查看: 3288|回復(fù): 7
動(dòng)態(tài)設(shè)置軟件I2C引腳速度變慢,請(qǐng)教大神有沒有更好的方法
ID:1088898 發(fā)表于 2023-9-28 21:22 | 顯示全部樓層 |閱讀模式
由于項(xiàng)目需要跟多個(gè)I2C從機(jī)通訊,從機(jī)地址相同又無法修改,只能將從機(jī)接到不同的IO
所以我寫了如下代碼來動(dòng)態(tài)設(shè)置I2C引腳
#include <STC32G.H>
#define        GPIO_PIN_SET_H                        1
#define        GPIO_PIN_SET_L                        0
u8 I2C_SCL_PIN;
u8 I2C_SDA_PIN;
void Delay5us()                //@22.1184MHz
        unsigned long edata i;
        _nop_();
        _nop_();
        i = 26UL;
        while (i) i--;
void GPIO_WritePin(u8 Pin, bit value)        //設(shè)置引腳值
        switch(Pin)
                case 1: P20 = value; break;
                case 2: P21 = value; break;
                case 3: P22 = value; break;
                case 4: P23 = value; break;
                case 5: P24 = value; break;
                case 6: P25 = value; break;
                case 7: P26 = value; break;
                case 8: P27 = value; default: break;
bit GPIO_ReadPin(u8 Pin)                        //獲取引腳值
        bit value;
        switch(Pin)
                case 1: value = P20; break;
                case 2: value = P21; break;
                case 3: value = P22; break;
                case 4: value = P23; break;
                case 5: value = P24; break;
                case 6: value = P25; break;
                case 7: value = P26; break;
                case 8: value = P27; default: break;
        return value;
void SET_SCL_H(void)
        GPIO_WritePin(I2C_SCL_PIN, GPIO_PIN_SET_H);
void SET_SCL_L(void)
        GPIO_WritePin(I2C_SCL_PIN, GPIO_PIN_SET_L);
void SET_SDA_H(void)
        GPIO_WritePin(I2C_SDA_PIN, GPIO_PIN_SET_H);
void SET_SDA_L(void)
        GPIO_WritePin(I2C_SDA_PIN, GPIO_PIN_SET_L);
bit GET_SDA(void)
   return GPIO_ReadPin(I2C_SDA_PIN);
void SET_I2C_Pin(u8 SCL_PIN, u8 SDA_PIN)
        I2C_SCL_PIN = SCL_PIN;
        I2C_SDA_PIN = SDA_PIN;
        WTST = 0x00;
        CKCON = 0x00;
        EAXFR = 1;
        P2M0 = 0x00;
        P2M1 = 0x00;
        SET_I2C_Pin(0,1);        //設(shè)置SCL引腳為P20,SDA引腳為P21
                SET_SDA_H();  //通過函數(shù)給IO賦值
                //P21 = 1;        //直接給IO賦值
                Delay5us();
                SET_SDA_L();
                //P21 = 0;
                Delay5us();
實(shí)驗(yàn)結(jié)果
通過函數(shù)給IO賦值只有80KHZ
如果直接給IO賦值頻率有97.6KHZ,差異太大,請(qǐng)大神幫忙看下代碼有沒有優(yōu)化空間
ID:161164 發(fā)表于 2023-9-29 09:10 | 顯示全部樓層
直接用GPIO_WritePin/GPIO_ReadPin
不要再嵌套
想再快可以用宏定義
  1. #define GPIO_W(x,y) (y)?(P2|=(1<<x)):(P2&=~(1<<x))
  2. #define GPIO_R(x) (bit)(P2&(1<<x))
ID:771630 發(fā)表于 2023-9-29 13:49 | 顯示全部樓層
硬件IIC +模擬開關(guān)或者PCA954x,1MHz/400KHz的速度,比軟件IIC快了不知道多少倍
ID:1094811 發(fā)表于 2023-9-29 14:30 | 顯示全部樓層
調(diào)用函數(shù)是需要指令時(shí)間的,給IO口值也是需要指令時(shí)間,直接給地址給值是最快的。
ID:384109 發(fā)表于 2023-9-29 16:01 | 顯示全部樓層
直接對(duì)引腳操作,不要用庫函數(shù)
ID:624769 發(fā)表于 2023-9-30 16:13 來自觸屏版 | 顯示全部樓層
去掉,Delay5us();
ID:1088898 發(fā)表于 2023-10-1 12:03 | 顯示全部樓層
lkc8210 發(fā)表于 2023-9-29 09:10
不要再嵌套
感謝 lkc8210
試了不嵌套速度也是不理想,用宏定義勉強(qiáng)可以達(dá)到,測(cè)試了12小時(shí),讀取I2C數(shù)據(jù)都正常,感謝!
感謝大家的回復(fù),問題已解決,感謝 lkc8210
