查看: 1402|回復: 0
51單片機DAC0832低頻波形發生器源程序 帶詳細注釋
ID:582 發表于 2023-5-18 21:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg52.h>                      //包含頭文件
  2. #include<intrins.h>
  3. #define uchar unsigned char         //宏定義
  4. #define uint unsigned int
  5. sbit s1=P3^5;                                  //定義按鍵的接口
  6. sbit s2=P3^6;
  7. sbit s3=P3^7;
  8. sbit s4=P3^4;
  9. sbit led0=P3^0;                  //定義四個LED,分別表示不同的波形
  10. sbit led1=P3^1;
  11. sbit led2=P3^2;
  12. sbit led3=P3^3;
  13.
  14. sbit lcdrs=P2^7;                                           //液晶控制引腳,還有一個控制
  15. 腳是RW,因為我們只需要向液晶里寫數據系就好了,所以,我們直接將RW引腳接地
  16. sbit lcden=P2^6;
  17. char num,boxing,u;                                           //定義全局變量
  18. int pinlv=100,bujin=1,bujin1=1;                   //頻率初始值是10Hz,步進值默
  19. 認是0.1,顯示步進值變量
  20. uchar code table[]="0123456789";                //定義顯示的數組
  21. uchar code table1[]="Fout=     Wave form:";        //初始化顯示字符
  22. unsigned long int m;                                   //定義長整形變量 m
  23. int a,b,h,num1;                                                        //定義全局變量
  24. //自定義字符
  25. uchar code zifu[]={                   //此數組內數據為液晶上顯示波形符號的自定義字符
  26.                                                 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
  27.                                                 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00,
  28. //正弦波           0  1
  29.                                                 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
  30.                                                 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00,
  31. //矩形波           2  3
  32.                                                 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
  33.                                                 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,
  34. //三角波           4  5
  35.                                                 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00,
  36. //鋸齒波           6
  37. };
  38. uchar code sin[64]={           //此數組內的數據為,da輸出對應電壓值對應的數字量,0是0V,255是5V
  39. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  40. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  41. };                                          //正弦波取碼
  42. uchar code juxing[64]={                //一個周期是采樣64個點, 所以數組內是64個數據
  43. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  44. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  45. };                                          //矩形波取碼
  46. uchar code sanjiao[64]={
  47. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  48. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  49. };                                                //三角波取碼
  50.
  51. void delay(uint xms)         //延時函數
  52. {
  53.         int a,b;
  54.         for(a=xms;a>0;a--)
  55.                 for(b=110;b>0;b--);
  56. }
  57. void write_com(uchar com)                //寫命令函數
  58. {
  59.         lcdrs=0;
  60.         P0=com;
  61.         delay(1);
  62.         lcden=1;
  63.         delay(1);
  64.         lcden=0;
  65. }
  66. void write_date(uchar date)                //寫數據函數
  67. {
  68.         lcdrs=1;
  69.         P0=date;
  70.         delay(1);
  71.         lcden=1;
  72.         delay(1);
  73.         lcden=0;
  74. }
  75. //自定義字符集
  76. void Lcd_ram()
  77. {
  78.         uint i,j,k=0,temp=0x40;
  79.         for(i=0;i<7;i++)
  80.         {
  81.            for(j=0;j<8;j++)
  82.            {
  83.             write_com(temp+j);
  84.             write_date(zifu[k]);
  85.             k++;
  86.            }
  87.            temp=temp+8;
  88.         }
  89. }
  90. void init_lcd()                                        //初始化函數
  91. {
  92.         uchar i;
  93.         lcden=0;                                        //默認開始狀態為關使能端,見時序圖
  94.         Lcd_ram();
  95.         write_com(0x0f);
  96.         write_com(0x38);                        //顯示模式設置,默認為0x38,不用變。
  97.         write_com(0x01);                        //顯示清屏,將上次的內容清除,默認為0x01.
