查看: 2577|回復: 2
哪位老哥整過stm32串口硬件流控制的代碼啊
ID:630212 發表于 2023-5-25 16:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
90黑幣
最佳答案
查看完整內容
以下是一個使用STM32的標準庫(HAL庫)實現硬件流控制的串口代碼,用于控制UART2: #include "stm32f4xx_hal.h" UART_HandleTypeDef huart2; void SystemClock_Config(void); int main(void) { HAL_Init(); SystemClock_Config(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_USART2_CLK_ENABLE(); GPIO_InitTypeDef GPIO_InitStruct = {0}; GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3; ...
ID:404160 發表于 2023-5-25 16:28 | 只看該作者
int main(void)
  HAL_Init();
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_RTS_CTS;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    while (1);
  uint8_t buffer[] = "Hello, world!\r\n";
  while (1)
    if (HAL_UART_Transmit(&huart2, buffer, sizeof(buffer), 100) != HAL_OK)
      while (1);
    HAL_Delay(1000);
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 16;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    while (1);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    while (1);
在以上代碼中,我們使用了硬件流控制(RTS/CTS)來實現串口的數據傳輸。在初始化UART時,我們將Mode設置為UART_MODE_TX_RX,以允許UART同時進行發送和接收。我們還將HwFlowCtl設置為UART_HWCONTROL_RTS_CTS,以啟用硬件流控制。
此時,CTS引腳應該配置為輸入模式,如上述代碼所示,我們使用GPIOA2引腳作為CTS。在數據發送時,如果CTS引腳處于邏輯高電平,則UART不會將數據發送到接收端,而會等待CTS引腳返回邏輯低電平,然后再繼續發送數據。
請注意,上述代碼主要用于示例演示,因此省略了錯誤處理和異常情況處理。在實際應用中,需要根據具體需求添加適當的錯誤處理和異常情況處理。
ID:404160 發表于 2023-5-28 17:06 | 只看該作者
int main(void)
  HAL_Init();
    while (1);
  while (1)
      while (1);
    HAL_Delay(1000);
    while (1);
    while (1);
