查看: 3298|回復(fù): 13
單片機(jī)LCD1602串口可以顯示,并口試過很多次都顯示不了?
大佬們,看看小弟這個怎么搞呀,串口可以顯示,并口試過很多次都顯示不了這是我的代碼:
#include <STC15F2K60S2.H>
#include "intrins.h"
#include "string.h"
#define u8 unsigned char
#define u16 unsigned int
#define LCD12864_DATA P0
sbit LCD12864_PSB = P1^3;
sbit LCD12864_RS = P1^0;
sbit LCD12864_RW = P1^1;
sbit LCD12864_EN = P1^2;
//sbit LCD12864_RST = P5^4;
void Delay1us(u16 count)     //@11.0592MHz
    while(count-- != 0)
        _nop_();
        _nop_();
        _nop_();
u8 lcd12864_check_busy()//檢測是否空閑
    u8 temp;
    LCD12864_DATA = 0xff;
    LCD12864_RS = 0;//并行的指令
    LCD12864_RW = 1;//并行讀寫選擇信號,1為讀,0為寫
    LCD12864_EN = 1;//使能信號,1為有效
    Delay1us(1000);
    temp = LCD12864_DATA;
    LCD12864_EN = 0;
    return temp&0x80;
void lcd12864_write_command(u8 cmd)//寫命令
    while(lcd12864_check_busy());
    LCD12864_RS = 0;
    LCD12864_RW = 0;
    LCD12864_EN = 1;
    Delay1us(1000);
    LCD12864_DATA = cmd;
    LCD12864_EN = 0;
void lcd12864_write_data(u8 dat)//寫數(shù)據(jù)
    LCD12864_RS = 1;
    LCD12864_RW = 0;
    LCD12864_EN = 1;
    Delay1us(1000);
    LCD12864_DATA = dat;
    LCD12864_EN = 0;
void lcd12864_init()
    LCD12864_PSB = 1;
    lcd12864_write_command(0x01);//1.清屏命令
    Delay1us(1000);
    lcd12864_write_command(0x02);//2.位址歸位
    Delay1us(1000);
    lcd12864_write_command(0x0C);//4.顯示狀態(tài) 開
    Delay1us(1000);
    lcd12864_write_command(0x80);//8.設(shè)定DDRAM位址
    Delay1us(1000);
    lcd12864_write_command(0x34);//擴(kuò)充功能設(shè)定——擴(kuò)充指令集動作
    Delay1us(1000);
    lcd12864_write_command(0x30);//擴(kuò)充功能設(shè)定——基本指令集動作
    Delay1us(1000);
void lcd12864_display_pos(u8 X , u8 Y)//選擇第幾行Y;第幾列X(則加上X)
    u8 addr;
    if(Y == 0)
        addr = 0x80;
    if(Y == 1)
        addr = 0x90;
    if(Y == 2)
        addr = 0x88;
    if(Y == 3)
        addr = 0x98;
    addr = addr+X;
    lcd12864_write_command(addr);
void lcd12864_show_char(u8 X , u8 Y , char sign)//顯示一個字符
    lcd12864_display_pos(X,Y);
    lcd12864_write_data(sign);
void lcd12864_show_string(u8 X , u8 Y , char string[])//顯示一個字符串
    while(*string != '\0')
        lcd12864_write_data(*string++);
    P1M1 = 0; P1M0 = 0;
    //P5M0 = 0;
    lcd12864_init();
    lcd12864_show_string(0,0,"某某某某大學(xué)");
    lcd12864_show_string(0,1,"地球科學(xué)學(xué)院");
    lcd12864_show_string(0,2,"21環(huán)境01班");
    lcd12864_show_char(0,3,0x02);
    lcd12864_show_string(1,3,"小明呀");
    lcd12864_show_char(7,3,0x02);
    while(1);
ID:220661 發(fā)表于 2023-10-2 08:05 | 只看該作者
先查查液晶模塊的對比度電位器,啥?沒有電位器?
ID:857072 發(fā)表于 2023-10-2 09:08 來自觸屏版 | 只看該作者
人家串口可以顯示跟硬件還有啥關(guān)系啊
ID:1012735 發(fā)表于 2023-10-2 10:53 | 只看該作者
1.去掉所有CheckBusy檢查,可能會死循環(huán)導(dǎo)致開機(jī)黑屏
2.初始化等命令錯誤
include.zip
3.78 KB, 下載次數(shù): 4
參考程序
ID:1094811 發(fā)表于 2023-10-2 11:08 來自觸屏版 | 只看該作者
屏后面有個選擇串、并的設(shè)置,看一下
ID:105534 發(fā)表于 2023-10-2 11:30 | 只看該作者
線有沒有漏接,多接的;我也有一塊12864屏,按開發(fā)板的圖接不行,后來按說明書重接就好了
ID:1085441 發(fā)表于 2023-10-2 12:33 | 只看該作者
查查并口時序?qū)Σ粚?仔?xì)看手冊。
還有,我用的液晶有INTEL和MOTOROLA兩種接口,請看看是不是接口選擇不對?
ID:1094940 發(fā)表于 2023-10-2 13:12 | 只看該作者
hy47566398 發(fā)表于 2023-10-2 10:53
2.初始化等命令錯誤
哥,我屏蔽了,但還是沒有顯示。
ID:1094940 發(fā)表于 2023-10-2 13:13 | 只看該作者
Ppp0011010 發(fā)表于 2023-10-2 11:30
需要接的都接上了,但是,還是沒有顯示,,我的代碼應(yīng)該沒問題吧
ID:771630 發(fā)表于 2023-10-2 16:26 | 只看該作者
不要檢測BUSY,PSB要根據(jù)手冊選擇相對應(yīng)的電平
ID:35873 發(fā)表于 2023-10-3 01:41 | 只看該作者
可能這個屏默認(rèn)串口  并口要改動下串并選擇的那個電阻  你也可以量下PSB引腳電壓  如果串是低電平 那么并就要高電平  排除這個就是程序了 或許延時不對  試試
ID:195496 發(fā)表于 2023-10-3 07:54 | 只看該作者
屏的模式要改一下才能用
ID:1055614 發(fā)表于 2023-10-3 14:02 | 只看該作者
在選擇串并口時可以通過程序選擇高低電平來完成。
第一種通過PSC口高低電平來選擇
第二種也可以通過液晶屏背面 PCB 上面絲印 S 短接為串口,P 點(diǎn)短接為并口
ID:1089601 發(fā)表于 2023-10-3 18:07 | 只看該作者
第6腳DB0的狀態(tài)是串口和并口的設(shè)置,應(yīng)該檢查設(shè)置一下。有的屏在電路板上有用焊錫連接的焊盤用于切換串口或并口
