核心問題是動態(tài)掃描數(shù)碼管沒有消隱。
- #include "reg51.h"
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define DIGIT_O P0//設(shè)置P0位數(shù)碼管數(shù)據(jù)輸出端
- //定義時分秒變量
- uchar timer,seconds,minutes,hours;
- uchar timer,seconds,minutes,hours = 0;
- //共陽極數(shù)字碼表
- uchar code segCode[]={
- 0xc0,0xf9,0xa4,0xb0,
- 0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x83,
- 0xc6,0xa1,0x86,0x8e};
- //定時器中斷服務(wù)程序
- void timer0_ISR() interrupt 1
- TH0 = 0xee; // 設(shè)置定時初值,一次中斷為5ms
- TL0 = 0x00;
- timer++;
- if(timer==200) //到達(dá)1s
- timer=0;
- seconds++;
- if (seconds == 60)
- seconds = 0;
- minutes++;
- if (minutes == 60)
- minutes = 0;
- hours++;
- if (hours == 24)
- hours = 0;
- void delay(uint x) //延時xms
- uint i,j;
- for(i=x;i>0;i--)
- for(j=114;j>0;j--);
- //初始化硬件
- void init()
- TMOD = 0x01; // 定時器0工作在模式1(16位定時器)
- TL0 = 0x00;
- ET0 = 1; // 允許定時器0中斷
- EA = 1; // 允許總中斷
- TR0 = 1; // 啟動定時器0
- seconds=0;
- minutes=0;
- hours=0;
- // 顯示時間
- void display_time()
- static uchar data i;
- P3&=0xf0;//消隱
- switch(i)
- case 0: DIGIT_O=segCode[minutes/10]; break;
- case 1: DIGIT_O=segCode[minutes%10]&0x7f; break;//加點(diǎn)
- case 2: DIGIT_O=segCode[seconds/10]; break;
- case 3: DIGIT_O=segCode[seconds%10]; break;
- P3|=0x01<<i;
- i=++i%4;
- void main()
- init();
- while(1)
- display_time();
- delay(1);
復(fù)制代碼 |
