查看: 1163|回復: 4
C語言CRC 16效驗程序不對
ID:64817 發表于 2023-3-26 18:02 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
各位請教 一下,我在網上找的CRC 16校驗程序在《Visual C++ 6.0》運行結果不對,請大家看一下哪里不對。
#include<stdio.h>
unsigned char aucCRCHi[]={
       0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
       0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
       0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
       0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
       0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
unsigned char aucCRCLo[]={
       0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
       0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
       0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
       0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
       0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
       0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
       0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
       0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
       0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
       0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
       0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
       0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
       0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
       0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
       0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
       0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
       0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
       0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
       0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
       0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
       0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
       0x41, 0x81, 0x80, 0x40
unsigned short GetQuickCRC16( int *a, int Length)
       unsigned char CRCHi = 0xFF;
       unsigned char CRCLo = 0xFF;
       unsigned char iIndex = 0;
       for (int i = 0; i < Length; i++)
              iIndex = CRCHi ^ a[ i];
              CRCHi = CRCLo ^ aucCRCHi[iIndex];
              CRCLo = aucCRCLo[iIndex];
       return (unsigned int)( CRCHi << 8 | CRCLo);// CRC校驗返回值
int pCharData[] = { 0x01,0x05,0x00 ,0x00,0xFF,0x00};  // 數據
int main()
     GetQuickCRC16(pCharData,6);
         printf ("0X%x\n",pCharData);
ID:883242 發表于 2023-3-26 20:35 | 只看該作者
首先要搞清楚你認為是對的CRC16采用的是什么多項式。
ID:1034262 發表于 2023-3-26 21:01 | 只看該作者
你用的什么多項式?看著像MODBUS-RT用的,記得初值要給FFFF。
ID:64817 發表于 2023-3-27 08:00 來自觸屏版 | 只看該作者
Hephaestus 發表于 2023-3-26 20:35
對謝,已解決
ID:64817 發表于 2023-3-27 08:01 來自觸屏版 | 只看該作者
coody_sz 發表于 2023-3-26 21:01
對謝,已解決
