查看: 3213|回復: 7
C語言指針的相關(guān)問題 程序分析
回帖獎勵 20 黑幣 回復本帖可獲得 20 黑幣獎勵! 每人限 1 次
ID:1079270 發(fā)表于 2023-8-7 10:14 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
bit flag500ms = 0;   //500ms定時標志
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
//待顯示的第一行字符串
unsigned char code str1[] = "Kingst Studio";
//待顯示的第二行字符串,需保持與第一行字符串等長,較短的行可用空格補齊
unsigned char code str2[] = "Let's move...";
void ConfigTimer0(unsigned int ms);
void InitLcd1602();
void LcdShowStr(unsigned char x, unsigned char y,
                unsigned char *str, unsigned char len);
    unsigned char i;
    unsigned char index = 0;  //移動索引
    unsigned char pdata bufMove1[16+sizeof(str1)+16]; //移動顯示緩沖區(qū)1
    unsigned char pdata bufMove2[16+sizeof(str2)+16]; //移動顯示緩沖區(qū)2
    EA = 1;            //開總中斷
    ConfigTimer0(10);  //配置T0定時10ms
    InitLcd1602();     //初始化液晶
    //緩沖區(qū)開頭一段填充為空格
    for (i=0; i<16; i++)
        bufMove1[ i] = ' ';
        bufMove2[ i] = ' ';
    //待顯示字符串拷貝到緩沖區(qū)中間位置
    for (i=0; i<(sizeof(str1)-1); i++)
        bufMove1[16+i] = str1[ i];
        bufMove2[16+i] = str2[ i];
    //緩沖區(qū)結(jié)尾一段也填充為空格
    for (i=(16+sizeof(str1)-1); i<sizeof(bufMove1); i++)
        bufMove1[ i] = ' ';
        bufMove2[ i] = ' ';
    while (1)
        if (flag500ms)  //每500ms移動一次屏幕
            flag500ms = 0;
            //從緩沖區(qū)抽出需顯示的一段字符顯示到液晶上
            LcdShowStr(0, 0, bufMove1+index, 16);
            LcdShowStr(0, 1, bufMove2+index, 16);
            //移動索引遞增,實現(xiàn)左移
            index++;
            if (index >= (16+sizeof(str1)-1))
            {   //起始位置達到字符串尾部后即返回從頭開始
                index = 0;
/* 配置并啟動T0,ms-T0定時時間 */
    unsigned long tmp;  //臨時變量
    tmp = 11059200 / 12;      //定時器計數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計算所需的計數(shù)值
    tmp = 65536 - tmp;        //計算定時器重載值
    tmp = tmp + 12;           //補償中斷響應(yīng)延時造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
/* 等待液晶準備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標位置,(x,y)-對應(yīng)屏幕上的字符坐標 */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應(yīng)屏幕上的起始坐標,
   str-字符串指針,len-需顯示的字符長度 */
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (len--)         //連續(xù)寫入len個字符數(shù)據(jù)
        LcdWriteDat(*str++);  //先取str指向的數(shù)據(jù),然后str自加1
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標關(guān)閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
/* T0中斷服務(wù)函數(shù),定時500ms */
void InterruptTimer0() interrupt 1
    static unsigned char tmr500ms = 0;
    TH0 = T0RH;  //重新加載重載值
    TL0 = T0RL;
    tmr500ms++;
    if (tmr500ms >= 50)
        tmr500ms = 0;
        flag500ms = 1;
問:bufMove1+index代入void LcdShowStr(unsigned char x, unsigned char y,
                unsigned char *str, unsigned char len)的 LcdWriteDat(*str++)的流程是什么?
ID:908826 發(fā)表于 2023-8-7 18:41 | 顯示全部樓層
先執(zhí)行間接運算操作,然后指針值加一指向下一個內(nèi)存地址
ID:1079566 發(fā)表于 2023-8-7 19:07 | 顯示全部樓層
流程: 類似如下
LcdWriteDat( bufMove1[index])
index++ (這里只是展示效果,實際不影響函數(shù)外的index)
或:
*str = & bufMove1[index]  // 或 *str= bufMove1 + index
LcdWriteDat(*str)
str++
ID:883242 發(fā)表于 2023-8-7 21:38 | 顯示全部樓層
原來你是不知道下面兩句話是完全等效的。
  1. bufMove1+index
  1. &bufMove1[index]
bufMove1作為一個數(shù)組名,本身就是指針常量,+index運算后得到一個指針變量,當然可以當成unsigned char *類型的參數(shù)傳遞進去。
而bufMove1[index],這就不是一個指針了,而是一個unsigned char類型的數(shù)據(jù),必須在前面加&才能變成unsigned char *類型的參數(shù)傳遞進去。
參與人數(shù) 1黑幣 +12 收起 理由
xnysfh + 12 很給力!
ID:844772 發(fā)表于 2023-8-8 08:36 | 顯示全部樓層
當bufMove1+index代入void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str, unsigned char len)的LcdWriteDat(*str++)時,流程如下:
LcdSetCursor(x, y):設(shè)置LCD光標起始地址為(x, y)。
進入while循環(huán),len--:len是要顯示的字符數(shù)量,每循環(huán)一次,len減1。
LcdWriteDat(*str++):從str指向的地址取出一個字符數(shù)據(jù),然后str自增1,指向下一個字符。將取出的字符數(shù)據(jù)寫入LCD的數(shù)據(jù)寄存器,顯示在LCD屏幕上。
重復步驟2和步驟3,直到len減到0,即所有字符都顯示完畢。
實際上,bufMove1+index代入*LcdShowStr(unsigned char x, unsigned char y, unsigned char *str, unsigned char len)的LcdWriteDat(*str++)時,bufMove1+index的內(nèi)容會被當作字符串的起始地址,而不是單個字符的地址。因此,函數(shù)會顯示從bufMove1+index開始的len個字符。
xnysfh + 12 很給力!
ID:1079270 發(fā)表于 2023-8-8 11:25 | 顯示全部樓層
Hephaestus 發(fā)表于 2023-8-7 21:38
原來你是不知道下面兩句話是完全等效的。
非常感謝,沒想到我的問題這么抽象還能明白我想表達的意思,不愧是大佬
ID:372579 發(fā)表于 2023-8-12 09:11 | 顯示全部樓層
51大神好多,逛逛就可以學到很多知識
ID:385774 發(fā)表于 2023-8-14 11:01 | 顯示全部樓層
原來你是不知道下面兩句話是完全等效的。
受教了。。。。謝謝
