查看: 2169|回復: 0
51單片機共陰數碼管顯示計數0-9,計數結束實現8個LED燈依次熄滅或依次點亮
功能實現:計數0~9,通過共陰數碼管顯示數值,計數到9時,實現8個LED燈依次熄滅或依次點亮
#include <reg52.h>
#include <intrins.h>
#define ledport        P2        //LED燈
#define SMG_PORT        P0  //數碼管
sbit LSA= P1^0;
sbit LSB= P1^1;
sbit LSC= P1^2;
unsigned char i;
unsigned char code LedChar[] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char Ledwei[8]={
        0x00,0x00 ,0x00 , 0x00, 0x00, 0x00,0x00,0x00
unsigned int cnt = 0;
unsigned char sec = 0;
/*unsigned char code ledliang[9]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};        */
void  led();
          unsigned char cnt = 0;
    LSC= 0;
    LSB= 0;
    LSA= 0;
  TMOD=0x01;//0000 0001 方式一
        TH0=0xFC;
        TL0=0x18;
        EA=1;
        ET0=1;
        TR0=1; //開啟T0
      led();
void  tmier0()   interrupt 1
  TH0=0xFC;
        TL0=0x18;
    cnt++;
        P0 = 0x00;
        switch(i)
                case 0: LSC=1; LSB=1; LSA=1; i++; P0=Ledwei[0];break;
                case 1: LSC=1; LSB=1; LSA=0; i++; P0=Ledwei[1];break;
                case 2: LSC=1; LSB=0; LSA=1; i++; P0=Ledwei[2];break;
                case 3: LSC=1; LSB=0; LSA=0; i++; P0=Ledwei[3];break;
                case 4: LSC=0; LSB=1; LSA=1; i++; P0=Ledwei[4];break;
                case 5: LSC=0; LSB=1; LSA=0; i=0; P0=Ledwei[5];break;
                default:break;
//延時
void delay_100ms(unsigned int ys)
   while(ys--);
void  led()
            if(cnt >= 1000)
                         cnt = 0;
                   Ledwei[0] = LedChar[sec%10];
                         sec++;
                         if(sec==10)
                         sec=0;
                         P0 = 0x00;
            unsigned int i = 0;
              for(i=0;i<9;i++)
                       /* P2=ledliang[i];*/  //方法1
                                           P2=~(0xff<<i);//方法二
                              delay_100ms(50000);
                              P2=0Xff;
                                if(i == 9)
                                          i=0;
屏幕截圖 2023-12-16 160859.png (473 KB, 下載次數: 45)
屏幕截圖 2023-12-16 160930.png (173.17 KB, 下載次數: 52)
屏幕截圖 2023-12-16 160955.png (241.65 KB, 下載次數: 53)
