV;//內部1.19V參考信號源值
  12. uint res;//讀取內部第15通道ADC結果
  13. uint VCC;//電源電壓
  14. uint VCA;//緩沖
  15. uint Vin;//被測電壓
  16. uint VADC;//ADC轉換結果
  17. uint count;//計數
  18. bit flag;//T0中斷標志
  19. void Delay_ms(unsigned int t)        //@11.0592MHz
  20. {
  21.         unsigned char data i, j;
  22.         while (t--)
  23.         {
  24.                 i = 15;
  25.                 j = 90;
  26.                 do
  27.                 {
  28.                         while (--j);
  29.                 } while (--i);
  30.         }
  31. }
  32. //初始化ADC
  33. void ADC_Init(void)
  34. {
  35.         P_SW2 |= 0x80;
  36.         ADCTIM = 0x3f;         //設置ADC內部時序
  37.         P_SW2 &= 0x7f;
  38.         ADCCFG = 0x2f;         //設置ADC時鐘為系統時鐘/2/16,12位結果右對齊
  39.         ADC_CONTR = 0x80;      //使能ADC模塊
  40. }
  41. //讀取ADC結果
  42. uint ADC_Read(uchar ch)
  43. {
  44.         ADC_CONTR = ch;                          //啟動AD轉換
  45.         _nop_();
  46.         _nop_();
  47.         while (!(ADC_CONTR & 0x20));                //查詢ADC完成標志
  48.         ADC_CONTR &= ~0x20;                         //清完成標志
  49.         return ADC_RES << 8 | ADC_RESL;         //返回12位ADC結果
  50. }
  51. void Timer0_Init(void)                //10毫秒@11.0592MHz
  52. {
  53.         AUXR &= 0x7F;                        //定時器時鐘12T模式
  54.         TMOD &= 0xF0;                        //設置定時器模式
  55.         TL0 = 0x00;                                //設置定時初始值
  56.         TH0 = 0xDC;                                //設置定時初始值
  57.         TF0 = 0;                                //清除TF0標志
  58.         TR0 = 1;                                //定時器0開始計時
  59.         ET0 = 1;                                //使能定時器0中斷
  60.         EA  = 1;                          //使能總中斷
  61. }
  62. void Read_Busy()           //忙檢測函數,判斷bit7是 0執行 1禁止
  63. {
  64.         unsigned char sta;      //
  65.         LCD1602_DB = 0xff;
  66.         LCD1602_RS = 0;
  67.         LCD1602_RW = 1;
  68.         do
  69.         {
  70.                 LCD1602_EN = 1;
  71.                 sta = LCD1602_DB;
  72.                 LCD1602_EN = 0;    //使能
  73.         }while(sta & 0x80);
  74. }
  75. void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
  76. {
  77.         Read_Busy();//忙檢測函數,判斷bit7是 0執行 1禁止
  78.         LCD1602_RS = 0;//RS數據命令選擇RS=1數據 RS=0命令
  79.         LCD1602_RW = 0;//讀寫選擇 RW=1讀取 RW=0寫
  80.         LCD1602_EN = 1;//使能預備
  81.         LCD1602_DB = cmd;//送命令
  82.         NOP20();
  83.         LCD1602_EN = 0; //下降沿使能
  84. }
  85. void Lcd1602_Write_Data(unsigned char dat)   //寫數據
  86. {
  87.         Read_Busy();//忙檢測函數,判斷bit7是 0執行 1禁止
  88.         LCD1602_RS = 1;//RS數據命令選擇RS=1數據 RS=0命令
  89.         LCD1602_RW = 0;//讀寫選擇 RW=1讀取 RW=0寫
  90.         LCD1602_EN = 1;//使能預備
  91.         LCD1602_DB = dat;//送數據
  92.         NOP20();
  93.         LCD1602_EN = 0; //下降沿使能
  94. }
  95. void InitLcd1602()              //1602初始化 共5組初始化寄存器
  96. {
  97.         LCD1602_RS = 0;
  98.         LCD1602_RW = 0;
