查看: 3468|回復: 3
關于輝芒微單片機觸摸程序
ID:604515 發表于 2023-8-4 16:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是一款輝芒微的觸摸芯片,現在在官方的調試軟件里,導出到工程,現在不會操作了,怎么樣寫:觸摸一下,LED1亮,觸摸5秒,LED2亮,
  * @file                main.c
  * @author              FMD AE
  * @brief               Device: FT62F28X
  *                 Memory: Flash 8KX14b, EEPROM 128X8b, SRAM 616X8b
  *                 主函數,touch庫的使用示例
  * @version             V1.0.0
  * @data                    2023-4-19
//include definition
#include        "SYSCFG.h";
#include        "touch.h";
#include        "led.h";
#include        "uart.h"
//Variable definition
unsigned char strongest = 0; //demo_test
unsigned char Sav_strongest = 0; //demo_test
unsigned long Sav_single,single;
unsigned char temp = 0;
void ConmunicateToPc(void);
void TSC_Scan(void);
void SleepProcess(void);
void Get_Key_Demo(void);
  * @brief  DelayUs program
  * @Description  延時函數
  * @param  time
  * @note
  * @retval  None
void DelayUs(unsigned int Time)
        unsigned int a;
        for(a=0;a<Time;a++)
                NOP();
*        函數名稱:DelayMs
*        功能:   短延時函數
*        輸入參數:Time延時時間長度 延時時長Time ms
*        返回參數:無
void DelayMs(unsigned char Time)
        unsigned char a,b;
        for(a=0;a<Time;a++)
                for(b=0;b<5;b++)
                         DelayUs(197); //快1%
  * @brief  interrupt ISR        program
  * @Description  中斷入口函數 ,注意BANK的切換
  * @param  None
  * @note
  * @retval  None
void interrupt ISR(void)
                //進中斷時bank保護
                if(AUXPGE==0) //BANK0-3
                        temp = 0;
                        AUXPGE = 0;
                        temp = 1;
        //進中斷時bank保護恢復
                if(AUXPGE==0)//BANK0-3
                        AUXPGE = temp ;
                        AUXPGE = 0;
                        AUXPGE = temp ;
  * @brief  Initialize_Communication program
  * @Description  應用程序應在系統初始化時必須把它們寫為合適的值,
  *                        特別是各種使能位,以免產生不必要的中斷及額外功耗。
  * @param  None
  * @note
  * @retval  None
void Initialize_Communication(void)
  //I2C 模塊
  I2CCR1 = 0;
  I2CCR2 = 0;
  I2CADDR = 0;
  I2CCCR = 0;
  I2CDAT = 0;
  I2CISR = 0;
  //SPI 模塊
  SPIDAT = 0;
  SPICR0 = 0;
  SPICFG = 0;
  SPISCR = 0;
  SPICRCP = 0;
  SPITXCRC = 0;
  SPIRXCRC = 0;
  SPIIER = 0;
  SPICR1 = 0;
  SPISTAT = 0;
  //UART 模塊
  UR0DATL = 0;
  UR0DATH = 0;
  UR0CR1 = 0;
  UR0CR2 = 0;
  UR0BRRL = 0;
  UR0STAT = 0;
  UR1DATL = 0;
  UR1DATH = 0;
  UR1CR1 = 0;
  UR1CR2 = 0;
  UR1BRRL = 0;
  UR1STAT = 0;
  * @brief  SYS_INITIAL        program
  * @Description  系統時鐘、IO初始化
  * @param  None
  * @note
  * @retval  None
void SYS_INITIAL(void)
        OSCCON = SYS_OSCCON;//0B01110001;    //WDT 32KHZ IRCF=110=16MHZ/4=4MHZ,0.25US/T
                                                        //Bit0=1,系統時鐘為內部振蕩器
                                                        //Bit0=0,時鐘源由FOSC<2:0>決定即編譯選項時選擇
        OPTION = 0B00001000;        //Bit3 PSA   預分頻器分配位 0= 預分頻器分配給Timer0模塊 1:分配給WDT
                                                        //Bit2:0:預分頻比選擇位 000: 1:2
        DelayMs(40);                         //為進入debug模式延時大于20ms
    INTCON = 0;                          //暫禁止所有中斷
        PORTA = 0;
        PORTB = 0b00000010;
    PORTD = 0;
    PORTC = 0;
    //**********特別注意*********************************************************//
    //PC1:由于F283B,F285B的PB7與PC1打在一起,如果用PB6PB7做debug模式那么PC1需要設為輸入
    //PC6:當需要用PC6做debug模式時,需要設為輸入
