查看: 2055|回復: 8
求陰歷及24節氣轉換數據表 打算制作跨越兩個世紀的桌面時鐘
ID:526108 發表于 2023-3-4 08:54 | 顯示全部樓層 |閱讀模式
這是我20年收集的24節氣轉換數據表,23年之前運行都是正確的,但今年算出來的節氣就不對了
希望網友能提供更精確的轉換表,最好能提供21世紀和22世紀的表格,打算做跨越兩個世紀的桌面時鐘
謝謝
ID:301191 發表于 2023-3-6 04:13 | 顯示全部樓層
頂一下
ID:155507 發表于 2023-3-6 08:39 | 顯示全部樓層
程序分享出來給需要的人作參考
  1. /****************************************************************************************************************************
  2. 二十四節氣數據庫(2000--2100)
  3. 數據格式說明:
  4. 每個月對應2個節氣,以下表是按節氣順序排
  5. 小寒大寒立春雨水驚蟄春分清明谷雨立夏小滿芒種夏至小暑大暑立秋處暑白露秋分寒露霜降立冬小雪大雪冬至
  6. 如2000年
  7. 1月6、21為小寒大寒
  8. ****************************************************************************************************************************/
  9. unsigned char code jieqi[]=
  10. { //
  11. 0x06,0x15,0x04,0x13,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2000
  12. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2001
  13. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x15,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2002
  14. 0x06,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x16,0x07,0x17,0x08,0x17,0x08,0x17,0x09,0x18,0x08,0x17,0x07,0x16, //2003
  15. 0x06,0x15,0x04,0x13,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2004
  16. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2005
  17. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2006
  18. 0x06,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x16,0x07,0x17,0x08,0x17,0x08,0x17,0x09,0x18,0x08,0x17,0x07,0x16, //2007
  19. 0x06,0x15,0x04,0x13,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2008
  20. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2009
  21. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2010
  22. 0x06,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x16,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x18,0x08,0x17,0x07,0x16, //2011
  23. 0x06,0x15,0x04,0x13,0x05,0x14,0x04,0x14,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2012
  24. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2013
  25. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2014
  26. 0x06,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x16,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x18,0x08,0x16,0x07,0x16, //2015
  27. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2016
  28. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2017
  29. 0x05,0x14,0x04,0x13,0x05,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2018
  30. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x15,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x18,0x08,0x16,0x07,0x16, //2019
  31. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2020
  32. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2021
  33. 0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2022
  34. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x15,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x18,0x08,0x16,0x07,0x16, //2023
  35. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2024
  36. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2025
  37. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2026
  38. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x15,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2027
  39. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2028
  40. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2029
  41. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2030
  42. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x06,0x15,0x06,0x15,0x07,0x17,0x08,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2031
  43. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2032
  44. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2033
  45. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2034
  46. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2035
  47. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2036
  48. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2037
  49. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2038
  50. 0x05,0x14,0x04,0x13,0x05,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2039
  51. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2040
  52. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2041
  53. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2042
  54. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2043
  55. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x16,0x06,0x15, //2044
  56. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2045
  57. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2046
  58. 0x05,0x14,0x04,0x13,0x06,0x15,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x08,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2047
  59. 0x06,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2048
  60. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2049
  61. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2050
  62. 0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x05,0x15,0x06,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2051
  63. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2052
  64. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2053
  65. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2054
  66. 0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2055
