查看: 2472|回復(fù): 11
怎么向STC89C52單片機(jī)中寫入大容量數(shù)組?
ID:938524 發(fā)表于 2023-2-23 23:02 | 顯示全部樓層 |閱讀模式
如題,大概有1-2k個(gè)數(shù)據(jù)的數(shù)組,怎么將它寫入89c52的eeprom中呢?怎樣進(jìn)行具體操作?
ID:94031 發(fā)表于 2023-2-24 06:17 | 顯示全部樓層
STC89C52RC內(nèi)部EEPROM的讀寫:https://blog.csdn.net/waitstory12/article/details/79900932
ID:213173 發(fā)表于 2023-2-24 06:29 | 顯示全部樓層
按扇區(qū)分段寫入EEPROM,每個(gè)扇區(qū)512字節(jié),共8個(gè)扇區(qū),共4M。地址0x2000~0x2E00。
  1. //STC89C52系列EEPROM多字節(jié)多扇區(qū)讀寫應(yīng)用示例
  2. #include <reg52.h>      //52系列單片機(jī)頭文件
  3. #include <intrins.h>
  4. #include <stdlib.h>        //包含產(chǎn)生隨機(jī)數(shù)用到的rand()函數(shù)。
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. //定義ISP的操作命令
  8. #define RdCommand 0x01                //讀命令
  9. #define PrgCommand 0x02                //寫命令
  10. #define EraseCommand 0x03        //擦除命令
  11. #define WaitTime 0x01                 //定義CPU的等待時(shí)間,寫入硬件延時(shí)
  12. /*STC89系列EEPROM寄存器聲明*/
  13. sfr ISP_DATA  = 0xe2;                //0000,0000 EEPROM數(shù)據(jù)寄存器
  14. sfr ISP_ADDRH = 0xe3;                //0000,0000 EEPROM地址高字節(jié)
  15. sfr ISP_ADDRL = 0xe4;                //0000,0000 EEPROM地址第字節(jié)
  16. sfr ISP_CMD   = 0xe5;                //xxxx,xx00 EEPROM命令寄存器
  17. sfr ISP_TRIG  = 0xe6;                //0000,0000 EEPRPM命令觸發(fā)寄存器
  18. sfr ISP_CONTR = 0xe7;                //0000,x000 EEPROM控制寄存器
  19. sbit LED1=P1^0;
  20. sbit LED2=P1^7;
  21. /* 測試常量數(shù)組 */
  22. uchar code table[512] =
  23. {
  24.     0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
  25.     0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,
  26.     0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f,
  27.     0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f,
  28.     0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,
  29.     0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f,
  30.     0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,
  31.     0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
  32.     0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
  33.     0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
  34.     0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf,
  35.     0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
  36.     0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf,
  37.     0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
  38.     0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
  39.     0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff,
  40.     0xff,0xfe,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,
  41.     0xef,0xee,0xed,0xec,0xeb,0xea,0xe9,0xe8,0xe7,0xe6,0xe5,0xe4,0xe3,0xe2,0xe1,0xe0,
  42.     0xdf,0xde,0xdd,0xdc,0xdb,0xda,0xd9,0xd8,0xd7,0xd6,0xd5,0xd4,0xd3,0xd2,0xd1,0xd0,
  43.     0xcf,0xce,0xcd,0xcc,0xcb,0xca,0xc9,0xc8,0xc7,0xc6,0xc5,0xc4,0xc3,0xc2,0xc1,0xc0,
