只需一步,快速開(kāi)始
查看: 1704|回復(fù): 0
單片機(jī)播放青花瓷源程序
ID:1087011 發(fā)表于 2023-7-3 14:18 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
#include<intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit buzzer = P2 ^ 5;  //蜂鳴器管腳
u8 time0h = 0;         //定時(shí)器高8位
u8 time0l = 0;         //定時(shí)器低8位
u8 bats = 0;           //延時(shí)拍數(shù)
bit stop = 0;          //是否為休止符,0是,1不是(給stop賦值為非0則stop等于1)
bit smooth = 0;        //1圓滑,0不圓滑
code u8 node[] = {
        //0xf2,0xf3,0xf5,0xf5,0xf6,0xf7,0xf8,//C調(diào)低音高8位  @11.0592MHz
        //0xf9,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc,//C調(diào)中音
        //0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe,//C調(diào)高音
        //0x42,0xc1,0x17,0xaf,0xd1,0xd1,0xb6,//C調(diào)低音低8位
        //0x1e,0xde,0x8a,0xd8,0x68,0xe9,0x5b,
        //0x8f,0xf0,0x45,0x69,0xb4,0xf4,0x2e,
        //0xf3,0xf5,0xf6,0xf6,0xf7,0xf8,0xf9,//D調(diào)
        //0xf9,0xfa,0xfb,0xfb,0xfb,0xfc,0xfc,
        //0xfc,0xfd,0xfd,0xfd,0xfd,0xfe,0xfe,
        //0xc1,0x17,0x45,0xd1,0xd1,0xb6,0x80,
        //0xde,0x8a,0x23,0x68,0xe9,0x5b,0xc1,
        //0xf0,0x45,0x91,0xb4,0xf4,0x2e,0x78,
        //0xf5,0xf6,0xf7,0xf7,0xf8,0xf9,0xfa,//E調(diào)
        //0xfa,0xfb,0xfb,0xfb,0xfc,0xfc,0xfd,
        //0xfd,0xfd,0xfd,0xfd,0xfe,0xfe,0xfe,
        //0x17,0x45,0x53,0xd1,0xb6,0x80,0x36,
        //0x8a,0x23,0xab,0xe9,0x5b,0xc1,0x1c,
        //0x45,0x91,0xd5,0xf4,0x2e,0x78,0xa3,
        //0xf5,0xf6,0xf7,0xf8,0xf9,0xf9,0xfa,//F調(diào)
        //0xfa,0xfb,0xfb,0xfc,0xfc,0xfc,0xfd,
        //0xfd,0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,
        //0xaf,0xd1,0xd1,0x46,0x1e,0xde,0x8a,
        //0xd8,0x68,0xe9,0x23,0x8f,0xf0,0x45,
        //0x69,0xb4,0xf4,0x12,0x60,0x8e,0xb6,
        //0xf6,0xf7,0xf8,0xf9,0xf9,0xfa,0xfb,//G調(diào)
        //0xfb,0xfb,0xfc,0xfc,0xfc,0xfd,0xfd,
        //0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,
        //0xd1,0xd1,0xb6,0x1e,0xde,0x8a,0x23,
        //0x69,0xe9,0x5b,0x8f,0xf0,0x45,0x91,
        //0xb4,0xf4,0x2e,0x60,0x8e,0xb6,0xea,
        0xf7,0xf8,0xf9,0xf9,0xfa,0xfb,0xfb,//A調(diào)
        0xfb,0xfc,0xfc,0xfc,0xfd,0xfd,0xfd,
        0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,0xff,
        0xd1,0xb6,0x80,0xde,0x8a,0x23,0xab,
        0xe9,0x5b,0xc1,0xf0,0x45,0x91,0xd5,
        0xf4,0x2e,0x78,0x8e,0xb6,0xea,0x09
        //0xf8,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc,//B調(diào)
        //0xfe,0xfe,0xfe,0xfe,0xfe,0xff,0xff,
        //0xb6,0x80,0x36,0x8a,0x23,0xab,0x23,
        //0x5b,0xc1,0x1c,0x45,0x91,0xd5,0x12,
        //0x2e,0x78,0xa3,0xb6,0xea,0x09,0x23
code u8 music[] = {
        0,1,2,0, 3,1,2,0, 3,1,2,0, 6,1,1,0, 6,1,1,1, 6,1,2,0, 1,1,2,0, 2,1,2,0,
        3,1,1,0, 3,1,1,1, 3,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,2,0,
        3,1,2,0, 6,1,2,0, 6,1,3,0, 5,1,1,0, 5,1,3,0, 4,1,1,1, 4,1,1,0, 3,1,3,1,
        3,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,2,0, 3,1,2,0, 6,1,2,1, 6,1,2,0,
        1,1,2,0, 2,1,2,0, 3,1,6,0, 0,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,2,0,
        3,1,2,0, 1,1,2,0, 3,1,2,0, 3,1,1,0, 4,1,1,1, 4,1,2,0, 3,1,2,0, 1,1,8,0,
        0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,2,0, 3,1,2,0, 6,1,1,0, 6,1,1,1, 6,1,2,0,
        1,1,2,0, 2,1,2,0, 3,1,1,0, 3,1,1,1, 3,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,4,0,