  99.         LCD1602_EN = 0;
  100.         Lcd1602_Write_Cmd(0x38);    //打開,5*8,8位數據   00111000
  101.         Lcd1602_Write_Cmd(0x0c);    //00001100后三位表示 開顯示 不顯光標 光標不閃爍
  102.         Lcd1602_Write_Cmd(0x06);    //00000110   //寫一個字符后地址指針加一
  103.         Lcd1602_Write_Cmd(0x01);    //清屏
  104. }
  105. void main()
  106. {
  107.         uchar i;
  108.         P0M0 = 0x00;
  109.         P0M1 = 0x00;
  110.         P1M0 = 0x00;
  111.         P1M1 = 0x80;       //設置P1.7為高阻 ADC口
  112.         P2M0 = 0x00;
  113.         P2M1 = 0x00;
  114.         P3M0 = 0x00;
  115.         P3M1 = 0x00;
  116.         P4M0 = 0x00;
  117.         P4M1 = 0x00;
  118.         P5M0 = 0x00;
  119.         P5M1 = 0x00;
  120.         Delay_ms(100);//等待系統穩定
  121.         BGV = (int idata *)0xef;//內部1.19V參考信號源值
  122.         ADC_Init();//初始化ADC
  123.         Timer0_Init();//初始化定時器
  124.         InitLcd1602();//初始化1602
  125.         while (1)
  126.         {
  127.                 if(flag)
  128.                 {
  129.                         flag=0;
  130.                         ADC_Read(0xcf);//丟掉兩次檢測
  131.                         ADC_Read(0xcf);
  132.                         res=ADC_Read(0xcf);   //讀取第15通道ADC結果
  133.                         VCC = (int)(4096L * *BGV / res);//計算電源電壓
  134.                         ADC_Read(0xc7);//丟掉兩次檢測
  135.                         ADC_Read(0xc7);
  136.                         VADC=ADC_Read(0xc7);   //讀取第7通道ADC結果
  137.                         Vin=VCC*(ulong)VADC/4096;//計算輸入電壓
  138.                         dis_buf[4]=VCC/1000%10+'0';//千位
  139.                         dis_buf[6]=VCC/100%10+'0';//百位
  140.                         dis_buf[7]=VCC/10%10+'0';//十位
  141.                         dis_buf[8]=VCC%10+'0';//個位
  142.                         dis_buf[14]=Vin/1000%10+'0';//千位
  143.                         dis_buf[16]=Vin/100%10+'0';//百位
  144.                         dis_buf[17]=Vin/10%10+'0';//十位
  145.                         dis_buf[18]=Vin%10+'0';//個位
  146.                         Lcd1602_Write_Cmd(0x80);//第一行
  147.                         for(i=0;i<10;i++)
  148.                                 Lcd1602_Write_Data(dis_buf[i]);
  149.                         Lcd1602_Write_Cmd(0x80+0x40);//第二行
  150.                         for(i=0;i<10;i++)
  151.                                 Lcd1602_Write_Data(dis_buf[i+10]);
  152.                 }
  153.         }
  154. }
  155. //
  156. void Timer0_Isr(void) interrupt 1
  157. {
  158.         flag=1;
  159. }
ID:143767 發表于 2024-3-9 10:11 | 顯示全部樓層
應該是AD轉換的問題
ID:1108299 發表于 2024-3-9 16:40 | 顯示全部樓層
wulin 發表于 2024-3-8 21:34
測不了,只顯示VCC=0.000V VIN=0.000V。讀數無變化
ID:712493 發表于 2024-3-9 16:57 | 顯示全部樓層
lcd1602 字符顯示數字  不是要加30?
ID:213173 發表于 2024-3-9 17:06 | 顯示全部樓層
@GS 發表于 2024-3-9 16:40
這只是示例程序,要根據你自己的實際電路修改端口定義。
ID:71955 發表于 2024-6-17 18:06 來自觸屏版 | 顯示全部樓層
你好,請教一下flag;//T0中斷標志那段程序為什么要放在主循環里?放在定時器T0中斷那里可以嗎
ID:1125947 發表于 2024-6-19 02:50 | 顯示全部樓層
試一下換個萬用表,或則檢查一下電路是不是有什么問題
ID:313517 發表于 2024-6-21 23:10 | 顯示全部樓層
試試硬件濾波,加上軟件濾波
