查看: 1404|回復(fù): 3
下面單片機(jī)代碼為啥報(bào)錯
ID:1081825 發(fā)表于 2023-6-5 15:26 | 顯示全部樓層 |閱讀模式
請教各位大神,下面代碼為啥報(bào)錯
#include<reg52.h>
typedef unsigned char u8;
typedef unsigned int u16;
u8 code Seg7_Tab[ ]        = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                         0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}
void Seg7_Display(u16 val,u8 DEC_HEX)
  static u8 i = 4,j = 0;
  static u16 pre_val=0;
  static u8 dis_data[5]={0};
  if(val != pre_val)
        pre_val=val;
        for(j=0;j<5;j++)
         dis_data[j] = val%DEC_HEX;
         val=val/DEC_HEX;
  i++;
  if(i>4)                //i的范圍[0,4]
        i=0;
  P0 = 0;
  P0 = Seg7_Tab[dis_data[ i]];
  P1 = i;
ID:883242 發(fā)表于 2023-6-5 15:32 | 顯示全部樓層
,0x71}后面缺了一個;
ID:161164 發(fā)表于 2023-6-5 15:54 | 顯示全部樓層
ID:647261 發(fā)表于 2023-6-5 15:58 | 顯示全部樓層
第5行“}”后面少了個“;”