        0,1,2,0, 3,1,2,0, 3,1,2,0, 6,1,2,0, 6,1,3,0, 5,1,1,0, 5,1,3,0, 4,1,1,1,
        4,1,1,0, 3,1,3,1, 3,1,4,0, 0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,1,0, 3,1,1,0,
        3,1,2,0, 6,1,2,1, 6,1,2,0, 1,1,2,0, 2,1,2,0, 3,1,2,1, 3,1,4,0, 0,1,4,0,
        0,1,4,0, 0,1,4,0, 0,1,2,0, 3,1,2,0, 3,1,2,0, 1,1,2,0, 3,1,2,0, 3,1,1,0,
        4,1,1,1, 4,1,2,0, 3,1,2,0, 1,1,8,0, 0,1,2,0, 5,1,2,0, 6,1,2,0, 7,1,2,0,
        1,2,2,0, 7,1,1,0, 1,2,1,1, 1,2,2,0, 5,1,1,0, 6,1,1,0, 6,1,4,0, 5,1,2,0,
        4,1,1,0, 4,1,1,1, 4,1,2,0, 3,1,2,0, 3,1,2,0, 3,1,1,0, 2,1,1,1, 2,1,2,0,
        5,1,2,0, 6,1,2,0, 7,1,2,0, 1,2,2,0, 7,1,1,0, 1,2,1,1, 1,2,2,0, 5,1,1,0,
        6,1,1,0, 6,1,4,0, 6,1,2,0, 7,1,1,0, 1,2,1,1, 1,2,2,0, 1,2,2,0, 1,2,2,0,
        1,2,1,0, 2,2,1,1, 2,2,2,0, 0,1,1,0, 5,1,1,0, 6,1,2,0, 7,1,2,0, 1,2,2,0,
        7,1,1,0, 1,2,1,1, 1,2,2,0, 3,2,2,0, 6,2,3,0, 5,2,1,1, 5,2,2,0, 4,2,2,0,
        3,2,4,0, 3,2,2,0, 2,2,2,1, 2,2,4,0, 6,1,2,0, 7,1,2,0, 1,2,4,0, 1,2,2,0,
        2,2,1,0, 1,2,1,1, 1,2,3,0, 1,2,1,0, 7,1,2,0, 1,2,1,0, 2,2,1,1, 2,2,4,0,
        1,2,2,0, 7,1,2,0, 1,2,8,0, 0,1,0,0
};//歌譜格式為:音符(0-7)+低中高音(0-2)+拍數(shù)(單位0.25拍)+是否圓滑(1,0)(最后四位中的第一第三位為終止參數(shù))
void time0() interrupt 1
        TR0 = 0;         //定時(shí)器關(guān)后賦值,防止從0開(kāi)始定時(shí)
        buzzer = !buzzer;
        TH0 = time0h;
        TL0 = time0l;
        TR0 = 1;         //定時(shí)器開(kāi)
void Delayms(u16 ms)//延時(shí)ms毫秒
        while (ms--)
                u8 i, j;
                _nop_();
                i = 2;
                j = 199;
                do
                        while (--j);
                } while (--i);
void Sing()
        if (stop)
                TH0 = time0h;
                TL0 = time0l;
                TR0 = 1;
                TR0 = 0;
        Delayms(200*bats);  //72拍/min
        if (!smooth)
                TR0 = 0;
                Delayms(10);   //音符間間歇
                TR0 = 1;
        u16 i = 0;
        u8  j = 0;
        EA = 1;    //總中斷開(kāi)
        ET0 = 1;   //T0中斷允許
        TMOD = 1;  //工作方式1,16位定時(shí)計(jì)數(shù)器
        while (1)  //控制播放次數(shù)
                i = 0;
                while (music[ i] != 0 || music[i + 2] != 0)//這里定義音符為0與拍數(shù)為0組合代表結(jié)束歌曲
                        j = music[ i] + 7 * music[i + 1] - 1;  //確定音符高8位位置
                        time0h = node[j];
                        time0l = node[j+21];
                        bats = music[i + 2];
                        stop = music[ i];
                        smooth = music[i + 3];
                        Sing();
                        i += 4;
/*下面是兩個(gè)神秘樂(lè)譜*/
//樂(lè)譜1
/*6,1,6,0, 5,1,2,0, 3,1,4,0, 5,1,4,0, 1,2,4,0, 6,1,2,1, 5,1,2,0, 6,1,8,0,
  3,1,4,0, 5,1,2,0, 6,1,2,0, 5,1,4,0, 3,1,2,1, 2,1,2,0, 1,1,2,1, 6,0,2,0,
  5,1,2,1, 3,1,2,0, 2,1,8,0, 2,1,6,0, 3,1,2,0, 5,1,4,0, 5,1,2,0, 6,1,2,0,
  3,1,6,1, 2,1,2,0, 1,1,8,0, 5,1,6,0, 3,1,2,0, 2,1,2,1, 1,1,2,0, 6,0,2,1,
  1,1,2,0, 5,0,8,0, 0,1,0,0
//樂(lè)譜2
/*1,1,4,0, 2,1,4,0, 3,1,4,0, 1,1,4,0, 1,1,4,0, 2,1,4,0, 3,1,4,0, 1,1,4,0,
  3,1,4,0, 4,1,4,0, 5,1,8,0, 3,1,4,0, 4,1,4,0, 5,1,8,0, 5,1,3,0, 6,1,1,0,
  5,1,3,0, 4,1,1,0, 3,1,4,0, 1,1,4,0, 5,1,3,0, 6,1,1,0, 5,1,3,0, 4,1,1,0,
  3,1,4,0, 1,1,4,0, 1,1,4,0, 5,0,4,0, 1,1,8,0, 1,1,4,0, 5,0,4,0, 1,1,8,0,
  0,1,0,0
