查看: 2018|回復: 6
關于51單片機C語言求數組大小的問題
ID:1065477 發表于 2023-3-7 22:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機C語言源程序如下:
/*MODE:Triangle*/
char code Mode_Tri[]=
{0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x01,0x3E,0x01,0x3F,0x20,0x00,/*"M",0*/
0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,/*"O",1*/
0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,/*"D",2*/
0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,/*"E",3*/
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,/*":",4*/
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,/*"T",5*/
0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,/*"r",6*/
0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"i",7*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x19,0x24,0x24,0x12,0x3F,0x20,0x00,/*"a",8*/
0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,/*"n",9*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,/*"g",10*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"l",11*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x24,0x24,0x24,0x24,0x17,0x00};/*"e",12*/
我想求如上字模數組的字符數
void getCharSize(unsigned char zk*)
     unsigned char charNum = sizeof(zk)/sizeof(*(zk))/16;
     //這里用Keil Debug看了,charNum =0x03;
麻煩請教一下大佬,如何才能在函數體內求得正確的字符數大小
ID:1012735 發表于 2023-3-8 01:24 | 只看該作者
strlen(char*)
ID:1034262 發表于 2023-3-8 09:53 | 只看該作者
你試試  unsigned char charNum = sizeof(zk)/16,就可以得到字符數。
ID:1065477 發表于 2023-3-8 10:56 | 只看該作者
coody_sz 發表于 2023-3-8 09:53
這個方法已經試過了,不太管用
ID:97322 發表于 2023-3-9 10:04 | 只看該作者
sizeof(zk)/sizeof(zk[0])
ID:353115 發表于 2023-3-9 10:54 | 只看該作者
不可以的,數組經過函數形參傳參后,會退化為指針的。得使用sizeof(Mode_Tri)/16
ID:807182 發表于 2023-3-9 14:22 | 只看該作者
直接strlen就可以啊
