查看: 2488|回復: 0
STM32單片機DS18B20+ESP8266+OneNet+pwm溫控風扇代碼
ID:1003388 發表于 2023-4-17 09:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include "stm32f10x.h"
  2. #include "bsp_SysTick.h"
  3. #include "bsp_usart1.h"
  4. #include "bsp_usart3.h"
  5. #include "TIM3.h"
  6. #include "temper.h"
  7. #include "power.h"
  8. #include "infra_red.h"
  9. #include "stm32f10x_it.h"
  10. //C庫
  11. #include <string.h>
  12. //WIFI
  13. #include "esp8266.h"
  14. #include "onenet.h"
  15. unsigned char order = 0;
  16. __IO float temper= 0;
  17. unsigned char pwm = 0;
  18. /***************************************************************************************************************************************/
  19. /*-------------------------------------------------------------------------------------------------------------------------------------*/
  20. /*-----------------------------------------------------------------主函數--------------------------------------------------------------*/
  21. /*-------------------------------------------------------------------------------------------------------------------------------------*/
  22. /***************************************************************************************************************************************/
  23. int main(void)
  24. {
  25.
  26.
  27.         unsigned short timeCount = 0;        //發送間隔變量
  28.         unsigned char *dataPtr = NULL;
  29.         char power = 0;
  30.         u8 t=0;
  31.         /******************各模塊功能初始化********************/
  32.         //設置中斷組為2
  33.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  34.         SysTick_Init();
  35.         POWER_GPIO_Config();
  36.         USART_Config();
  37.         TIM3_Init();
  38.         RED_GPIO_Config();
  39.         USART3_Config();
  40.         DS18B20_GPIO_Config();
  41.         ESP8266_Init();
  42. /**********************************************************************************************************************************************/
  43. /**********************************************************************************************************************************************/
  44. /**********************************************************************************************************************************************/
  45.         SysTick_Delay_Ms(500);
  46.         while(OneNet_DevLink())                        //接入OneNET
  47.                 SysTick_Delay_Ms(500);
  48.         while(1)
  49.         {
  50.                  if(t%10==0)                          //每100ms讀取一次
  51.                 {
  52.                         temper = DS18B20_Get_Temp();
  53.                 }
  54.                 if(t%100==0)                        //每1s串口1發送一次
  55.                 {
  56.                         printf("溫度:%.2f\r\n",temper);
  57.                 }
  58. /******************************************************************************/
  59.                 switch (order)
  60.                 {
  61. /******************************************************************************/
  62.                         //正常運行模式 order 0
  63.                         case 0:
  64.                                 if(RED == 1)
  65.                                 {
  66.                                         power = 1;
  67.                                 }else
  68.                                 {
  69.                                         power = 0;
  70.                                         POWER_OFF
  71.                                         pwm = 0;
  72.                                 }
  73.                                 if(power)
  74.                                 {
  75.                                         if(temper>35)
  76.                                         {
  77.                                                 POWER_ON
  78.                                                 pwm = 100;
  79.                                         }else if(temper>25&temper<35)
  80.                                         {
  81.                                                 POWER_ON
  82.                                                 pwm = ((((int)(temper*100))-2500)/10);
  83.                                         }else
  84.                                         {
  85.                                                 POWER_OFF
  86.                                                 pwm = 0;
  87.                                         }
  88.                                         TIM_SetCompare2(TIM3,pwm);         //設置占空比改變電機轉速
  89.                                 }
  90.                                 break;
  91. /****************************************************************************/
  92.                         case 1:
  93.                                 POWER_ON
  94.                                 TIM_SetCompare2(TIM3,25);
  95.                                 pwm = 25;
  96.                                 break;
  97.                         case 2:
  98.                                 POWER_ON
  99.                                 TIM_SetCompare2(TIM3,50);
  100.                                 pwm = 50;
  101.                                 break;
  102.                         case 3:
  103.                                 POWER_ON
  104.                                 TIM_SetCompare2(TIM3,75);
  105.                                 pwm = 75;
  106.                                 break;
  107.                         case 4:
  108.                                 POWER_ON
  109.                                 TIM_SetCompare2(TIM3,100);
  110.                                 pwm = 100;
  111.                                 break;
  112.                         case 5:
  113.                                 POWER_OFF
  114.                                 pwm = 0;
  115.                                 break;
  116.                 }
  117.
  118.
  119.
  120.
  121.                  SysTick_Delay_Ms(10);
  122.                 t++;
  123.                 if(++timeCount >= 500)        //發送間隔5s
  124.                 {
  125.                         printf("OneNet_SendData\r\n");
  126.                         OneNet_SendData();        //發送數據
  127.                         timeCount = 0;
  128.                         ESP8266_Clear();
  129.                 }
  130.
  131.                 dataPtr = ESP8266_GetIPD(0);
  132.                 if(dataPtr != NULL)
  133.                         OneNet_RevPro(dataPtr);
  134.
  135.         }
  136. }
Keil代碼下載(只有代碼,不含其他資料): 程序.7z (197.39 KB, 下載次數: 65)
參與人數 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