  98.         write_com(0x0c);                        //顯示功能設置0x0f為開顯示,顯示光標,光標閃爍;0x0c為開顯示,不顯光標,光標不閃
  99.         write_com(0x06);                        //設置光標狀態默認0x06,為讀一個字符光標加1.
  100.         write_com(0x80);                        //設置初始化數據指針,是在讀指令的操作里進行的
  101.         for(i=10;i<20;i++)                           //顯示初始化
  102.         {
  103.                 write_date(table1[i]);                   //顯示第一行字符
  104.         }
  105.         write_com(0x80+0x40);                           //選擇第二行
  106.         for(i=0;i<9;i++)
  107.         {
  108.                 write_date(table1[i]);                   //顯示第二行字符
  109.         }
  110.         write_com(0x80+10);                                   //選擇第一行第十個位置
  111.         write_date(0);
  112.         write_date(1);
  113.         write_date(0);
  114.         write_date(1);
  115.         write_date(0);
  116.         write_date(1);                                           //顯示自定義的波形圖案
  117.         write_com(0x80+0x40+0x09);                   //選擇第二行第九個位置
  118.         write_date(' ');
  119.         write_date('1');
  120.         write_date('0');
  121.         write_date('0');
  122.         write_date('H');
  123.         write_date('z');                                   //顯示初始的頻率值
  124. }
  125. void initclock()                           //定時器初始化函數
  126. {
  127.         TMOD=0x01;                                   //定時器的工作方式
  128.         TH0=a;
  129.         TL0=b;                                           //定時器賦初值
  130.         EA=1;                                           //打開中斷總開關
  131.         ET0=1;                                           //打開定時器允許中斷開關
  132.         TR0=1;                                           //打開定時器定時開關
  133. }
  134. void display()                                   //顯示函數
  135. {
  136.         uchar qian,bai,shi,ge;           //定義變量用于顯示
  137.         qian=pinlv/1000;                   //將頻率值拆成一位的數據,將數據除以1000,得到的商是一位數,賦值給qian
  138.         bai=pinlv%1000/100;                   //將頻率除以1000的余數再除以100就得到了頻率的百位,賦值給bai
  139.         shi=pinlv%1000%100/10;           //同上,得到頻率的十位
  140.         ge=pinlv%1000%100%10;
  141.         write_com(0x80+0x40+0x09); //選中第二行第九個位置
  142.            if(qian==0)                                   //千位如果為0
  143.         write_date(' ');                   //不顯示
  144.         else                                           //千位不為0
  145.         write_date(table[qian]);   //正常顯示千位
  146.         if(qian==0&&bai==0)                   //千位和百位都為0
  147.         write_date(' ');                   //百位不顯示
  148.         else                                           //不都為0
  149.         write_date(table[bai]);           //百位正常顯示
  150.         write_date(table[shi]);           //顯示十位數
  151.         write_date(table[ge]);           //顯示個位
  152.         write_date('H');                   //顯示頻率的單位Hz
  153.         write_date('z');
  154.         if(boxing==0)                           //判斷波形為正弦波
  155.         {
  156.                 write_com(0x80+10);           //選中一行頻率圖案位置
  157.                 write_date(0);                   //顯示正弦波圖案
  158.                 write_date(1);
  159.                 write_date(0);
  160.                 write_date(1);
  161.                 write_date(0);
  162.                 write_date(1);
  163.                 led3=1;
  164.                 led0=0;                                        //點亮正弦波指示燈
  165.         }
  166.         if(boxing==1)                                //注釋同上
  167.         {
  168.                 write_com(0x80+10);
  169.                 write_date(2);
  170.                 write_date(3);
  171.                 write_date(2);
  172.                 write_date(3);
  173.                 write_date(2);
  174.                 write_date(3);
  175.                 led0=1;
  176.                 led1=0;
  177.         }
  178.         if(boxing==2)
  179.         {
  180.                 write_com(0x80+10);
  181.                 write_date(4);
  182.                 write_date(5);
  183.                 write_date(4);
  184.                 write_date(5);
  185.                 write_date(4);
  186.                 write_date(5);
  187.                 led1=1;
  188.                 led2=0;
  189.         }
  190. }
  191. void keyscan()                                        //頻率調節鍵盤檢測函數
  192. {
  193.         if(s1==0)                                        //加按鍵是否按下
  194.         {
  195.                 EA=0;                                        //關閉中斷
  196.                 delay(2);                            //延時去抖
  197.                 if(s1==0)                                //再次判斷
  198.                 {
  199.                         while(!s1);                        //按鍵松開
