- #include <REG52.H>
- sbit ADDR0=P2^2;
- sbit ADDR1=P2^3;
- sbit ADDR2=P2^4;
- sbit ADDR3=P2^5;
- sbit ENLED=P2^6;
- sbit KEY_IN_1=P1^3;
- sbit KEY_IN_2=P1^2;
- sbit KEY_IN_3=P1^1;
- sbit KEY_IN_4=P1^0;
- sbit KEY_OUT_1=P1^7;
- sbit KEY_OUT_2=P1^6;
- sbit KEY_OUT_3=P1^5;
- sbit KEY_OUT_4=P1^4;
- unsigned char code LedChar[]={
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40
- unsigned char LedBuff[6]={
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
- unsigned char code KeyCodeMap[4][4]={
- {0x31,0x32,0x33,0x26},
- {0x34,0x35,0x36,0x35},
- {0x37,0x38,0x39,0x28},
- {0x30,0x1B,0x0D,0x27}
- unsigned char KeySta[4][4]={
- {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
- void KeyDriver();
- void main()
- ENLED=0;
- ADDR3=1;
- TMOD=0x01;
- TH0=0xFC;
- TL0=0x67;
- EA=1;
- ET0=1;
- TR0=1;
- LedBuff[0]=LedChar[0];
- while(1)
- KeyDriver();
- void ShowNumber(unsigned long num)
- signed char i;
- unsigned char buf[6];
- for(i=0;i<6;i++)
- buf[i]=num%10;
- num=num/10;
- for(i=5;i>=1;i--)
- if(buf[i]==0)
- LedBuff[i]=0xFF;
- else
- break;
- for(;i>=0;i--)
- LedBuff[i]=LedChar[buf[i]];
- void KeyAction(unsigned char keycode)
- static unsigned long result=0;
- static unsigned long addend=0;
- if((keycode>=0x30)&&(keycode<=0x39))
- addend=(addend*10)+(keycode-0x30);
- ShowNumber(addend);
- else if(keycode==0x26)
- result += addend;
- addend=0;
- ShowNumber(result);
- else if(keycode==0x0D)
- result += addend;
- addend=0;
- else if(keycode==0x1B)
- addend=0;
- result=0;
- void KeyDriver()
- unsigned char i,j;
- static unsigned char backup[4][4]={
- for(i=0;i<4;i++)
- for(j=0;j<4;j++)
- if(backup[i][j] != KeySta[i][j])
- if(backup[i][j] !=0)
- KeyAction(KeyCodeMap[i][j]);
- backup[i][j]=KeySta[i][j];
- void KeyScan()
- unsigned char i;
- static unsigned char keyout=0;
- static unsigned char keybuf[4][4]={
- {0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF}
- keybuf[keyout][0]=(keybuf[keyout][0]<<1)|KEY_IN_1;
- keybuf[keyout][1]=(keybuf[keyout][1]<<1)|KEY_IN_2;
- keybuf[keyout][2]=(keybuf[keyout][2]<<1)|KEY_IN_3;
- keybuf[keyout][3]=(keybuf[keyout][3]<<1)|KEY_IN_4;
- for(i=0;i<4;i++)
- if((keybuf[keyout][i]&0x0F)==0x00)
- KeySta[keyout][i] = 0;
- else if((keybuf[keyout][i]&0x0F)==0xFF)
- KeySta[keyout][i] = 1;
- keyout++;
- keyout=keyout&0x03;
- switch(keyout)
- case 0:KEY_OUT_4=1;KEY_OUT_1=0;break;
- case 1:KEY_OUT_1=1;KEY_OUT_2=0;break;
- case 2:KEY_OUT_2=1;KEY_OUT_3=0;break;
- case 3:KEY_OUT_3=1;KEY_OUT_4=0;break;
- default:break;
- void LedScan()
- static unsigned char i=0;
- P0=0xFF;
- switch(i)
- case 0:ADDR2=0;ADDR1=0;ADDR0=0;i++;P0=LedBuff[0];break;
- case 1:ADDR2=0;ADDR1=0;ADDR0=1;i++;P0=LedBuff[1];break;
- case 2:ADDR2=0;ADDR1=1;ADDR0=0;i++;P0=LedBuff[2];break;
- case 3:ADDR2=0;ADDR1=1;ADDR0=1;i++;P0=LedBuff[3];break;
- case 4:ADDR2=1;ADDR1=0;ADDR0=0;i++;P0=LedBuff[4];break;
- case 5:ADDR2=1;ADDR1=0;ADDR0=1;i=0;P0=LedBuff[5];break;
- default:break;
- void InterruptTimer0() interrupt 1
- TH0=0xFC;
- TL0=0x67;
- LedScan();
- KeyScan();
