查看: 2245|回復(fù): 0
怎么讓單片機(jī)計時器改成倒計時,可以通過獨立按鍵設(shè)置倒計時(用的是普中板)
ID:1094758 發(fā)表于 2023-9-28 14:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
typedef unsigned int u16;
typedef unsigned char u8;
#define KEY_PRESS1 1
#define KEY_PRESS2 2
#define KEY_PRESS3 3
#define KEY_PRESS4 4
#define KEY_UNPRESS 0
#define SMG_SORT P0
#define LED_SORT P2
void delay_10us(u16 ten_us)
     while(ten_us--);
u8 NUM_SMG[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                0x7f,0x6f,0x40};
u8 SELECT_SMG[] = {0x00,0x04,0x08,0x0c,0x10,0x14,0x18,0x1c};
void time0_init()
    TMOD |= 0x01;  //設(shè)置工作方式;定時器0的工作模式1
    TH0 = 0xFC;
    TL0 = 0x18;
    EA = 1;        //中斷總開關(guān)
    ET0 = 1;    //定時器0允許位
    TR0 = 1;    //打開定時器0
sbit LED1 = P2^0;
static u16 n = 0;
sbit KEY1 = P3^1;
sbit KEY2 = P3^0;
sbit KEY3 = P3^2;
sbit KEY4 = P3^3;
static u8 hour = 0;
static u8 min = 0;
static u8 time = 0;
static u8 scan_state = 0;
void Show_time(u8 ti, u8 loc)
    u8 a = ti/10;
    u8 b = ti%10;
    SMG_SORT = NUM_SMG;
P2 = SELECT_SMG[loc];
    delay_10us(100);
    SMG_SORT = NUM_SMG[a];
    P2 = SELECT_SMG[loc+1];
    delay_10us(100);
void show_line()
    SMG_SORT = 0x40;
    P2 = SELECT_SMG[2];
    delay_10us(100);
    SMG_SORT = 0x40;
    P2 = SELECT_SMG[5];
    delay_10us(100);
u8 key_scan() // 返回按鍵的狀態(tài)  0  1  2  3  4
        if(scan_state==0&KEY1==0||KEY2==0||KEY3==0||KEY4==0)
        delay_10us(1000);
        scan_state = 1;
        if(KEY1==0 )return 1;
        if(KEY2==0 )return 1;
        if(KEY3==0 )return 1;
        if(KEY4==0 )return 1;
         else if(KEY1==1&KEY2==1&KEY3==1&KEY4==1)
          scan_state=0;
          return 1;
void time_ADD()
    if(KEY4==0)
        delay_10us(20);
        while(!KEY4);
            Show_time();
            time++;
            if(time>59)
                min++;
                time = 0;
                if(min>59)
                    hour++;
                    min = 0;
void time_SUB()
    if(KEY3==0)
        delay_10us(20);
        while(!KEY3);        //判斷按鍵是否松手
            Show_time();
            if(min>0||time>0)
                time--;
                if(time==0)
                    min--;
                    time=59;
    time0_init();
    LED1 =0;
        Show_time(time,0);
        Show_time(min,3);
        Show_time(hour,6);
        show_line();
void time0() interrupt 1
    //注:每次進(jìn)入中斷意味著定時/和計數(shù)器已經(jīng)溢出,若要繼續(xù)重復(fù)工作,需要重新賦值
    TH0 = 0xFC;
    TL0 = 0x18;
    n++;
    if(n==1000)
        n = 0;
        time += 1;
        if(time >= 59)
            time = 0;
            min +=1;
            if(min == 60)
                min = 0;
                hour += 1;
                if(hour == 24)
                    hour = 0;
