查看: 972|回復: 0
直流電機控制程序
ID:1098920 發(fā)表于 2024-2-21 20:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <REGX51.H>
#include "Delay.h"
#include "Key.h"
#include "Timer0.h"
#include "Nixie.h"
sbit Motor=P1^0;
unsigned char Counter,Compare;
unsigned char Keynumber,Speed;
void main ()
        Timer0_Init();
   while (1)
                 Keynumber=Key();
                 if (Keynumber==2)
                         Speed++;
                         Speed%=4;
                         if(Speed==0){Compare=0;}
                         if(Speed==1){Compare=25;}
                         if(Speed==2){Compare=50;}
                         if(Speed==3){Compare=100;}
                 Nixie(1,Speed);
void Timer0_Routine () interrupt 1
  TL0 = 0x9C;
        TH0 = 0xFF;
  Counter++;
        Counter%=100;
        if (Counter<Compare)
                  Motor=1;
                  Motor=0;
