查看: 2073|回復(fù): 0
基于單片機(jī)60秒倒計(jì)時(shí)計(jì)時(shí)器程序Proteus仿真圖
ID:1083231 發(fā)表于 2023-6-11 09:12 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
unsigned char code LED[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char m,buf[4];
unsigned int shu,j;
void delay(unsigned char x)
        unsigned char y;
        for(;x>0;x--)
                for(y=110;y>0;y--);
void dis(unsigned int temp)
        unsigned char i;
        buf[0]=0;
        buf[1]=0;
        buf[2]=temp/10;
        buf[3]=temp%10;
        for(i=0;i<4;i++)
                P2=(0x01<<i);
                P1=LED[buf[ i]];
                delay(5);
                P1=0xff;
void INT_0( ) interrupt 0
        TR0=~TR0;
void INT_1( ) interrupt 2
        TR0=~TR0;
        TL0=(65536-50000)%256;
    TH0=(65536-50000)/256;
        shu=60;
    j=0;
void TIME_0( ) interrupt 1
    j++;
        if(j==10)
            j=0;
                shu--;
                if(shu==0)
                TR0=0;
    TCON=0x05;
    IP=0x00;
    TMOD=0x01;
    TR0=1;
    IE=0x87;
    shu=60;
    j=1;
                dis(shu);
基于單片機(jī)60秒倒計(jì)時(shí)計(jì)時(shí)器.zip
70.79 KB, 下載次數(shù): 24, 下載積分: 黑幣 -5
Proteus
參與人數(shù) 1黑幣 +50 收起 理由