  44.     0xbf,0xbe,0xbd,0xbc,0xbb,0xba,0xb9,0xb8,0xb7,0xb6,0xb5,0xb4,0xb3,0xb2,0xb1,0xb0,
  45.     0xaf,0xae,0xad,0xac,0xab,0xaa,0xa9,0xa8,0xa7,0xa6,0xa5,0xa4,0xa3,0xa2,0xa1,0xa0,
  46.     0x9f,0x9e,0x9d,0x9c,0x9b,0x9a,0x99,0x98,0x97,0x96,0x95,0x94,0x93,0x92,0x91,0x90,
  47.     0x8f,0x8e,0x8d,0x8c,0x8b,0x8a,0x89,0x88,0x87,0x86,0x85,0x84,0x83,0x82,0x81,0x80,
  48.     0x7f,0x7e,0x7d,0x7c,0x7b,0x7a,0x79,0x78,0x77,0x76,0x75,0x74,0x73,0x72,0x71,0x70,
  49.     0x6f,0x6e,0x6d,0x6c,0x6b,0x6a,0x69,0x68,0x67,0x66,0x65,0x64,0x63,0x62,0x61,0x60,
  50.     0x5f,0x5e,0x5d,0x5c,0x5b,0x5a,0x59,0x58,0x57,0x56,0x55,0x54,0x53,0x52,0x51,0x50,
  51.     0x4f,0x4e,0x4d,0x4c,0x4b,0x4a,0x49,0x48,0x47,0x46,0x45,0x44,0x43,0x42,0x41,0x40,
  52.     0x3f,0x3e,0x3d,0x3c,0x3b,0x3a,0x39,0x38,0x33,0x36,0x35,0x34,0x33,0x32,0x31,0x30,
  53.     0x2f,0x2e,0x2d,0x2c,0x2b,0x2a,0x29,0x28,0x27,0x26,0x25,0x24,0x23,0x22,0x21,0x20,
  54.     0x1f,0x1e,0x1d,0x1c,0x1b,0x1a,0x19,0x18,0x17,0x16,0x15,0x14,0x13,0x12,0x11,0x10,
  55.     0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01,0x00
  56. };
  57. uint code table1[]={0x2000,0x2200,0x2400,0x2600,0x2800,0x2a00};//STC89C52RC EEPROM 扇區(qū)地址
  58. //uint code table1[]={0x4000,0x4200,0x4400,0x4600,0x4800,0x4a00};//STC89C54 EEPROM 扇區(qū)地址
  59. uint Random;//隨機(jī)數(shù)變量
  60. /* ================ 打開 ISP,IAP 功能 ================= */
  61. void ISP_IAP_enable(void)
  62. {
  63.         EA = 0;       /* 關(guān)中斷   */
  64.         ISP_CONTR = ISP_CONTR & 0x18;       /* 0001,1000 */
  65.         ISP_CONTR = ISP_CONTR | WaitTime; /* 寫入硬件延時(shí) */
  66.         ISP_CONTR = ISP_CONTR | 0x80;       /* ISPEN=1  */
  67. }
  68. /* =============== 關(guān)閉 ISP,IAP 功能 ================== */
  69. void ISP_IAP_disable(void)
  70. {
  71.         ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
  72.         ISP_TRIG = 0x00;
  73.         EA   =   1;   /* 開中斷 */
  74. }
  75. /* ================ 公用的觸發(fā)代碼 ==================== */
  76. void ISPgoon(void)
  77. {
  78.         ISP_IAP_enable();   /* 打開 ISP,IAP 功能 */
  79.         ISP_TRIG = 0x46;  /* 觸發(fā)ISP_IAP命令字節(jié)1 */
  80.         ISP_TRIG = 0xb9;  /* 觸發(fā)ISP_IAP命令字節(jié)2 */
  81.         _nop_();
  82. }
  83. /* ==================== 字節(jié)讀 ======================== */
  84. uchar byte_read(uint byte_addr)
  85. {
  86.         ISP_ADDRH = (uchar)(byte_addr >> 8);/* 地址賦值 */
  87.         ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
  88.         ISP_CMD   = ISP_CMD & 0xf8;   /* 清除低3位  */
  89.         ISP_CMD   = ISP_CMD | RdCommand; /* 寫入讀命令 */
  90.         ISPgoon();       /* 觸發(fā)執(zhí)行  */
  91.         ISP_IAP_disable();    /* 關(guān)閉ISP,IAP功能 */
  92.         return (ISP_DATA);    /* 返回讀到的數(shù)據(jù) */
  93. }
  94. /* ================== 扇區(qū)擦除 ======================== */
  95. void SectorErase(uint sector_addr)
  96. {
  97.         uint iSectorAddr;
