我這個(gè)程序燒到單片機(jī)里,LCD顯示一翻頁(yè)第一頁(yè)的濕度就自己跳為零,然后就報(bào)警,第二頁(yè)的內(nèi)容可以正常顯示。
BUT=1;
uart_init();//初始化串口
lcd1602_init();
time0_init();
while(DHT11_Init()) //檢測(cè)DHT11是否存在
lcd1602_show_string(0,0,"Error");
DHT11_Read_Data(&temp,&humi);
// lcd1602_show_string(0,0,"Temp: C");
// lcd1602_show_string(0,1,"Humi: %RH");
// lcd1602_show_string(0,0,"Wating......");
// delay_ms(2500);
i++;
valuedata1=200-Adc0832(0);
delay_ms(100);
valuedata2=Adc0832(1);
key=key_scan(0);
if(key==KEY1_PRESS)//檢測(cè)按鍵K1是否按下,按下進(jìn)入設(shè)置閾值狀態(tài)
LED2=0;
while(1) //溫度上限設(shè)置
key=key_scan(0);
if(key==KEY2_PRESS)
temphigh++;
if(key==KEY3_PRESS)
temphigh--;
if(key==KEY1_PRESS)
break;
tempgoal_bufhigh[0]=temphigh/10+0x30;
tempgoal_bufhigh[1]=temphigh%10+0x30;
lcd1602_show_string(10,0,tempgoal_bufhigh);
while(1) //溫度下限設(shè)置
key=key_scan(0);
if(key==KEY2_PRESS)
templow++;
if(key==KEY3_PRESS)
templow--;
if(key==KEY1_PRESS)
break;
tempgoal_buflow[0]=templow/10+0x30;
tempgoal_buflow[1]=templow%10+0x30;
lcd1602_show_string(13,0,tempgoal_buflow);
while(1) //濕度上限設(shè)置
key=key_scan(0);
if(key==KEY2_PRESS)
humihigh++;
if(key==KEY3_PRESS)
humihigh--;
if(key==KEY1_PRESS)
break;
humigoal_bufhigh[0]=humihigh/10+0x30;
humigoal_bufhigh[1]=humihigh%10+0x30;
lcd1602_show_string(10,1,humigoal_bufhigh);
while(1) //濕度下限設(shè)置
key=key_scan(0);
if(key==KEY2_PRESS)
humilow++;
if(key==KEY3_PRESS)
humilow--;
if(key==KEY1_PRESS)
break;
humigoal_buflow[0]=humilow/10+0x30;
humigoal_buflow[1]=humilow%10+0x30;
lcd1602_show_string(13,1,humigoal_buflow);
LED2=1;
if(keydata==0)
lcd1602_show_string(0,1,"Humi: %");
temp_buf[0]=temp/10+0x30;
temp_buf[1]=temp%10+0x30;
temp_buf[2]='\0';
lcd1602_show_string(6,0,temp_buf);
humi_buf[0]=humi/10+0x30;
humi_buf[1]=humi%10+0x30;
humi_buf[2]='\0';
lcd1602_show_string(6,1,humi_buf);
tempgoal_bufhigh[2]='\0';
tempgoal_buflow[2]='\0';
humigoal_bufhigh[2]='\0';
humigoal_buflow[2]='\0';
delay_ms(50);
if(keydata==1)
lcd1602_show_string(0,0,"GZ: LUX");
lcd1602_show_string(0,1,"YW: MMP");
CO_buf[0]=valuedata1/100+0x30;
CO_buf[1]=valuedata1%100/10+0x30;
CO_buf[2]=valuedata1%10+0x30;
CO_buf[3]='\0';
lcd1602_show_string(3,0,CO_buf);
CH_buf[0]=valuedata2/100+0x30;
CH_buf[1]=valuedata2%100/10+0x30;
CH_buf[2]=valuedata2%10+0x30;
CH_buf[3]='\0';
lcd1602_show_string(3,1,CH_buf);
delay_ms(50);
if(temp>=temphigh||temp<=templow||humi>=humilow||humi<humihigh||valuedata2>=10)
BEEP=0;
LED1=0;
BEEP=1;
LED1=1;
if(temp>=temphigh)
IN1=0;
IN1=1;
if(temp<=templow)
IN2=0;
IN2=1;
if(humi<=humilow)
IN3=0;
IN3=1;
if(humi>=humihigh)
IN4=0;
IN4=1;
if(valuedata2>=10)
IN5=0;
IN5=1;
delay_ms(1);
藍(lán)牙程序:
void time0() interrupt 1 //定時(shí)器0中斷函數(shù)
TH0=0XDC; //給定時(shí)器賦初值,定時(shí)10ms
TL0=0X00;
gmsec++;//10ms加1次
if(BUT==0)
delay_ms(500);
lcd1602_clear();
keydata=!keydata;
if(gmsec%500==0)//定時(shí)5秒
SendString("Temp:");
SendString(temp_buf);
SendString("C");
SendString("\r\n");
delay_ms(20);
SendString("Humi:");
SendString(humi_buf);
SendString("%");
SendString("\r\n");
delay_ms(20);
SendString("GZ:");
SendString("144");
SendString("LUX");
SendString("\r\n");
delay_ms(20);
SendString("YW:");
SendString(CH_buf);
SendString("MMP");
SendString("\r\n");
