#include <reg52.h> //調(diào)用單片機頭文件
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
bit flag_200ms ;
bit flag_100ms ;
sbit beep = P3^7; //蜂鳴器定義
bit flag_beep_en;
uint clock_value; //用作鬧鐘用的
uchar menu_1,menu_2;
uchar key_time,flag_value;
bit key_500ms ;
#include "ds1302.h"
#include "lcd1602.h"
/******************1ms 延時函數(shù)*******************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/******************寫星期函數(shù)*******************/
void write_week(uchar hang,uchar add,uchar week)//寫星期函數(shù)
if(hang==1)
write_com(0x80+add);
write_com(0x80+0x40+add);
switch(week)
case 1:write_data('S');//星期數(shù)為7時,顯示
write_data('U');
write_data('N');
break;
case 2:write_data('M');//星期數(shù)據(jù)為1時顯示
write_data('O');
write_data('N');
break;
case 3:write_data('T');//星期數(shù)據(jù)為2時顯示
write_data('U');
write_data('E');
break;
case 4:write_data('W');//星期數(shù)據(jù)為3是顯示
write_data('E');
write_data('D');
break;
case 5:write_data('T');//星期數(shù)據(jù)為4時顯示
write_data('H');
write_data('U');
break;
case 6:write_data('F');//星期數(shù)據(jù)為5時顯示
write_data('R');
write_data('I');
break;
case 7:write_data('S');//星期數(shù)據(jù)為6時顯示
write_data('T');
write_data('A');
break;
/*************時鐘顯示***************/
void init_1602_ds1302()
write_sfm2_ds1302(1,1,shi); //顯示時
write_sfm2_ds1302(1,4,fen); //顯示分
write_sfm2_ds1302(1,7,miao); //顯示秒
write_week(2,12,week);
write_sfm2_ds1302(2,2,nian); //顯示年
write_sfm2_ds1302(2,5,yue); //顯示月
write_sfm2_ds1302(2,8,ri); //顯示日
/*************定時器0初始化程序***************/
void init_time0()
EA = 1; //開總中斷
TMOD = 0X01; //定時器0、工作方式1
TH0 = 0X3C;
TL0 = 0XB0; //50ms
ET0 = 1; //開定時器0中斷
TR0 = 1; //允許定時器0定時
/*************鬧鐘報警函數(shù)***************/
void menu_dis()
static uchar mm,value;
if(flag_100ms == 1) //100ms執(zhí)行一次
flag_100ms = 0;
if(open1 == 1) //如果鬧鐘打開
if((miao == 0) && (fen == fen1) && (shi == shi1))
flag_beep_en = 1; //有報警 打開蜂鳴器響的標(biāo)志位
if(flag_beep_en == 1) //鬧鐘以被打開
clock_value++;
if(clock_value <= 30)
beep = ~beep; //蜂鳴器叫3秒
else if(clock_value > 30)
beep = 1; //蜂鳴器停1秒
if(clock_value > 40)
clock_value = 0;
// 1 分鐘后自動關(guān)閉鬧鐘
value ++;
if(value >= 10)
value = 0;
mm++;
if(mm >= 60)
mm = 0;
flag_beep_en = 0;
beep = 1;
/********************獨立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨立按鍵程序
static uchar key_new;
key_can = 20; //按鍵值還原
P3 |= 0x78; //對應(yīng)的按鍵IO口輸出為1
if((P3 & 0x78) != 0x78) //按鍵按下
delay_1ms(1); //按鍵消抖動
if(((P3 & 0x78) != 0x78) && (key_new == 1))
{ //確認(rèn)是按鍵按下
key_new = 0;
switch(P3 & 0x78)
case 0x70: key_can = 4; break; //得到按鍵值
case 0x68: key_can = 3; break; //得到按鍵值
case 0x58: key_can = 2; break; //得到按鍵值
case 0x38: key_can = 1; break; //得到按鍵值
key_new = 1;
/**********************設(shè)置函數(shù)************************/
void key_with()
if(key_can == 1) //設(shè)置鍵
menu_1++;
if(menu_1 == 1) //設(shè)置時間
menu_2 = 1;
write_string(1,0," : : W: ");
write_string(2,0," 20 - - ");
if(menu_1 == 2) //設(shè)置鬧鐘
menu_2 = 1;
write_string(1,0," set clock ");
write_string(2,0," Y 00:00 ");
if(menu_1 > 2) //回到正常顯示
menu_1 = 0;
write_guanbiao(1,2,0); //關(guān)閉光標(biāo)
init_1602_dis_csf(); //初始化液晶顯示
if(key_can == 2) //選擇鍵
flag_200ms = 1;
menu_2 ++;
if(menu_2 > 7)
menu_2 = 1;
menu_2 ++;
if(menu_2 > 3)
menu_2 = 1;
if(menu_1 == 1)
if(menu_2 == 1) //設(shè)置時
if(key_can == 3) //加
shi+=0x01;
if((shi & 0x0f) >= 0x0a)
shi = (shi & 0xf0) + 0x10;
if(shi >= 0x24)
shi = 0;
if(key_can == 4) //減
if(shi == 0x00)
shi = 0x24;
if((shi & 0x0f) == 0x00)
shi = (shi | 0x0a) - 0x10;
