查看: 2156|回復(fù): 4
N32G455VEL7芯片如何通過DMA控制I2C寫eeprom
ID:1062719 發(fā)表于 2023-10-30 15:45 | 顯示全部樓層 |閱讀模式
芯片是N32G455VEL7,工具是keil5,用DMA來控制I2C寫eeprom 程序如下
void I2C_EE_PageWrite(u8* pBuffer, u16 WriteAddr, u16 NumByteToWrite)
        DMA_InitType  DMA_InitStructure;
        /* enter rountine safely */
        /* DMA initialization */
        DMA_DeInit(DMA1_CH4);
        DMA_InitStructure.PeriphAddr = (u32)&I2Cx->DAT;
        DMA_InitStructure.MemAddr = (u32)pBuffer;
        DMA_InitStructure.Direction = DMA_DIR_PERIPH_DST
        DMA_InitStructure.BufSize = NumByteToWrite
        DMA_InitStructure.PeriphInc = DMA_PERIPH_INC_DISABLE;
        DMA_InitStructure.DMA_MemoryInc = DMA_MEM_INC_ENABLE;
        DMA_InitStructure.PeriphDataSize = DMA_MemoryDataSize_Byte;
        DMA_InitStructure.MemDataSize = DMA_MemoryDataSize_Byte;
        DMA_InitStructure.CircularMode = DMA_MODE_NORMAL;
        DMA_InitStructure.Priority = DMA_PRIORITY_VERY_HIGH;
        DMA_InitStructure.Mem2Mem = DMA_M2M_DISABLE;
        DMA_Init(DMA1_CH4, &DMA_InitStructure);
        I2C_ConfigAck(I2Cx, ENABLE);
        I2C_GenerateStart(I2Cx, ENABLE);
        while (!I2C_CheckEvent(I2Cx, I2C_EVT_MASTER_MODE_FLAG)) // EV5
        I2C_SendAddr7bit(I2Cx, EEPROM_ADDR, I2C_DIRECTION_SEND);
        while (!I2C_CheckEvent(I2Cx, I2C_EVT_MASTER_TXMODE_FLAG)) // EV6
        I2C_SendData(I2Cx, WriteAddr);//地址
        while (!I2C_CheckEvent(I2Cx, I2C_EVT_MASTER_DATA_SENDED))
        I2C_EnableDMA(I2Cx, ENABLE);
        DMA_EnableChannel(DMA1_CH4, ENABLE);
        while (!DMA_GetFlagStatus(DMA1_FLAG_TC4, DMA1))
        I2C_GenerateStop(I2Cx, ENABLE);
        I2C_EE_WriteOnePageCompleted();
我已經(jīng)將數(shù)據(jù)發(fā)送到數(shù)據(jù)寄存器中了,然后怎么寫到eeprom中呢?不應(yīng)該自動寫嗎?難道我要通過 I2C_SendData()函數(shù)循環(huán)寫入?
ID:1062719 發(fā)表于 2023-11-2 15:06 | 顯示全部樓層
要把寄存器的地址WriteAddr值也放在buf中
ID:1062719 發(fā)表于 2023-11-2 15:17 | 顯示全部樓層
我這里不行的問題是我傳進來的地址是16位的,我只把低8位的地址發(fā)到data中去了
ID:883242 發(fā)表于 2023-11-2 22:55 | 顯示全部樓層
這兩句能編譯通過???
ID:1062719 發(fā)表于 2023-11-3 09:38 | 顯示全部樓層
Hephaestus 發(fā)表于 2023-11-2 22:55
        DMA_InitStructure.BufSize = NumB ...
這個肯定編譯不過,這個是我在放上來時,刪除后面測試時的其他參數(shù)時刪除多了
