查看: 2568|回復: 0
MAX6675_STM32單片機程序(OLED顯示+熱電偶+藍牙+繼電器)
ID:316613 發表于 2023-8-11 09:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
功能如標題已經測試通過
  1. /*********************************************************************************
  2. * 文件名  :main.c
  3. * 描述    :通過stm32的spi1讀取max6675的溫度值,并通過uart1發送出來
  4. *
  5. * 實驗平臺:STM32開發板
  6. * 庫版本  :ST3.0.0
  7. * 硬件連接: ------------------------------------
  8. *           |PA6-SPI1-MISO:MAX6675-SO          |
  9. *           |PA7-SPI1-MOSI:MAX6675-SI          |
  10. *           |PA5-SPI1-SCK :MAX6675-SCK         |
  11. *           |PA4-SPI1-NSS :MAX6675-CS          |
  12. *            ------------------------------------
  13. **********************************************************************************/
  14. #include "stm32f10x.h"
  15. #include "usart1.h"
  16. #include "led.h"
  17. #include "oled.h"
  18. #include "hc05.h"
  19. #include "usart3.h"
  20. #include "string.h"
  21. #define         MAX6675_CS                         GPIO_Pin_4
  22. #define         MAX6675_CSL()                GPIOA->BRR = MAX6675_CS;
  23. #define         MAX6675_CSH()                GPIOA->BSRR = MAX6675_CS;
  24. /*
  25. * 函數名:SPI1_Init
  26. * 描述  MAX6675 接口初始化
  27. * 輸入  :無
  28. * 輸出  :無
  29. * 返回  :無
  30. */
  31. void SPI_MAX6675_Init(void)
  32. {
  33.         GPIO_InitTypeDef GPIO_InitStructure;
  34.         SPI_InitTypeDef  SPI_InitStructure;
  35.
  36.         /* 使能 SPI1 時鐘 */
  37.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1, ENABLE);
  38.         /* ---------通信I/O初始化----------------
  39.          * PA5-SPI1-SCK :MAX6675_SCK
  40.          * PA6-SPI1-MISO:MAX6675_SO
  41.          * PA7-SPI1-MOSI:MAX6675_SI
  42.          */
  43.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  44.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  45.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        // 復用輸出
  46.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  47.         /* ---------控制I/O初始化----------------*/
  48.         /* PA4-SPI1-NSS:MAX6675_CS */                                                        // 片選
  49.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  50.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  51.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                // 推免輸出
  52.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  53.         GPIO_SetBits(GPIOA, GPIO_Pin_4);                                                // 先把片選拉高,真正用的時候再拉低
  54.         /* SPI1 配置 */
  55.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  56.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  57.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  58.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  59.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  60.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  61.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
  62.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  63.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  64.         SPI_Init(SPI1, &SPI_InitStructure);
  65.
  66.
  67.         /* 使能 SPI1  */
  68.         SPI_Cmd(SPI1, ENABLE);
  69. }
  70. /*
  71. *
  72. *
  73. *
  74. */
  75. unsigned char MAX6675_ReadByte(void)
  76. {
  77.
  78.         /* Loop while DR register in not emplty */
  79.         while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);
  80.
  81.         /* Send byte through the SPI1 peripheral */
  82.         SPI_I2S_SendData(SPI1, 0xff);
  83.
  84.         /* Wait to receive a byte */
  85.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  86.
  87.         /* Return the byte read from the SPI bus */
  88.         return SPI_I2S_ReceiveData(SPI1);
  89. }
  90. void HC05_Role_Show(void)
  91. {
  92.         if(HC05_Get_Role()==1)printf("ROLE:Master");        //主機
  93.         else printf("ROLE:Slave ");                                         //從機
  94. }
  95. //顯示ATK-HC05模塊的連接狀態
  96. void HC05_Sta_Show(void)
  97. {
  98.         if(HC05_LED)printf("STA:Connected ");                        //連接成功
  99.         else printf("STA:Disconnect");                                 //未連接
  100. }
  101. /*
  102. * 函數名:main
  103. * 描述  :主函數
  104. * 輸入  :無
  105. * 輸出  :無
  106. */
  107. main (void)
  108. {
  109.         unsigned int t,i;
  110.         unsigned char c;
  111.         unsigned char flag;
  112.         float temprature;
  113.
  114.          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  115.
  116.         /* 配置系統時鐘為72M */
  117.         SystemInit();
  118.      LED_Init();
  119.         /* MAX6675 SPI 接口初始化 */
  120.         SPI_MAX6675_Init();
  121.         USART1_Config();
  122.         OLED_IIC_Init();
  123.             LED0=LED1=0 ;
  124.
  125.         //OLED_ShowNum(0,1,6666666,8,16);
  126.         OLED_P8x16Str(0,0,"temp:");
  127.
  128.         HC05_Init();
  129. //                 while(HC05_Init())                 //初始化ATK-HC05模塊
  130. //        {
  131. //OLED_P8x16Str(2,2,"xxxx");
  132. //        }
  133. OLED_P8x16Str(3,3,"222");
  134.         HC05_Role_Show();
  135. USART3_RX_STA=0;
  136.         while(1)
  137.         {
  138.
  139.                 MAX6675_CSL();
  140.                 c = MAX6675_ReadByte();
  141.                 i = c;
  142.                 i = i<<8;
  143.                 c = MAX6675_ReadByte();
  144.                 MAX6675_CSH();
  145.
  146.                 i = i|((unsigned int)c);                        //i是讀出來的原始數據
  147.                 flag = i&0x04;                                                //flag保存了熱電偶的連接狀態
  148.                 t = i<<1;
  149.                 t = t>>4;
  150.                 temprature = t*0.25;
  151.
  152.                 if(i!=0)                                                        //max6675有數據返回
  153.                 {
  154.                         if(flag==0)                                                //熱電偶已連接
  155.                         {
  156.                                 printf("原始數據是:%04X,  當前溫度是:%4.2f。\r\n",i,temprature);
  157.                                            OLED_ShowNum(17,1,temprature,4,16);
  158. //                                if(temprature< 25)    //溫度小于25°加熱,
  159. //                                {
  160. //                                         LED0=1;// 加熱
  161. //                                LED1=0; // 關閉風扇
  162. //                                }
  163. //                                else if (temprature >30)   //溫度高于30都 散熱
  164. //                                {
  165. //                                LED1=1;   //打開風扇
  166. //                                LED0=0;        //關閉加熱
  167. //                                }
  168.                         }
  169.                         else                                                        //熱電偶掉線
  170.                         {
  171.                                 printf("未檢測到熱電偶,請檢查。\r\n");
  172.                         }
  173.
  174.                 }
  175.                 else        //max6675沒有數據返回
  176.                 {
  177.                         printf("max6675沒有數據返回,請檢查max6675連接。\r\n");
  178.                 }
  179.                 for(i=0;i<0x2fffff;i++);                        //max6675的轉換時間是0.2秒左右,所以兩次轉換間隔不要太近
  180.         }
  181. }
原理圖:無
仿真:無
程序: 程序.7z (182.89 KB, 下載次數: 47)
收藏收藏2 分享淘帖 頂 踩
