屏幕截圖 2023-11-04 230425.png (126.63 KB, 下載次數(shù): 34)
仿真圖
2023-11-4 23:04 上傳
2023-11-5 13:36 上傳
仿真圖的單片機代碼和仿真圖在附件里
- #include<reg51.h>
- #include<intrins.h> //包含頭文件
- #define uchar unsigned char
- #define uint unsigned int //宏定義
- #include "eeprom52.h"
- //////////////////////////////按鍵定義/////////////////////////////////
- sbit dj=P1^0;//電機控制端接口
- sbit DQ=P1^6;//溫度傳感器接口
- sbit key1=P3^5;//設(shè)置溫度
- sbit key2=P3^6;//溫度加
- sbit key3=P3^7;//溫度減
- sbit BEEP=P1^3; //定義蜂鳴器
- bit beep_st; //蜂鳴器間隔標志
- sbit w1=P2^4;
- sbit w2=P2^5;
- sbit w3=P2^6;
- sbit w4=P2^7; //數(shù)碼管的四個位
- uchar table[22]=
- {0x3F,0x06,0x5B,0x4F,0x66,
- 0x6D,0x7D,0x07,0x7F,0x6F,
- 0x77,0x7C,0x39,0x5E,0x79,0x71,
- 0x40,0x38,0x76,0x00,0xff,0x37};//'-',L,H,滅,全亮,n 16-21/////共陰數(shù)碼管段選//////////
- unsigned int wen_du; //溫度變量
- int shang,xia; //對比溫度暫存變量
- uchar dang; //檔位顯示
- uchar flag;
- uchar d1,d2,d3;//顯示數(shù)據(jù)暫存變量
- uchar m;
- uchar js;
- uchar cs=0;
- unsigned char s_t[];
- uchar stc[50]={"The current temperature is:"};
- //將數(shù)字轉(zhuǎn)成字符串
- void convert_uint_to_uchar_array(unsigned int wen_du, unsigned char s_t[4]) {
- int i;
- for (i = 0; i < 4; i++) {
- s_t[i] = (wen_du >> i * 8) & 0xFF;
- void delay(unsigned int xms)//延時
- unsigned char i, j;
- while(xms--)
- i = 2;
- j = 239;
- do
- while (--j);
- } while (--i);
- //發(fā)送
- void PutString(unsigned char *TXStr)
- SCON=0x40; //串行口方式1
- PCON=0x80;//增倍波特率
- TH1=0xf3; //4800波特率
- TL1=0xf3;
- TMOD=0x20; //將T1定時器方式2
- TR1=1; //啟動T1
- ES=0;
- while(*TXStr!=0)
- SBUF=*TXStr;
- while(TI==0);
- TI=0;
- TXStr++;
- ES=1;
- /*寫eeprom中*/
- void write_eeprom()
- SectorErase(0x2000); //清除扇區(qū)
- byte_write(0x2000, shang); //寫上限數(shù)值到扇區(qū)
- byte_write(0x2001, xia); //寫下限數(shù)值到扇區(qū)
- byte_write(0x2060, a_a); //寫初始變量到扇區(qū)指定位置
- /*把數(shù)據(jù)從單片機內(nèi)部eeprom中讀出來*/
- void read_eeprom()
- shang = byte_read(0x2000); //從扇區(qū)讀取上限數(shù)據(jù)
- xia = byte_read(0x2001); //從扇區(qū)讀取下限數(shù)據(jù)
- a_a = byte_read(0x2060); //從扇區(qū)讀取初始變量
- /*開機自檢傳感器eeprom初始化*/
- void init_eeprom()
- read_eeprom(); //先讀扇區(qū)的數(shù)據(jù)