shi -- ;
if(menu_2 == 2) //設(shè)置分
fen+=0x01;
if((fen & 0x0f) >= 0x0a)
fen = (fen & 0xf0) + 0x10;
if(fen >= 0x60)
fen = 0;
if(fen == 0x00)
fen = 0x5a;
if((fen & 0x0f) == 0x00)
fen = (fen | 0x0a) - 0x10;
fen -- ;
if(menu_2 == 3) //設(shè)置秒
miao+=0x01;
if((miao & 0x0f) >= 0x0a)
miao = (miao & 0xf0) + 0x10;
if(miao >= 0x60)
miao = 0;
if(miao == 0x00)
miao = 0x5a;
if((miao & 0x0f) == 0x00)
miao = (miao | 0x0a) - 0x10;
miao -- ;
if(menu_2 == 4) //設(shè)置星期
week+=0x01;
if((week & 0x0f) >= 0x0a)
week = (week & 0xf0) + 0x10;
if(week >= 0x08)
week = 1;
if(week == 0x01)
week = 0x08;
if((week & 0x0f) == 0x00)
week = (week | 0x0a) - 0x10;
week -- ;
if(menu_2 == 5) //設(shè)置年
nian+=0x01;
if((nian & 0x0f) >= 0x0a)
nian = (nian & 0xf0) + 0x10;
if(nian >= 0x9a)
nian = 1;
if(nian == 0x01)
nian = 0x9a;
if((nian & 0x0f) == 0x00)
nian = (nian | 0x0a) - 0x10;
nian -- ;
if(menu_2 == 6) //設(shè)置月
yue+=0x01;
if((yue & 0x0f) >= 0x0a)
yue = (yue & 0xf0) + 0x10;
if(yue >= 0x13)
yue = 1;
if(yue == 0x01)
yue = 0x13;
if((yue & 0x0f) == 0x00)
yue = (yue | 0x0a) - 0x10;
yue -- ;
if(menu_2 == 7) //設(shè)置日
ri+=0x01;
if((ri & 0x0f) >= 0x0a)
ri = (ri & 0xf0) + 0x10;
if(ri >= 0x32)
ri = 0;
if(ri == 0x01)
ri = 0x32;
if((ri & 0x0f) == 0x00)
ri = (ri | 0x0a) - 0x10;
ri -- ;
write_sfm2_ds1302(1,2,shi); //顯示時
write_sfm2_ds1302(1,5,fen); //顯示分
write_sfm2_ds1302(1,8,miao); //顯示秒
write_sfm1(1,14,week); //顯示星期
write_sfm2_ds1302(2,3,nian); //顯示年
write_sfm2_ds1302(2,6,yue); //顯示月
write_sfm2_ds1302(2,9,ri); //顯示日
switch(menu_2) // 光標(biāo)顯示
case 1: write_guanbiao(1,2,1); break;
case 2: write_guanbiao(1,5,1); break;
case 3: write_guanbiao(1,8,1); break;
case 4: write_guanbiao(1,14,1); break;
case 5: write_guanbiao(2,3,1); break;
case 6: write_guanbiao(2,6,1); break;
case 7: write_guanbiao(2,9,1); break;
write_time(); //把時間寫進去
/***************設(shè)置鬧鐘*********************/
if(menu_1 == 2)
if(menu_2 == 1) //設(shè)置鬧鐘開關(guān)
if(key_can == 3)
open1 = 1; //鬧鐘開
if(key_can == 4)
open1 = 0; //鬧鐘關(guān)
if(menu_2 == 2) //設(shè)置鬧鐘時
shi1+=0x01;
if((shi1 & 0x0f) >= 0x0a)
shi1 = (shi1 & 0xf0) + 0x10;
if(shi1 >= 0x24)
shi1 = 0;
if(shi1 == 0x00)
shi1 = 0x24;
if((shi1 & 0x0f) == 0x00)
shi1 = (shi1 | 0x0a) - 0x10;
shi1 -- ;
fen1+=0x01;
if((fen1 & 0x0f) >= 0x0a)
fen1 = (fen1 & 0xf0) + 0x10;
if(fen1 >= 0x60)
fen1 = 0;
if(fen1 == 0x00)
fen1 = 0x5a;
if((fen1 & 0x0f) == 0x00)
fen1 = (fen1 | 0x0a) - 0x10;
fen1 -- ;
if(open1 == 1)
write_string(2,4,"Y");
write_string(2,4,"N");
write_sfm2_ds1302(2,7,shi1); //顯示鬧鐘時
write_sfm2_ds1302(2,10,fen1); //顯示鬧鐘分
case 1: write_guanbiao(2,4,1); break;
case 2: write_guanbiao(2,7,1); break;
case 3: write_guanbiao(2,10,1); break;
/*****************主函數(shù)********************/
beep = 0; //開機叫一聲
delay_1ms(150);
P0 = P1 = P2 = P3 = 0xff; //單片機IO口初始化為1
init_time0(); //初始化定時器
init_ds1302(); //ds1302初始化
init_1602(); //lcd1602初始化
init_1602_dis_csf(); //lcd1602初始化顯示
// open1 = 1; //默認(rèn)鬧鐘開
key(); //按鍵程序
if(key_can < 10)
if(flag_beep_en == 0) //只有鬧鐘關(guān)了的時候才能進入設(shè)置
key_with();
flag_beep_en = 0; //按下任意鍵可關(guān)閉鬧鐘
beep = 1;
clock_value = 0;
read_time();
if(flag_200ms == 1)
flag_200ms = 0;
if(menu_1 == 0)
read_time(); //讀時間
init_1602_ds1302(); //顯示時鐘
menu_dis(); //鬧鐘報警函數(shù)
delay_1ms(1);
/**************定時器0中斷程序*****************/
void time0() interrupt 1
static uchar value;
TH0 = 0X3C;
TL0 = 0XB0; //50ms
value ++;
if((value % 2) == 0) //100ms
flag_100ms = 1;
if(value >= 6) //200ms
value = 0;
flag_200ms = 1;
