查看: 1727|回復: 2
Proteus仿真LCD1602只亮屏不顯示字符?
ID:1103701 發(fā)表于 2023-12-11 14:42 | 顯示全部樓層 |閱讀模式
Desktop Screenshot 2023.12.11 - 14.34.30.69.png Desktop Screenshot 2023.12.11 - 14.40.49.09.png
單片機代碼及截圖如下
#include "reg52.h"
#include"intrins.h"
#define out P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
void lcd_initial(void);
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad,uchar*s);
void delay(uint);
void main(void)
{        lcd_initial();
        {        string(0x80,"Welcome");
                string(0xC0,"Chengdu CHINA");
                delay(1000);
                write_command(0x01);
                delay(1000);
void delay(uint j)
{        uchar i=250;
        for( ;j>0;j--)
        {        while(--i);
                i=249;
                while(--i);
                i=250;
{        uchar dt;
        do
        {        dt=0xff;
        E=0;
        RS=0;
        RW=1;
        E=1;
        dt=out;
        }while(dt&0x80);
        E=0;
{        check_busy();
        E=0;
        RS=0;
        RW=0;
        out=com;
        E=1;
        _nop_( );
        E=0;
        delay(1);
{        check_busy();
        E=0;
        RS=1;
        RW=0;
        out=dat;
        E=1;
        _nop_();
        E=0;
        delay(1);
{        write_command(0x38);
        write_command(0x0F);
        write_command(0x06);
        delay(1);
void string(uchar ad,uchar *s)
{        write_command(ad);
        while(*s>0)
        {        write_data(*s++);
                delay(100);
ID:1085081 發(fā)表于 2023-12-11 19:41 | 顯示全部樓層
該程序的功能是在液晶屏上顯示"Welcome"和"Chengdu CHINA"兩行內(nèi)容,每隔一段時間清除屏幕內(nèi)容并重新顯示。代碼是沒問題的,檢查一下硬件吧
ID:1103774 發(fā)表于 2023-12-11 20:21 | 顯示全部樓層
應該是硬件有些問題
