300黑幣
描述:原本使用的SPI2,端口PB12.13.15 PA0 正常顯示 對應 CS,SCLK,SDA,RS(命令/數據)
換成SPI1,端口 PA15,PB3.4.5 對應 CS,SCLK,RS(命令/數據),SDA 問題:換了以后,不能顯示。只換PA15,可以顯示,所以問題出在PB345這塊。請教大家
#include "SPI.h"
void GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
//對應的SCK PB3
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable , ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SPI1 , ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//MOSI為 SDA PB 5
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
//MISO__A0 -- PB4
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//液晶初始化I/O口 rst PA0 --rst
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//片選 PA15___CS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
void SPI_Initial()
SPI_InitTypeDef SPI_InitStructure;
SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;//設置SPI單向或者雙向的數據模式:SPI設置為雙線雙向全雙工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //設置SPI工作模式:設置為主SPI
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//設置SPI的數據大小:SPI發送接收8位幀結構
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;//選擇了串行時鐘的穩態:時鐘懸空高
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;//數據捕獲于第二個時鐘沿
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信號由硬件(NSS管腳)還是軟件(使用SSI位)管理:內部NSS信號有SSI位控制
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;//定義波特率預分頻的值:波特率預分頻值為2
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定數據傳輸從MSB位還是LSB位開始:數據傳輸從MSB位開始
SPI_Init(SPI1, &SPI_InitStructure); //根據SPI_InitStruct中指定的參數初始化外設SPIx寄存器
SPI_Cmd(SPI1, ENABLE);
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
/*RCC 復位和時鐘設置*/
/* RCC system reset(for debug purpose) */
RCC_DeInit(); //時鐘管理重置
/* Enable HSE 外部高速晶振*/
RCC_HSEConfig(RCC_HSE_ON); //打開外部晶振
/* Wait till HSE is ready 等待外部晶振 就緒, 返回值:SUCCESS 就緒,ERROR 未就緒*/
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Flash讀取緩沖啟動Flash預取值 加速
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2); //Flash操作的延時設置Flash_Latency延時2周期
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1); //AHB使用系統時鐘
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1); //APB2(高速)為HCLK的一半
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2); //APB1(低速)為HCLK的一半
//注:AHB主要負責外部存儲器時鐘。APB2負責AD,I/O,高級TIM,串口1。APB1負責DA,USB,SPI,I2C,CAN,串口2345,普通TIM
/* ADCCLK = PCLK2/4 */
RCC_ADCCLKConfig(RCC_PCLK2_Div4); //默認4
/* PLLCLK = 8MHz * 7 = 56 MHz 注意此處的8M是指的外部晶振的大小*/
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //PLLCLK = 8MHz * 9 = 72 MH 默認為7
/* Enable PLL */
RCC_PLLCmd(ENABLE); //啟動PLL
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){} //等待PLL啟動
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //將PLL設置為系統時鐘源
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08){} //等待系統時鐘源的啟動
void SPI_SendData(uint8_t byte)
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI1, byte);
最佳答案
查看完整內容
或許你我的手上的手冊不一樣?
我手上的這份明白表示,PB3/4/5,沒有原生態SPI接口,連映射的都沒有。既然本就沒有,你映射過去也依然沒用。
至于只換PA15可以,是因為你的SPI_NSS是由軟件控制的,可以是任意IO。
而硬件控制,則需跟隨SPIx的群組走了。
附上手冊,其中第21頁你看一下。
如果確定有SPI,那恐怕是要查一下外圍了。
