void InterruptTimer0() interrupt 1
unsigned char i;
static unsigned char keyout = 0; //矩陣按鍵掃描輸出索引
static unsigned char keybuf[4][4] = { //矩陣按鍵掃描緩沖區
{0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
TH0 = 0xFC; //重新加載初值
TL0 = 0x67;
//將一行的 4 個按鍵值移入緩沖區
keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
//消抖后更新按鍵狀態
for (i=0; i<4; i++) //每行 4 個按鍵,所以循環 4 次
if ((keybuf[keyout][i ] & 0x0F) == 0x00)
[i ]{ //連續 4 次掃描值為 0,即 4*4ms 內都是按下狀態時,可認為按鍵已穩定的按下
[i ]KeySta[keyout][i ] = 0;
else if ((keybuf[keyout][i ] & 0x0F) == 0x0F)
{ //連續 4 次掃描值為 1,即 4*4ms 內都是彈起狀態時,可認為按鍵已穩定的彈起
KeySta[keyout][i ] = 1;
//執行下一次的掃描輸出
keyout++; //輸出索引遞增
keyout = keyout & 0x03; //索引值加到 4 即歸零
switch (keyout) //根據索引,釋放當前輸出引腳,拉低下次的輸出引腳
case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
default: break;
}請問比如我按了第4行第2個鍵,就是output4為0,keyln2為0,在代碼中是怎么體現的我按的這個鍵?
