串口發(fā)送完固定字符后,按下鍵碼不能發(fā)送指定字符protues仿真結(jié)果如下
p1為未按下鍵碼仿真結(jié)果
p2為按下鍵碼后結(jié)果 (s2,s3按下情況相同)
#include<reg51.h>
#include"Delay.h"
unsigned char scan()
if((P3&0x0C)!=0x0C)
{Delay(10);
if((P3&0x0C)!=0x0C)
{return(P3&0x0C);
return 0xFF;
void sendbyte(unsigned char byte)
SBUF=byte;
while(!TI);
TI=0;
void sendstr(unsigned char *str)
while(*str!='\0')
sendbyte(*str);
*str++;
void time_adjust()
static bit kp=0;
unsigned char s_code=scan();//S——scan鍵盤(pán)掃描
if((s_code!=0xFF)&&(kp==0))//none=0xFF
kp=1;
switch(s_code)
case 0x08:
{sendy("222\r\n");
break;
case 0x04:
sendy("111\r\n");
break;
default:break;
else if((kp==1)&&(s_code==0xFF))
kp=0;
SCON=0x50;//串口方式1,RX/TX
ES=1;EA=1;//使能
TMOD=TMOD|0x20;//方式2定時(shí)
TL1=0xFD;TH1=0xFD;//9600bps初值@110952Mhz
TR1=1;
sendstr("2021040140238\r\n");
sendstr("0\r\n");
time_adjust();
void isr_uart()interrupt 4
if(RI==1)
P1=SBUF;
RI=0;