- if(a_a != 1) //判斷是否是新單片機(原理:新的單片機扇區(qū)里的數(shù)據(jù)都是0,這里判斷是否不等于1。如果是不等于1,就是等于0,那就是新單片機了,就會執(zhí)行下面的上下限值初始化數(shù)值的語句,并讓a_a變成1,下次開機就會知道是用過的單片機了就會讀取EEPROM里的上下限數(shù)據(jù)了)
- shang = 30; //上限數(shù)值初始為30
- xia = 20; //下限數(shù)值初始為20
- a_a = 1; //初始值變量賦值1,下次開機就會直接讀取EEPROM內(nèi)的上下限數(shù)據(jù)
- write_eeprom(); //將初始的數(shù)據(jù)保存進單片機的EEPROM
- /*ds18b20延遲子函數(shù)(晶振12MHz )*/
- void delay_18B20(uint i)
- while(i--);
- /*ds18b20初始化函數(shù)*/
- void Init_DS18B20()
- uchar x=0;
- DQ=1; //DQ復位
- delay_18B20(8); //稍做延時
- DQ=0; //單片機將DQ拉低
- delay_18B20(80); //精確延時 大于 480us
- DQ=1; //拉高總線
- delay_18B20(14);
- x=DQ; //稍做延時后 如果x=0則初始化成功 x=1則初始化失敗
- delay_18B20(20);
- /*ds18b20讀一個字節(jié)*/
- uchar ReadOneChar()
- uchar i=0;
- uchar dat=0;
- for (i=8;i>0;i--)
- DQ=0; // 給脈沖信號
- dat>>=1;
- DQ=1; // 給脈沖信號
- if(DQ)
- dat|=0x80;
- delay_18B20(4);
- return(dat);
- /*ds18b20寫一個字節(jié)*/
- void WriteOneChar(uchar dat)
- uchar i=0;
- for (i=8;i>0;i--)
- DQ=0;
- DQ=dat&0x01;
- delay_18B20(5);
- DQ=1;
- dat>>=1;
- /*讀取ds18b20當前溫度*/
- void ReadTemperature()
- uchar a=0;
- uchar b=0;
- uchar t=0;
- Init_DS18B20();
- WriteOneChar(0xCC); // 跳過讀序號列號的操作
- WriteOneChar(0x44); // 啟動溫度轉(zhuǎn)換
- delay_18B20(100); // this message is very important
- Init_DS18B20();
- WriteOneChar(0xCC); //跳過讀序號列號的操作
- WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個寄存器) 前兩個就是溫度
- delay_18B20(100);
- a=ReadOneChar(); //讀取溫度值低位
- b=ReadOneChar(); //讀取溫度值高位
- wen_du=((b*256+a)>>4); //當前采集溫度值除16得實際溫度值
- /*按鍵*/
- void zi_keyscan()//自動模式按鍵掃描函數(shù)
- if(key1==0) //設(shè)置鍵按下
- delay(300); //延時去抖
- if(key1==0)flag=1; //再次判斷按鍵,按下的話進入設(shè)置狀態(tài)
- while(key1==0);//松手檢測 //按鍵釋放
- while(flag==1) //進入設(shè)置上限狀態(tài)
- d1=18;d2=shang/10;d3=shang%10; //顯示字母H 和上限溫度值
- if(key1==0) //判斷設(shè)置鍵是否按下
- if(key1==0)flag=2; //按鍵按下,進入設(shè)置下限模式
- if(key2==0) //加鍵按下
- shang+=5; //上限加5
- if(shang>=100)shang=100; //上限最大加到100
- }while(key2==0);//松手檢測
- write_eeprom(); //保存數(shù)據(jù)
- if(key3==0) //減鍵按下
- shang-=1; //上限減1
- if(shang<=10)shang=10; //上限最小減到10
- }while(key3==0);//松手檢測
- while(flag==2) //設(shè)置下限
- d1=17;d2=xia/10;d3=xia%10; //顯示字母L 顯示下限溫度值
- if(key1==0)
- delay(300);
- if(key1==0)flag=0;
