- 作品:EEPROM實驗,開機還原關電前LED的亮滅狀況
- 單片機:STC89C52RC
- 晶振:12M
- 編譯環境:Keil uVision4 V9.00
- //#include <STC89C52RC.H>
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- //定義ISP的操作命令
- #define RdCommand 0x01 //讀命令
- #define PrgCommand 0x02 //寫命令
- #define EraseCommand 0x03 //擦除命令
- #define WaitTime 0x01 //定義CPU的等待時間,寫入硬件延時
- /****************特殊功能寄存器聲明****************/
- sfr ISP_DATA = 0xe2;
- sfr ISP_ADDRH = 0xe3;
- sfr ISP_ADDRL = 0xe4;
- sfr ISP_CMD = 0xe5;
- sfr ISP_TRIG = 0xe6;
- sfr ISP_CONTR = 0xe7;
- sbit LED1 = P2^0;
- sbit LED2 = P2^1;
- sbit K1 = P3^2; //按鈕1
- sbit K2 = P3^3; //按鈕2
- /* ================ 打開 ISP,IAP 功能 ================= */
- void ISP_IAP_enable(void)
- EA = 0; /* 關中斷 */
- ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
- ISP_CONTR = ISP_CONTR | WaitTime; /* 寫入硬件延時 */
- ISP_CONTR = ISP_CONTR | 0x80; /* ISPEN=1 */
- /* =============== 關閉 ISP,IAP 功能 ================== */
- void ISP_IAP_disable(void)
- ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
- ISP_TRIG = 0x00;
- EA = 1; /* 開中斷 */
- /* ================ 公用的觸發代碼 ==================== */
- void ISPgoon(void)
- ISP_IAP_enable(); /* 打開 ISP,IAP 功能 */
- ISP_TRIG = 0x46; /* 觸發ISP_IAP命令字節1 */
- ISP_TRIG = 0xb9; /* 觸發ISP_IAP命令字節2 */
- _nop_();
- /* ==================== 字節讀 ======================== */
- unsigned char byte_read(unsigned int byte_addr)
- ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* 地址賦值 */
- ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
- ISP_CMD = ISP_CMD & 0xf8; /* 清除低3位 */
- ISP_CMD = ISP_CMD | RdCommand; /* 寫入讀命令 */
- ISPgoon(); /* 觸發執行 */
- ISP_IAP_disable(); /* 關閉ISP,IAP功能 */
- return (ISP_DATA); /* 返回讀到的數據 */
- /* ================== 扇區擦除 ======================== */
- void SectorErase(unsigned int sector_addr)
- unsigned int iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00); /* 取扇區地址 */
- ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 */
- ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 */
- /* ==================== 字節寫 ======================== */
- void byte_write(unsigned int byte_addr, unsigned char original_data)
- ISP_ADDRH = (unsigned char)(byte_addr >> 8); /* 取地址 */
- ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 */
- ISP_CMD = ISP_CMD | PrgCommand; /* 寫命令2 */
- ISP_DATA = original_data; /* 寫入數據準備 */
- ISP_IAP_disable(); /* 關閉IAP功能 */
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=120;j>0;j--);
- 函數:主程序
- void main(void)
- uchar V;
- V = byte_read(0x2002); // 開機讀取EEPROM區2002h數據,還原關電前LED的亮滅狀況
- if(V == 2){LED1=0;LED2=1;}
- else if(V == 6){LED1=1;LED2=0;}
- else {LED1=0;LED2=0;}//首次上電EEPROM的默認數據是0xff
- while(1)
- if(!K1)
- delayms(10);
- if(!K1)
- LED1=0;LED2=1;
- while(!K1);//等待松手
- SectorErase(0x2000); // 擦除第1個扇區(2000h~21FFh)
- byte_write(0x2002,2); // 對EEPROM區2002h寫入2
- if(!K2)
- delayms(10);
- if(!K2)
- LED1=1;LED2=0;
- while(!K2);//等待松手
- byte_write(0x2002,6); // 對EEPROM區2002h寫入6
復制代碼 |