  67. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2056
  68. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2057
  69. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2058
  70. 0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2059
  71. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2060
  72. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2061
  73. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2062
  74. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2063
  75. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2064
  76. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2065
  77. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2066
  78. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2067
  79. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x04,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2068
  80. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2069
  81. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2070
  82. 0x05,0x14,0x04,0x12,0x05,0x14,0x05,0x14,0x05,0x15,0x05,0x15,0x07,0x17,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2071
  83. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x04,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2072
  84. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x16,0x06,0x15, //2073
  85. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x14,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2074
  86. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2075
  87. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x04,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2076
  88. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x16,0x06,0x15, //2077
  89. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x17,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2078
  90. 0x05,0x14,0x04,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2079
  91. 0x05,0x14,0x04,0x13,0x05,0x14,0x04,0x13,0x04,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2080
  92. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2081
  93. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2082
  94. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2083
  95. 0x05,0x14,0x04,0x13,0x04,0x13,0x04,0x13,0x04,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x06,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2084
  96. 0x04,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2085
  97. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x07,0x15, //2086
  98. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x16, //2087
  99. 0x05,0x14,0x04,0x13,0x04,0x13,0x04,0x13,0x04,0x14,0x04,0x14,0x06,0x16,0x06,0x16,0x06,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2088
  100. 0x04,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x17,0x07,0x15,0x06,0x15, //2089
  101. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2090
  102. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2091
  103. 0x05,0x14,0x04,0x13,0x04,0x13,0x04,0x13,0x04,0x14,0x04,0x14,0x06,0x16,0x06,0x16,0x06,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2092
  104. 0x04,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x07,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2093
  105. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2094
  106. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2095
  107. 0x05,0x14,0x04,0x12,0x04,0x13,0x04,0x13,0x04,0x14,0x04,0x14,0x06,0x16,0x06,0x16,0x06,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2096
  108. 0x04,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x14,0x06,0x16,0x06,0x16,0x07,0x16,0x07,0x16,0x06,0x15,0x06,0x15, //2097
  109. 0x05,0x13,0x03,0x12,0x05,0x14,0x04,0x13,0x05,0x14,0x05,0x15,0x06,0x16,0x07,0x16,0x07,0x16,0x08,0x17,0x07,0x16,0x06,0x15, //2098
  110. 0x05,0x14,0x03,0x12,0x05,0x14,0x04,0x14,0x05,0x15,0x05,0x15,0x07,0x16,0x07,0x17,0x07,0x17,0x08,0x17,0x07,0x16,0x07,0x15, //2099
  111. } ;
  112. //*****************************************************************************************
  113. // 24節氣計算,采用查表法
  114. //輸入參數:用十進制,年值00-99,對應為2000-2099年,月值1-12,日值1-31.
  115. //返回值:0為沒節氣,1-24分別對應 小寒 大寒 立春 雨水 驚蟄 春分 清明 谷雨 立夏 小滿 芒種 夏至
  116. //                               小暑 大暑 立秋 處暑 白露 秋分 寒露 霜降 立冬 小雪 大雪 冬至
  117. //******************************************************************************************
  118. uchar jieqijisuan(uchar yeardat,uchar moondat,uchar daydat)
  119. {//參數1為年值,2為月,3為日
  120.     uchar k=0;
  121.     if(daydat==jieqi[yeardat*24+(moondat-1)*2])k=(moondat-1)*2+1;
  122.     if(daydat==jieqi[yeardat*24+(moondat-1)*2+1])k=(moondat-1)*2+2;
  123.     return k;
  124. }
ID:332444 發表于 2023-3-6 10:24 | 顯示全部樓層
通常像用這樣的表也會有誤的,網絡上提問不少.以前看到有人計算軌跡獲得,不過精度要求運算位不少,不同運算位誤差也存在,由于目前電腦運算位數有限,必須采取算法技巧進行處理到需要的精度才能符合要求,忘記哪里看到了.
ID:384109 發表于 2023-3-6 10:35 | 顯示全部樓層
這個?那古代沒有計算機的時候是怎么算的,畢竟24節氣也是古代人統計出來的啊
ID:16255 發表于 2023-3-6 17:26 | 顯示全部樓層
“打算做跨越兩個世紀的桌面時鐘”
兩個世紀,如果你有這么長壽,它也不一定熬得到那一天……
ID:16255 發表于 2023-3-6 17:30 | 顯示全部樓層
我也在我的時鐘中加入了二十四節氣的提醒,但似乎并沒有什么太大的作用,相比普通節假日和家人生日什么的來說二十四節氣并沒有什么用處。
ID:155507 發表于 2023-3-6 17:43 | 顯示全部樓層
mengsiu 發表于 2023-3-6 17:26
留來做傳家寶。
ID:526108 發表于 2023-3-6 18:45 | 顯示全部樓層
angmall 發表于 2023-3-6 08:39
程序分享出來給需要的人作參考
你的表太大了,我自己做了張表。
做表好累,200年得慢慢做
