查看: 1428|回復: 1
51單片機負載平衡監控系統是個什么原理啊?求分析電路與程序
ID:1073370 發表于 2023-4-22 14:51 | 顯示全部樓層 |閱讀模式
有沒有大佬知道負載平衡和負載均衡的區別,負載平衡是個什么原理啊,我對我這個設計的工作原理不太懂,有大佬接觸過這個設計嗎!設計是能根據當前的負載情況選擇0%~80%,最小分辨率為10%的負載狀態;一方負載高于另外一方20%時,報警發聲,負載值相差越大,報警聲越急迫。然后圖片時我畫的原理圖,可以進行仿真但是仿真出來蜂鳴器沒有聲音 ,對撥碼開關進行調節數碼管會顯示不同數字,但是我不知道我這個仿真結果是不是正確,我的仿真調節左邊撥碼開關但是數碼管變化的卻是是右邊。
ID:1073370 發表于 2023-4-22 15:00 | 顯示全部樓層
#include <AT89X52.h>
unsigned char code SEGtable[]=
        0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00
sbit sw7 = P0 ^ 7;
sbit sw6 = P0 ^ 6;
sbit sw5 = P0 ^ 5;
sbit sw4 = P0 ^ 4;
sbit sw3 = P0 ^ 3;
sbit sw2 = P0 ^ 2;
sbit sw1 = P0 ^ 1;
sbit sw0 = P0 ^ 0;
sbit FMQ = P1 ^ 7;
bit alarmflg = 0;
unsigned RxByte = 0x00;
unsigned char counter = 0;
unsigned char Scounter,Lcounter;  //·Ö±ð´æ·Å×Ô¼ºµÄˮλ״̬ºÍÔ¶·½µÄˮλ״̬
unsigned char FMcounter = 0x02;   //±¨¾¯×´Ì¬²ÎÊý
void DelayFM(unsigned int x)
         unsigned char t;
        while(x--)
                 for(t=0;t<120;t++);
//·äÃùÆ÷Çý¶¯º¯Êý£¬²ÎÊýΪ·¢ÉùÉùµ÷
void FM(unsigned char x)
         unsigned char i;
        for(i=0;i<100;i++)
                 FMQ = ~FMQ;
                DelayFM(x);
        FMQ = 0;
void Delayms(unsigned int MS)
        unsigned int i,j;
        for( i=0;i<MS;i++)
                for(j=0;j<1141;j++);
void InitUART(void)
    TMOD = 0x20;     //9600bps
    SCON = 0x50;
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
void Send(unsigned char x)
  SBUF = x;
  while(TI == 0);
  TI = 0;
void Serial(void) interrupt 4 using 1
        unsigned char RxByte;
        if(RI == 1)
                RxByte = SBUF;
                RI = 0;
    P2 = RxByte;
    switch(RxByte)
      case 0x00: Lcounter = 0;break;
      case 0xf9: Lcounter = 1;break;
      case 0xa4: Lcounter = 2;break;
      case 0xb0: Lcounter = 3;break;
      case 0x99: Lcounter = 4;break;
      case 0x92: Lcounter = 5;break;
      case 0x82: Lcounter = 6;break;
      case 0xF8: Lcounter = 7;break;
      case 0x80: Lcounter = 8;break;
      default:{};
    if(Scounter > Lcounter)
      if((Scounter - Lcounter) > 2)
        FMcounter = Scounter - Lcounter;
        alarmflg = 1;
        alarmflg = 0;
      alarmflg = 0;
int main(void)
   InitUART();
     Delayms(100);
     P0 = 0xFF;
     counter = 0;
     counter = counter + (unsigned char)sw7;
     counter = counter + (unsigned char)sw6;
     counter = counter + (unsigned char)sw5;
     counter = counter + (unsigned char)sw4;
     counter = counter + (unsigned char)sw3;
     counter = counter + (unsigned char)sw2;
     counter = counter + (unsigned char)sw1;
     counter = counter + (unsigned char)sw0;
     Scounter = counter;
     Send(SEGtable[counter]);
     if(alarmflg == 1)
      FM(FMcounter);