- if(key2==0)
- delay(300);
- if(key2==0)
- xia+=5;
- if(xia>=95)xia=95;
- if(key3==0)
- delay(300);
- if(key3==0)
- xia-=1;
- if(xia<=0)xia=0;
- void zi_dong()//自動溫控模式
- d1=dang;d2=wen_du/10;d3=wen_du%10; //顯示檔位,顯示當前溫度值
- zi_keyscan();//按鍵掃描函數(shù)
- if(wen_du<xia){dang=0;
- if(cs==0){
- BEEP=0;
- delay(500);
- BEEP=1;
- delay(500);
- }else{ BEEP=1;}
- cs=1;
- }//低于下限 檔位為0 電機停止
- if((wen_du>=xia)&&(wen_du<=shang))//溫度大于下限,小于上限 1擋
- {dang=1;cs=0;}
- if(wen_du>shang){dang=2;}//溫度大于上限,2檔
- void init() //定時器初始化函數(shù)
- TMOD=0x01; //定時器0工作方式1
- TH0=0xf8;
- TL0=0x30; //定時器初值5ms
- ET0=1; //打開定時器0中斷允許
- TR0=1; //打開定時器0定時器開關(guān)
- EA=1; //打開中斷系統(tǒng)總開關(guān)
- void main() //主函數(shù)
- uchar j;
- dj=0; //電機開
- init_eeprom(); //開始初始化保存的數(shù)據(jù)
- for(j=0;j<80;j++) //先讀取溫度值,防止開機顯示85
- ReadTemperature();
- init();
- while(1) //進入while循環(huán)
- if(js>=50) //當js在定時器里加到50次時(js加一次是20ms,加到50次就是1000ms,也就是1秒讀取一次溫度)
- ReadTemperature(); //讀取溫度值
- js=0; //定時讀取溫度的變量js清零,重新計時下次讀取溫度
- zi_dong();//判斷當前需要哪一個檔位
- 控制占空比原理:
- 定時器每5ms控制變量m加一,當m加到4時,將m清零。
- 也就是占空比的一個周期是5ms*4=20ms,頻率就是50Hz。
- 因為m是加四次是一個周期,也就是加一次占空比是加25%。
- 下面程序里if(m<=3)dj=1;else dj=0;就是讓dj高電平的時間是m加3次的時間,而dj為低電平的時間就是加第四次的時間,所以占空比就是3/4就是75%
- void T0_TIME() interrupt 1 //定時器工作函數(shù),用于PWM工作
- TH0=0xf8;
- TL0=0x30; //定時器賦初值5ms
- m++; //5ms,m加一
- switch(dang) //判斷檔位
- case 0:dj=0;break; //0檔,控制電機停止
- case 1:if(m<=3)dj=1;else dj=0;break;//控制電機以75%占空比轉(zhuǎn)動
- case 2:dj=1;break; //2檔,控制電機100%占空比轉(zhuǎn)動
- default:; //其他情況,直接跳出
- switch(m) //判斷m的數(shù)值
- case 1: //m為1時
- w4=1;P0=table[d1];w1=0; break; //關(guān)閉低四位數(shù)碼管位選;P0口輸出對應(yīng)數(shù)字的段碼;打開第一位數(shù)碼管位選
- case 2:
- w1=1;P0=table[16];w2=0; break; //關(guān)閉低一位數(shù)碼管位選;P0口輸出對應(yīng)數(shù)字的段碼;打開第二位數(shù)碼管位選
- case 3:
- w2=1;P0=table[d2];w3=0; break; //關(guān)閉低二位數(shù)碼管位選;P0口輸出對應(yīng)數(shù)字的段碼;打開第三位數(shù)碼管位選
- case 4:
- w3=1;P0=table[d3];w4=0;m=0;if(js<50)js++;break; //關(guān)閉低三位數(shù)碼管位選;P0口輸出對應(yīng)數(shù)字的段碼;打開第四位數(shù)碼管位選
- //js變量小于50時,就讓js加,加到50后,主函數(shù)里就會執(zhí)行一次讀取溫度函數(shù)
- default:; //其他情況時跳出
仿真程序:
仿真程序.7z
(124.42 KB, 下載次數(shù): 52)
2023-11-5 13:40 上傳
仿真+keil工程 下載積分: 黑幣 -5
