查看: 1445|回復: 5
單片機lcd顯示 不明白怎么寫程序
要求通過矩陣鍵盤顯示6位學號,但目前只可以單位顯示,沒法顯示6位,希望大佬給一個思路
#include <reg52.h>      //包含52頭文件
#define uint unsigned int //宏定義uint代替unsigned int
#define uchar unsigned char //宏定義uchar代替unsigned char
#define out P0
sbit lcdrs=P2^4;
sbit lcdrw=P2^5;
sbit lcden=P2^6;
void check_busy(void);
void write_cmd(char cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void keyscan();
uchar key,num=100,flag;
uint cnt=0;
uchar dat[]="0123456789ABCDEF";
void delay (uint xms)     //毫秒函數定義
    uint i,j;
    for(i=0;i<xms;i++)
       for(j=0;j<120;j++);
void  main()                            //主函數
{        lcd_init();
          write_cmd(0x80+0x40);
          keyscan();
           if(num<16)
             write_data(dat[key]);
/**********************檢查忙標志函數************************/
    uchar dt;
        out=0xff;
        do
           lcden=0;
           lcdrs=0;
           lcdrw=1;
           lcden=1;
           dt=out;
        }while(dt&0x80);
        lcden=0;
/**************************1602顯示****************************/
void write_cmd(char cmd)  //寫指令函數
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=0;
        lcdrw=0;//先將RW拉低
        out=cmd;
        lcden=1;
        lcden=0;
void write_data(uchar dat) //寫數據函數
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=1;
        lcdrw=0;//先將RW拉低
        out=dat;
        lcden=1;
        lcden=0;
void write_str(uchar *str)//寫字符串函數
        while(*str!='\0')
                write_data(*str++);
                delay(5);
/***************************初始化******************************/
void lcd_init()//初始化1602
        write_cmd(0x38);//顯示模式設置
        write_cmd(0x0c);//顯示開關,光標沒有閃爍
        write_cmd(0x06);//顯示光標移動設置
        write_cmd(0x01);//清除屏幕
        delay(1);
void keyscan()
    uchar temp,num;
    P1=0xff;       //先向P1寫1
        P1=0xfe;       //選中按鍵第一行
        temp=P1;           //把P1給中間變量
        temp=temp&0xf0;//低四位清零
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xee:key=0; break;
                            case 0xde:key=1; break;
                            case 0xbe:key=2; break;
                            case 0x7e:key=3; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfd;//選中按鍵第二行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xed:key=4; break;
                            case 0xdd:key=5; break;
                            case 0xbd:key=6; break;
                            case 0x7d:key=7; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfb;//選中按鍵第三行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xeb:key=8; break;
                            case 0xdb:key=9; break;
                            case 0xbb:key=10; break;
                            case 0x7b:key=11; break;
                        while(temp!=0xf0)
                            temp=P1;
                            temp=temp&0xf0;
        P1=0xf7;//選中按鍵第四行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xe7:key=12; break;
                            case 0xd7:key=13; break;
                            case 0xb7:key=14; break;
                            case 0x77:key=15; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
   while((num<50)&&(temp!=0xf0))
   {delay(10);
     num++;
    num=0;
ID:1102504 發表于 2023-12-4 15:32 來自觸屏版 | 只看該作者
你可以去b站學一下
ID:94031 發表于 2023-12-4 16:01 | 只看該作者
先解決6位數碼管能不斷顯示緩存數組里的內容,再解決緩存能存儲矩陣鍵盤輸入的學號。
ID:374110 發表于 2023-12-4 16:57 | 只看該作者
找個1602的程序自己看看邏輯,沒有位選和片選處理怎么會多位顯示
ID:161164 發表于 2023-12-7 10:31 | 只看該作者
ID:1096616 發表于 2023-12-11 18:05 | 只看該作者
哦,這個是一個可行的想法