  98.         iSectorAddr = (sector_addr & 0xfe00); /* 取扇區(qū)地址 */
  99.         ISP_ADDRH = (uchar)(iSectorAddr >> 8);
  100.         ISP_ADDRL = 0x00;
  101.         ISP_CMD = ISP_CMD & 0xf8;   /* 清空低3位  */
  102.         ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3  */
  103.         ISPgoon();       /* 觸發(fā)執(zhí)行  */
  104.         ISP_IAP_disable();    /* 關(guān)閉ISP,IAP功能 */
  105. }
  106. /* ==================== 字節(jié)寫 ======================== */
  107. void byte_write(uint byte_addr, uchar original_data)
  108. {
  109.         ISP_ADDRH = (uchar)(byte_addr >> 8);  /* 取地址  */
  110.         ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
  111.         ISP_CMD  = ISP_CMD & 0xf8;    /* 清低3位 */
  112.         ISP_CMD  = ISP_CMD | PrgCommand;  /* 寫命令2 */
  113.         ISP_DATA = original_data;   /* 寫入數(shù)據(jù)準(zhǔn)備 */
  114.         ISPgoon();       /* 觸發(fā)執(zhí)行  */
  115.         ISP_IAP_disable();     /* 關(guān)閉IAP功能 */
  116. }
  117. void main()
  118. {
  119.         uchar i;
  120.         uint j,k;
  121.         LED2=0;//LED2亮
  122.         k=50000;
  123.         while(k--);//延時(shí)等待系統(tǒng)穩(wěn)定
  124.         LED2=1;//LED2滅
  125.         for(i=0;i<6;i++)//循環(huán)寫6個(gè)扇區(qū)
  126.         {
  127.                 SectorErase(table1[i]);//擦除扇區(qū)
  128.                 for(j=0;j<512;j++)//循環(huán)寫512個(gè)字節(jié)
  129.                 {
  130.                         byte_write(table1[i]+j,table[j]);//寫入數(shù)據(jù)
  131.                         if(byte_read(table1[i]+j)!= table[j])//比較對錯(cuò)
  132.                         {
  133.                                 LED1=0;//錯(cuò)誤LED1亮
  134.                                 k=50000;
  135.                                 while(k--);//延時(shí)便于觀察
  136.                                 LED1=1;//LED1滅
  137.                         }
  138.                 }
  139.         }
  140.         Random=rand()/64;//生成0~511隨機(jī)數(shù)
  141.         if(byte_read(table1[Random%6]+Random)==table[Random])//隨機(jī)在6個(gè)扇區(qū)的隨機(jī)地址抽樣比對
  142.                 LED2=0;//正確LED2亮
  143.         else LED1=0;//錯(cuò)誤LED1亮
  144.         while(1);
  145. }
ID:155507 發(fā)表于 2023-2-24 08:22 | 顯示全部樓層
用stc—isp向stc89c52rc的eeprom寫數(shù)據(jù)
http://m.raoushi.com/bbs/dpj-168511-1.html
ID:320306 發(fā)表于 2023-2-24 09:27 | 顯示全部樓層
估計(jì)有難度,沒那么大空間
ID:1034262 發(fā)表于 2023-2-24 10:02 | 顯示全部樓層
zsyzdx 發(fā)表于 2023-2-24 09:27
估計(jì)有難度,沒那么大空間
有的,有5K的EEPROM。
ID:938524 發(fā)表于 2023-2-24 10:28 | 顯示全部樓層
xuyaqi 發(fā)表于 2023-2-24 06:17
謝謝大佬的幫助!
ID:938524 發(fā)表于 2023-2-24 10:29 | 顯示全部樓層
wulin 發(fā)表于 2023-2-24 06:29
謝謝大佬的幫助!
angmall 發(fā)表于 2023-2-24 08:22
謝謝大佬的幫助!
估計(jì)有難度,沒那么大空間
謝謝大佬的幫助!
coody_sz 發(fā)表于 2023-2-24 10:02
有的,有5K的EEPROM。
謝謝大佬的幫助!
ID:996773 發(fā)表于 2023-2-28 14:58 | 顯示全部樓層
慚愧,用了兩年stc89c52還不知道燒寫軟件可以向eeprom寫數(shù)據(jù),一直是在程序里面做批量向eeprom寫數(shù)據(jù)的
,學(xué)習(xí)了這是很實(shí)用方法,蟹蟹
