查看: 2752|回復: 3
在用proteus仿真stm32的輸入捕獲時發現,無論是用波形發生器還是定時器生成PWM方波...
在用proteus仿真stm32的輸入捕獲時發現,無論是用波形發生器還是定時器生成PWM方波,輸入捕獲下獲得的頻率在oled顯示不會改變,一直為0
代碼
IC.c
#include "IC.h"
void IC_Init(void)
        //開啟定時器2時鐘
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        //開啟GPIOA時鐘
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        //GPIOA配置
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        //GPIOA初始化
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        TIM_InternalClockConfig(TIM3);//TIM2 選擇定時器的內部時鐘源
        //時基單元配置
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        //時鐘分頻:1,2,4分頻
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        //計數器計數方式:向上、向下、中央對齊計數
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
        //設置ARR時鐘周期
        TIM_TimeBaseInitStructure.TIM_Period=65536-1;//ARR:10000個數后重裝
        //設置PSC預分頻的值
        TIM_TimeBaseInitStructure.TIM_Prescaler=72-1;//PSC:720分頻,計數頻率100k
        //重復計數器的值,高級定時器,這里用不到設置為0
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
        //時基單元初始化
        TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStructure);
        //輸入捕獲
        TIM_ICInitTypeDef TIM_ICInitStructure;
        TIM_ICInitStructure.TIM_Channel=TIM_Channel_1;
        TIM_ICInitStructure.TIM_ICFilter=0xF;
        TIM_ICInitStructure.TIM_ICPolarity=TIM_ICPolarity_Rising;
        TIM_ICInitStructure.TIM_ICPrescaler=TIM_ICPSC_DIV1;
        TIM_ICInitStructure.TIM_ICSelection=TIM_ICSelection_DirectTI;
        TIM_ICInit(TIM3,&TIM_ICInitStructure);
        //從模式+觸發
        TIM_SelectInputTrigger(TIM3,TIM_TS_TI1FP1);
        TIM_SelectSlaveMode(TIM3,TIM_SlaveMode_Reset);
        //使能TIM2
        TIM_Cmd(TIM3,ENABLE);
uint32_t IC_GetFreq(void)
        return 1000000 / (TIM_GetCapture1(TIM3));
main.c:
#include "stm32f10x.h"
#include  "OLED.h"
#include "delay.h"
#include "IC.h"
//#include "PWM.h"
int main(void)
        delay_init();
        OLED_Init();
//        PWM_Init();
//        PWM_SetPrescaler(720-1);//Freq=1000HZ
//        PWM_SetCompare1(50);//Duty=50/100
        IC_Init();
        OLED_Clear();
        OLED_ShowString(1, 1, "Freq:");                //1行1列顯示字符串Freq:00000Hz
                OLED_ShowNum(1,6,IC_GetFreq(),5);
TIM3_ic_存在問題.7z
350.19 KB, 下載次數: 7
ID:1112997 發表于 2024-3-14 17:01 | 只看該作者
你好,問題得到解決了嗎?
ID:1147547 發表于 2025-5-16 18:40 | 只看該作者
您好,我也遇到了這個問題,請問解決了嗎
ID:1116940 發表于 2025-5-17 11:04 | 只看該作者
我覺得是stm32在protues上不太完善,以前用輸入捕獲他是不能用的