  200.                         pinlv+=bujin;                //頻率以步進值加
  201.                         if(pinlv>1000)                //最大加到1000Hz
  202.                         {
  203.                                 pinlv=100;                //1000Hz
  204.                         }
  205.                         display();                        //顯示函數
  206.                         m=65536-(150000/pinlv);//計算頻率
  207. /*頻率值最小是10Hz,pinlv的值是100(因為要顯示小數點后一位),150000/100=1500,這個1500就是定時器需要計時的,單位是us,65536-1500得到的是定時器的初值,
  208. 先不管初值,先看定時時間,1500us,一個波形的周期是由64個定時組成的,所以,一個波形周期就是64*1500us=96000,也就是96ms,約等
  209. 于100ms,也就是10Hz的頻率*/
  210.                         a=m/256;                        //將定時器的初值賦值給變量
  211.                         b=m%256;
  212.                         EA=1;                                //打開中斷總開關
  213.                 }
  214.         }
  215.         if(s2==0)                                        //減按鍵按下
  216.         {
  217.
  218.                 delay(5);
  219.                 if(s2==0)
  220.                 {
  221.                         EA=0;
  222.                         while(!s2);
  223.                         pinlv-=bujin;                   //頻率以步進值減
  224.                         if(pinlv<100)
  225.                         {
  226.                                 pinlv=1000;
  227.                         }
  228.                         display();
  229.                         m=65536-(150000/pinlv);
  230.                         a=m/256;
  231.                         b=m%256;
  232.                         EA=1;
  233.                 }
  234.         }
  235.         if(s3==0)                                         //波形切換按鍵
  236.         {
  237.                 delay(5);
  238.                 if(s3==0)
  239.                 {
  240.                         EA=0;
  241.                         while(!s3);
  242.                         boxing++;                           //波形切換
  243.                         if(boxing>=3)                   //4種波形
  244.                         {
  245.                                 boxing=0;
  246.                         }
  247.                         display();
  248.                         EA=1;
  249.                 }
  250.         }
  251. }
  252. void bujindisplay()                                 //步進值設置界面顯示程序
  253. {
  254.         uint bai,shi,ge;                         //定義步進值 百十個位
  255.         bai=bujin1/100;                                 //將步進值除以100得到百位,也就是頻率值的十位,因為有一個小數位
  256.         shi=bujin1%100/10;                         //將步進值除以100的余數除以十得到十位
  257.         ge=bujin1%100%10;                         //取余10后得到個位,也就是頻率步進值的小數點后一位
  258.         write_com(0x80+11);                         //選中液晶第一行第十一列
  259.         if(bai==0)                                         //百位是否為0
  260.         write_date(' ');                         //百位不顯示
  261.         else                                                 //百位不為0
  262.         write_date(table[bai]);                 //顯示百位數據
  263.         write_date(table[shi]);                 //顯示十位數據
  264.         write_date(table[ge]);                 //顯示個位
  265. }
  266. void bujinjiance()                                 //步進值設置鍵盤程序
  267. {
  268.         if(s4==0)                                         //步進設置按鍵按下
  269.         {
  270.                 delay(5);                                 //延時去抖
  271.                 if(s4==0)                                 //再次判斷按鍵
  272.                 {
  273.                          while(!s4);                 //按鍵釋放,按鍵松開才繼續向下執行
  274.                          h++;                                 //變量加
  275.                          if(h==1)                         //進入設置狀態時
  276.                          {
  277.                                   write_com(0x01);                          //清屏
  278.                                  write_com(0x80);                          //初始化顯示步進設置界面
  279.                                  write_date('S');delay(1);          //step value
  280.                                  write_date('t');delay(1);
  281.                                  write_date('e');delay(1);
  282.                                  write_date('p');delay(1);
  283.                                  write_date(' ');delay(1);
  284.                                  write_date('v');delay(1);
  285.                                  write_date('a');delay(1);
  286.                                  write_date('l');delay(1);
  287.                                  write_date('u');delay(1);
  288.                                  write_date('e');delay(1);
  289.                                  write_date(':');delay(1);
  290.                                  bujin1=bujin;                                  //步進值賦值給臨時變量
  291.