    //PC7:由于F283B,F285B的PC7與PD5打在一起, PD5與PC7要配置相同,設為輸入
    //PD3:由于F283X,F285B,F286A,F287A的PD3與GND打在一起則禁止輸出高或使能內部上拉,設為輸入
    //    由于F287C的PD3與VDD打在一起則禁止輸出低或使能內部下拉,設為輸入
    TRISA = TRISA_CONFIG;                // 0-輸出 1-輸入     RA4 - //0B00000000
    TRISB = TRISB_CONFIG;                // B4-B7  TK5-TK2    PB7--touch   //0B00000000
    TRISC = TRISC_CONFIG;         //  0B00000000
    TRISD = TRISD_CONFIG;        // TKCAP_PD5設為輸入   //0B00101000
    ANSEL1 = 0B10000000; //TKCAP_PD5_AN15設為模擬輸入腳
        BANKSEL4_7;
        WPUA = 0B00000000;     //PA端口上拉控制 1-開上拉 0-關上拉
    WPUB = 0B00000000;
        WPUC = 0B00000000;
        WPUD = 0B00000000;
        WPDA = 0B00000000;     //PA端口上拉控制 1-開上拉 0-關上拉
    WPDB = 0B00000000;
        WPDC = 0B00000000;
        WPDD = 0B00000000;
    BANKSEL0_3;
  * @brief  WDT_INITIAL        program
  * @Description  初始化設置看門狗為16位計數器,用于SLEEP模式的128ms喚醒
  * @param  None
  * @note
  * @retval  None
void WDT_INITIAL(void)
        CLRWDT();                             //清看門狗
        WDTCON = 0B00001111;    //bit[6:5]WCKSRC=00=LIRC(32K)
                                                        //bit[4:1]WDTPS=0110=1:4096,預分頻1:1 定時時間=(4096*1)/32000=128ms
                                                        //bit[0]SWDTEN= 1 開啟
  * @brief  main        program
  * @Description 主函數
  * @param  None
  * @note
  * @retval  None
void main(void )
    Initialize_Communication();//必做,上電復位值
    SYS_INITIAL();//系統時鐘、IO初始化
    //touch庫資源使用詳情請看touch.h說明
    TSC_INITIAL();//觸摸按鍵初始化
    //低功耗定時,請勿關閉
        WDT_INITIAL(); //看門狗初始化
    PEIE = 1;  //使能外設中斷
        GIE = 1;  //使能全局中斷
//        LED(); //led.c  demo_test
                //清看門狗
                CLRWDT();
                //按鍵掃描
                TSC_Scan();
                if(TSC_DataProcessing()== 1) //返回1表示所有按鍵處理完成一次。
                        Get_Key_Demo();
  * @brief  SleepProcess        program
  * @Description 低功耗處理函數,若未選擇低功耗功能,SleepProcess() 在實際工程中可以刪除,
                                雖然已通過宏裁剪,但是函數也會編譯占用4byte rom和 占用cpu執行時間。
                1. bSleepEnable用于使能低功耗功能,如程序滿足休眠條件之后,請將bSleepEnable置1;
                2. bSleepMode為觸摸庫標志,用戶不允許操作。
  * @param  None
  * @note
  * @retval  None
#ifndef TOUCH_DEBUG
        #ifdef _DEF_LOW_POWER
//        if(PB7 == 0)//檢測到PB7低電平進入休眠
                bSleepEnable = 1;
        if(bSleepMode)        //滿足此條件,說明程序將立即進入低功耗,請將GPIO及其它耗電外設關閉,以達到最低功耗
    while(bSleepMode)
                TSC_SleepPrcoessing();
        CLRWDT();
                TSC_Sleep();
//                if(PB7 == 1)//檢測到PB7高電平退出休眠
//                        bSleepEnable = 0;
        #endif
#endif
  * @brief  TSC_Scan program
  * @Description 請勿刪除此函數
  * @param  None
  * @note
  * @retval  None
void TSC_Scan(void)
        #ifndef TOUCH_DEBUG
        TSC_Start();
    #else
    TSC_Start_Test();
    ConmunicateToPc();
    #endif
  * @brief  Get_Key_Demo program
  * @Description 獲取觸摸按鍵示例,用戶參考實現自己的功能
  * @param  None
  * @note
  * @retval  None
    /*只有調用CS庫才能獲取cs按鍵 TSC_GetCsKey();獲取當前按下的一個按鍵*/
    strongest = TSC_GetCsKey();
    if(Sav_strongest != strongest)
//        LED_Scan();
    Sav_strongest = strongest;
    /*獲取多個按鍵,可以用來實現組合按鍵功能*/
    single = TSC_GetLocalKey();
    if(Sav_single != single)
//        LED_Local_Scan();
    Sav_single = single;
收藏收藏1 分享淘帖 頂1 踩
ID:1090708 發表于 2023-8-4 17:19 | 只看該作者
有專門的調試軟件啊
ID:123289 發表于 2023-8-5 09:56 | 只看該作者
再更細致地研讀芯片手冊。
ID:739727 發表于 2024-6-12 23:53 | 只看該作者
用定時器掃描
