查看: 1937|回復: 2
STC12C5A60S2單片機移植UCOSII建立7信任務驅動7個LED燈閃爍
ID:731890 發表于 2023-12-23 14:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機可用的操作系統比較少,能夠在51單片機上運行一套完整的操作系統非常困難,我們把UCOSII移植到STC12C5A60S2上面,能夠完全運行會部功能。
  1. #include "includes.h"
  2. sbit LED0=P1^0;
  3. sbit LED1=P1^1;
  4. sbit LED2=P1^2;
  5. sbit LED3=P1^3;
  6. sbit LED4=P1^4;
  7. sbit LED5=P1^5;
  8. sbit LED6=P1^6;
  9. OS_STK Task1Stk[MaxStkSize+1];
  10. OS_STK Task2Stk[MaxStkSize+1];
  11. OS_STK Task3Stk[MaxStkSize+1];
  12. OS_STK Task4Stk[MaxStkSize+1];
  13. OS_STK Task5Stk[MaxStkSize+1];
  14. OS_STK Task6Stk[MaxStkSize+1];
  15. OS_STK Task7Stk[MaxStkSize+1];
  16. void Task1(void *ppdata) reentrant;
  17. void Task2(void *ppdata) reentrant;
  18. void Task3(void *ppdata) reentrant;
  19. void Task4(void *ppdata) reentrant;
  20. void Task5(void *ppdata) reentrant;
  21. void Task6(void *ppdata) reentrant;
  22. void Task7(void *ppdata) reentrant;
  23. void main(void)
  24. {
  25.         OSInit();
  26.         InitHardware();
  27.
  28.         OSTaskCreate(Task1,(void*)0,&Task1Stk[0],0);
  29.         OSTaskCreate(Task2,(void*)0,&Task2Stk[0],1);
  30.         OSTaskCreate(Task3,(void*)0,&Task3Stk[0],2);
  31.         OSTaskCreate(Task4,(void*)0,&Task4Stk[0],3);
  32.         OSTaskCreate(Task5,(void*)0,&Task5Stk[0],4);
  33.         OSTaskCreate(Task6,(void*)0,&Task6Stk[0],5);
  34.         OSTaskCreate(Task7,(void*)0,&Task7Stk[0],6);
  35.         OSStart();
  36. }
  37. void Task1(void *ppdata) reentrant
  38. {
  39.         ppdata = ppdata;
  40.         while(1){
  41.                 LED0=~LED0;
  42.                 OSTimeDly(OS_TICKS_PER_SEC);
  43.         }
  44. }
  45. void Task2(void *ppdata) reentrant
  46. {
  47.         ppdata = ppdata;
  48.         while(1){
  49.                 LED1=~LED1;
  50.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  51.         }
  52. }
  53. void Task3(void *ppdata) reentrant
  54. {
  55.         ppdata = ppdata;
  56.         while(1){
  57.                 LED2=~LED2;
  58.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  59.         }
  60. }
  61. void Task4(void *ppdata) reentrant
  62. {
  63.         ppdata = ppdata;
  64.         while(1){
  65.                 LED3=~LED3;
  66.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  67.         }
  68. }
  69. void Task5(void *ppdata) reentrant
  70. {
  71.         ppdata = ppdata;
  72.         while(1){
  73.                 LED4=~LED4;
  74.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  75.         }
  76. }
  77. void Task6(void *ppdata) reentrant
  78. {
  79.         ppdata = ppdata;
  80.         while(1){
  81.                 LED5=~LED5;
  82.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  83.         }
  84. }
  85. void Task7(void *ppdata) reentrant
  86. {
  87.         ppdata = ppdata;
  88.         while(1){
  89.                 LED6=~LED6;
  90.                 OSTimeDly(OS_TICKS_PER_SEC*2);
  91.         }
  92. }
原理圖: 無
仿真: 無
代碼: STC12C5A60S2+UCOSII7個任務驅動7個LED燈閃爍.7z (99.1 KB, 下載次數: 27)
收藏收藏2 分享淘帖 頂 踩
ID:435636 發表于 2023-12-23 18:50 | 只看該作者
謝謝分享
,51能絲滑跑嗎?還剩下多少rom和ram?
ID:1064915 發表于 2024-1-3 10:18 | 只看該作者
UCOSII的學習資料,有鏈接嗎
