查看: 1055|回復: 0
4位數碼管顯示密碼鎖程序
ID:1108766 發表于 2024-1-10 15:31 來自觸屏版 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include<reg51.h>
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
sbit led4=P1^3;
sbit smg1=P2^0;
sbit smg2=P2^1;
sbit smg3=P2^2;
sbit smg4=P2^3;
sbit sda=P2^5;
sbit scl=P2^4;
sbit SOUNDER=P1^7;
uchar a;
uint n=0,m=0,js,error=0;
uchar key;
uchar mima[]={0x00,0x00,0x00,0x00};
uchar e_mima[]={0x01,0x02,0x03,0x04};
uchar new_mima[]={0x01,0x02,0x03,0x04};
uchar code dis[]=         //0~9,A~F的共陰顯示代碼
{0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
uchar code tab[]=        //矩陣鍵盤按鍵位置碼
0x77,0xb7,0xd7,0xe7,
0x7b,0xbb,0xdb,0xeb,
0x7d,0xbd,0xdd,0xed,
0x7e,0xbe,0xde,0xee
void init();
void change_mima();
void delay02()
void start()  //開始信號
        sda=1;
        delay02();
        scl=1;
        delay02();
        sda=0;
        delay02();
void stop()   //停止
        sda=0;
        delay02();
        scl=1;
        delay02();
        sda=1;
        delay02();
void respons()  //應答
        uchar i;
        scl=1;
        delay02();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay02();
void at2402init()
        sda=1;
        delay02();
        scl=1;
        delay02();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
            delay02();
                sda=CY;
                delay02();
                scl=1;
                delay02();
        //        scl=0;
     //   delay();
        scl=0;
        delay02();
        sda=1;
        delay02();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay02();
        sda=1;
        delay02();
        for(i=0;i<8;i++)
                scl=1;
                delay02();
                k=(k<<1)|sda;
                scl=0;
                delay02();
        return k;
void delay11(uchar x)
        uchar a,b;
        for(a=x;a>0;a--)
         for(b=100;b>0;b--);
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        re