  292.                                  bujindisplay();                          //顯示步進值
  293.                          }
  294.                          if(h==2)                                                  //退出設置
  295.                          {
  296.                                  h=0;                                                  //清零
  297.                                 bujin=bujin1;                                  //設置好的臨時步進值賦值給步進變量
  298.
  299.                                 init_lcd();                                          //初始化液晶顯示
  300.                                 initclock();                                  //定時器初始化
  301.                                 display();                                          //調用顯示程序
  302.                          }
  303.                 }
  304.         }
  305.         if(h==1)        //設置步進值時
  306.         {
  307.                 if(s1==0)                                                          //加按鍵按下
  308.                 {
  309.                         delay(5);                                                  //延時去抖
  310.                         if(s1==0)                                                  //再次判斷
  311.                         {
  312.                                 while(!s1);                                          //按鍵釋放
  313.                                 bujin1++;                                          //步進值加1
  314.                                 if(bujin1>=101)                                  //步進值最大100,也就是10.0Hz
  315.                                 {
  316.                                         bujin1=1;                                  //超過最大值就恢復到
  317.      0.1Hz
  318.                                 }
  319.                                 bujindisplay();                                  //步進顯示
  320.                         }
  321.                 }
  322.                 if(s2==0)                                                          //減按鍵,注釋同上
  323.                 {
  324.                         delay(5);
  325.                         if(s2==0)
  326.                         {
  327.                                 while(!s2);
  328.                                 bujin1--;                                          //步進減
  329.                                 if(bujin1<=0)
  330.                                 {
  331.                                         bujin1=100;
  332.                                 }
  333.                                 bujindisplay();
  334.                         }
  335.                 }
  336.         }
  337. }
  338. void main()                                         //主函數
  339. {
  340.         init_lcd();                                 //調用初始化程序
  341.         m=65536-(150000/pinlv);         //定時器初值
  342.         a=m/256;
  343.         b=m%256;
  344.         initclock();                         //定時器初始化
  345.         led0=0;                                         //點亮第一個波形指示燈
  346.         while(1)                                 //進入while循環,括號內為1,一直成立,所以也叫死循環,程序不會跳出,一直在內執行
  347.         {
  348.                 if(h==0)                         //正常模式不是步進調節
  349.                 {
  350.                         keyscan();                 //掃描按鍵
  351.                 //        display();
  352.                 }
  353.
  354.                 bujinjiance();                 //掃描步進調節程序
  355.                 switch(boxing)                                                        //選擇波形
  356.                 {
  357.                         case 0 : P1=sin[u]; break;                        //正弦波
  358.                         case 1 : P1=juxing[u]; break;                //矩形波
  359.                         case 2 : P1=sanjiao[u]; break;                //三角波
  360.                 }
  361.         }
  362. }
  363. void T0_time()interrupt 1                   //定時器
  364. {
  365.         TH0=a;
  366.         TL0=b;                                                   //根據不同的初值,定時器定時時間不同,達到不同頻率的目的
  367.         u++;                                                   //變量加
  368.         if(u>=64)                                           //一個周期采樣64個點, 所以加到64就清零
  369.         u=0;                                                   //u清零
  370. }
word文檔:http://m.raoushi.com/bbs/dpj-228989-1.html
